Date/Time: Thu, 26 Nov 2026 04:45:45 +0000
Third TPO Chart question
View Count: 240
| [2026-05-16 17:55:37] |
| User922418 - Posts: 42 |
Hello again, I run TPO Profile charts. When I have one TPO chartbook open, it usually has four to six individual TPO profile chart window, along with one bar chart window. With one TPO profile chartbook, my new top of the line high performance desktop runs fine. When I open a second, third, fourth, fifth, sixth and sometimes a seventh chartbook, things start to slow down. Hours later, it seems like things move at a snails pace. Si, I tried opening separate Sub-instances, thinking this might improve things and having only one chartbook in each instance window. Seven sub-instances running just one chartbook, and this makes things even slower. Any suggestions on how I can improve my desktops performance? Maybe there are some settings in SC that I need to change? If so, can you please tell me? Thank you |
| [2026-05-16 18:32:04] |
| Sierra_Chart Engineering - Posts: 25491 |
This is resolved by increasing this Input setting: Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks Also refer to: General Settings Window: Troubleshooting Performance Issues Related to Timers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-16 18:33:14
| [2026-05-16 19:04:29] |
Thank you
