Date/Time: Thu, 26 Nov 2026 04:45:51 +0000
Eurex Connectivity and Sierra Chart Second Instance
View Count: 289
| [2026-05-16 14:59:31] |
| User116561 - Posts: 16 |
Hi, I have been researching ways to connect to Eurex via Sierra Chart. I understand it is not supported by Teton and CQG order routing would needed for Eurex. I also understand CQG order routing is not preferred over Teton, and I'm trying to find the optimal way to connect to Eurex for my use case. Ideally, I would like to be able to use the Trading Spread Order Entry study within a chart, with CME and Eurex products as legs. I am almost certain if I run two instances of Sierra Chart, one with Teton/CME, and a second with Eurex/CQG, I will not be able to utilize the Trading Spread Order Entry study across instances/exchanges. I am wondering if there is a way to utilize Sierra Chart across the two instances. I would prefer to limit my risk and run CME and Eurex on separate instances, instead of having all order routing via CQG while using data from both exchanges to drive trading decisions. Any help is appreciated on this. Thanks. |
| [2026-05-18 05:57:59] |
| Sierra_Chart Engineering - Posts: 25491 |
If you want to do spread trading between CME and EUREX you will need to use CQG, and you will do this all in a single instance of Sierra Chart. There really is no way around this if you want to use the Spread Order Entry study. Have your broker set you up with trading for CME and EUREX on CQG and use the Denali Exchange Data Feed for both the CME and EUREX data, when using CQG: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-18 12:09:59] |
Thank you for responding.
