Date/Time: Thu, 26 Nov 2026 04:45:49 +0000
Price Display Format
View Count: 252
| [2026-05-16 21:35:27] |
| User882361 - Posts: 8 |
I did try to figuring this subject, but found no solution yet... so: ZBM26-CBOT price is displayed as 110 23/32... is that possible to display it just as I see it on TT alike 110.23 or 110'23 ??? [ so getting rid off of .../32.... ] Date Time Of Last Edit: 2026-05-16 21:36:47
| [2026-05-17 19:53:50] |
| Sierra_Chart Engineering - Posts: 25491 |
Refer to this setting: General Settings Window: Display Fractions In Short Format (Global Settings >> General Settings >> Charts >> Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
