Date/Time: Thu, 26 Nov 2026 04:33:45 +0000
Volume bars on nifty not readable
View Count: 342
| [2026-05-15 14:05:45] |
| Brabim - Posts: 2 |
High i want to set number bar study on nifty futures but the numbers are too unclear. i have tried to fix this on my own but not able to do it. I would like Bid volume , ask volume and also the candlestick on the side .
| [2026-05-15 14:16:47] |
| Sierra_Chart Engineering - Posts: 25491 |
Provide an image of the chart showing this, by following these *exact* instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-15 16:40:49] |
| Brabim - Posts: 2 |
https://www.sierrachart.com/image.php?Image=1778863213862.png
| [2026-05-15 17:57:59] |
Refer to this section here to resolve: Numbers Bars: Adjusting Volume at Price Multiplier For Larger Increment Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
