Date/Time: Thu, 26 Nov 2026 04:45:43 +0000
Minimize Restore Close Windows
View Count: 294
| [2026-05-19 16:11:00] |
| WarriorTrader - Posts: 259 |
Hello, Is there any way to move the "Minimize Restore Close" all the way to the right? It seems more natural when it is in the corner. Picture included. Thanks, WT |
| [2026-05-19 16:17:46] |
File attached
| [2026-05-19 17:17:20] |
The following setting can take any text. As such, you can add spaces to the beginning of it to put those items where you want them. General Settings Window: MDI Container Window Child Window Menu Text Separator (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-20 01:49:10] |
Thx, much better now.
| [2026-05-20 06:02:17] |
Come to think of it, one can use simple characters like __ ||| X to make it look like a regular window and stick it in the corner like a regular window. My original post was going to ask how to restore the window before I figured out the "Min. Restore Close" text on the top of the page. It would be nice if __ ||| X was the default. People would figure it out if the text was in the upper right corner like any other window. Possible to do list - easy little tidbit that makes a big difference to SC appearance? |
