Date/Time: Thu, 19 Nov 2026 05:39:55 +0000
Lagging data feed
View Count: 1388
| [2026-10-27 19:31:02] |
| John - SC Support - Posts: 48583 |
Is it Internet connectivity issue even though it specifically happens during switching timeframes ?
are you able to tell me what/where to look for ? We still find it very odd that it appears to be when you change timeframes. The only thing we can think of that could be occurring is that you are losing the connection and then when you change timeframes the system is finally recognizing this and tries to reconnect. This is why we suggest looking at your Power settings for your computer, particularly if it is a laptop. There are all kinds of options that can turn on/off functionality and perhaps something is going to "sleep" that is causing this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-27 21:00:06] |
| User719512 - Posts: 543 |
@Jimmyy you might look into a tool called LatencyMon and watch drivers for high DPC/ISR that could be causing TCP retransmissions. Download the latest version from the official Resplendence site (resplendence.com/latencymon). |
| [2026-10-28 17:39:46] |
| Jimmyy - Posts: 358 |
User719512, I downloaded but i am not sure where to go on from there. After I ran the test, it gave me conclusion saying Your system appears to be suitable for handling real time audio and other tasks without dropouts. Update: It just changed the conclusion to Your system seems to be having difficulty handling real time audio and other tasks. You may experience dropouts, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Date Time Of Last Edit: 2026-10-28 17:45:50
| [2026-10-30 17:08:03] |
Hi, It happened again today when connected to teton at 13:07 2026-10-30 08:37:39.097 | Trade activity files set size: 462 2026-10-30 08:37:39.177 | Reading Internal Order ID file. 2026-10-30 08:37:39.181 | Reading Trade Orders file. 2026-10-30 08:37:39.184 | Reading Trade Positions file. 2026-10-30 08:37:39.188 | Reading Trade Account Data files. 2026-10-30 08:37:39.192 | Software version: 2974 64-bit 2026-10-30 08:37:39.193 | OpenGL enabled (NVIDIA Corporation/NVIDIA GeForce GTX 1650/PCIe/SSE2) 2026-10-30 08:37:39.193 | Primary Thread ID: 16900 2026-10-30 08:37:39.193 | Usage end date: 2027-01-03 2026-10-30 08:37:39.193 | Enabled for: Advanced Features 2. 2026-10-30 08:37:39.193 | Enabled for: Sierra Chart Historical Data Service. 2026-10-30 08:37:39.193 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-10-30 08:37:39.193 | Enabled for: Delayed Denali Exchange Data Feed. 2026-10-30 08:37:39.193 | Enabled for exchange2: CME 2026-10-30 08:37:39.193 | Enabled for exchange2: CBOE Global Indexes Main 2026-10-30 08:37:39.193 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-10-30 08:37:39.193 | Current selected Data/Trading service: Teton CME Routing 2026-10-30 08:37:39.193 | Custom symbol settings values: enabled 2026-10-30 08:37:39.193 | Chart Update Interval: 100 2026-10-30 08:37:39.193 | Intraday Data Storage Time Unit: 0 2026-10-30 08:37:39.193 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-10-30 08:37:39.193 | 2026-10-30 12:37:39 Local computer time in UTC 2026-10-30 08:37:39.193 | 2026-10-30 08:37:39 Local computer time in SC Time Zone 2026-10-30 08:37:39.193 | 2026-10-30 12:37:31 Server time in UTC 2026-10-30 08:37:39.193 | Local computer UTC time and Server UTC time difference: 6 seconds. 2026-10-30 08:37:39.193 | Notice: Your computer's clock is off by 6 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'. 2026-10-30 08:37:39.193 | Program path: D:\SierraChart USA - Copy - Phillip 1 - Updated - JP\ 2026-10-30 08:37:39.193 | Data Files path: D:\SierraChart USA - Copy - Phillip 1 - Updated - JP\Data\ 2026-10-30 08:37:39.193 | OS Version Number: 10.0 2026-10-30 08:37:39.193 | Locale Setting: C 2026-10-30 08:37:39.193 | Crash reporter started: true 2026-10-30 08:37:39.193 | 2026-10-30 08:37:39.193 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2026-10-30 08:37:39.194 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-10-30 08:37:39.409 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. Socket close state=2 2026-10-30 08:37:39.409 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-10-30 08:37:39.662 | Received 5 login tokens. 2026-10-30 08:37:39.960 | Symbol settings MD5 received. Request ID: 1. 2026-10-30 08:37:39.960 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2026-10-30 08:37:41.740 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Reloading chart. 