Date/Time: Thu, 26 Nov 2026 04:45:54 +0000
Question on Numbers Bars
View Count: 351
| [2026-05-15 19:50:19] |
| User545800 - Posts: 15 |
Thank you. I do see footprint number bars but then is displayed in some other language. Please see the attachment. Another clarification: In Numbers Bars, how do I add separate columns showing trade count filtered by size: for example one for |
| [2026-05-18 14:43:27] |
You need to scale your Numbers Bars appropriately to be able to view the numbers themselves. Refer to the following: Numbers Bars: Scaling a Numbers Bars Chart You can also add multiple price levels together using the "Volume at Price Multiplier". Refer to the following: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) In Numbers Bars, how do I add separate columns showing trade count filtered by size: for example one for
There is no support for filtering data based on volumes within the Numbers Bars study itself. You would need to have a chart that has the volume filtering on it, then add the Numbers Bars study to that chart. Refer to the following: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