2026-10-30 08:37:41.740 | 2026-10-30 08:37:41.741 | Teton CME Routing | Firm: Phillip Capital 2026-10-30 08:37:41.741 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11089 2026-10-30 08:37:41.741 | Starting DelayedDownloadMonitoringTimer 2026-10-30 08:37:41.741 | Starting HDTimeoutTimer 2026-10-30 08:37:41.741 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-10-30 08:37:41.741 | Triggering next historical data download in queue. 2026-10-30 08:37:41.741 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Waiting for historical downloads to complete with the IDs: 1, 2026-10-30 08:37:41.757 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-10-30 08:37:41.757 | DTC Client socket (1) | New receive buffer size: 0 2026-10-30 08:37:41.757 | DTC Client socket (1) | Connecting to IP: 216.200.108.154 Port: 11089. 2026-10-30 08:37:41.994 | ESZ26_FUT_CME [C] 60 Min #3 | Reloading chart. 2026-10-30 08:37:41.995 | ESZ26_FUT_CME [C] 60 Min #3 | Waiting for historical downloads to complete with the IDs: 1, 2026-10-30 08:37:42.031 | ESZ26_FUT_CME [C] 15 Min #4 | Reloading chart. 2026-10-30 08:37:42.031 | ESZ26_FUT_CME [C] 15 Min #4 | Waiting for historical downloads to complete with the IDs: 1, 2026-10-30 08:37:42.054 | ESZ26_FUT_CME [C] 60 Min #5 | Reloading chart. 2026-10-30 08:37:42.054 | ESZ26_FUT_CME [C] 60 Min #5 | Waiting for historical downloads to complete with the IDs: 1, 2026-10-30 08:37:42.092 | ESZ26_FUT_CME [C] 5 Min #2 | Reloading chart. 2026-10-30 08:37:42.092 | ESZ26_FUT_CME [C] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2026-10-30 08:37:42.103 | Requested user files to download. 2026-10-30 08:37:42.103 | Removing historical data download ID 1. 2026-10-30 08:37:42.103 | Mapping ESZ26_FUT_CME to ESZ26. Service code: cme 2026-10-30 08:37:42.103 | Using symbol data fast lookup vector 2026-10-30 08:37:42.103 | HD Request # 1 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-10-30 08:37:42.103 | HD Request # 1 | Download start date-time: 2026-10-29 03:10:49.000000. File last date-time: 2026-10-29 03:10:49.880000 2026-10-30 08:37:42.103 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149 2026-10-30 08:37:42.111 | Teton CME Routing | Network connection to server complete. 2026-10-30 08:37:42.111 | Teton CME Routing | Starting socket receive thread. 2026-10-30 08:37:42.111 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-10-30 08:37:42.115 | Socket (3) | Creating socket. 2026-10-30 08:37:42.115 | Socket (3) | New receive buffer size: 0 2026-10-30 08:37:42.115 | Socket (3) | Connecting to IP: 67.214.125.5 Port: 10149. 2026-10-30 08:37:42.572 | HD Request # 1 | Setting DTC encoding to Binary VLS 2026-10-30 08:37:42.572 | HD Request # 1 | Sending historical data logon request message. 2026-10-30 08:37:42.721 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-10-30 08:37:42.721 | Teton CME Routing | Sending logon request message. 2026-10-30 08:37:42.831 | HD Request # 1 | Requesting Intraday data. Start date-time: 2026-10-29 03:10:49. Record interval: 0. Symbol: ESZ26 2026-10-30 08:37:42.975 | Teton CME Routing | Received logon response. 2026-10-30 08:37:42.975 | Teton CME Routing | Server Name: SC DTC Server. Build=58073. 2026-10-30 08:37:42.975 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-10-30 08:37:42.975 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-10-30 08:37:42.975 | Teton CME Routing | Trading is supported. 2026-10-30 08:37:42.975 | Teton CME Routing | Order cancel and replace is supported. 2026-10-30 08:37:42.975 | Teton CME Routing | OCO Orders supported. 2026-10-30 08:37:42.975 | Teton CME Routing | Bracket Orders supported. 2026-10-30 08:37:42.975 | Teton CME Routing | MarketDepthIsSupported: 1 2026-10-30 08:37:42.975 | Teton CME Routing | Connection to server complete. 2026-10-30 08:37:42.975 | No download requests in the queue to start downloads for. | Number times message added: 4 2026-10-30 08:37:42.975 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-10-30 08:37:42.979 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-10-28 19:14:02.932457 2026-10-30 08:37:43.049 | File to download: Alert triggered.wav. Action: 0 2026-10-30 08:37:43.050 | User files to download complete 2026-10-30 08:37:43.059 | HD Request # 1 | Decompressing data. 2026-10-30 08:37:43.189 | Updated verified funded futures trading account ending date to: 2026-11-29 12:37:43 2026-10-30 08:37:43.198 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=7PV5739 2026-10-30 08:37:43.300 | HD Request # 1 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-10-29 03:10:49.880000 2026-10-30 08:37:43.991 | HD Request # 1 | Timestamp of first Intraday data file record written: 2026-10-29 03:10:50.129000. 2026-10-30 08:37:52.840 | Socket (3) | CloseSocket call. 2026-10-30 08:37:52.840 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-10-30 08:37:52.840 | Historical data download thread signaled to stop. 2026-10-30 08:37:52.840 | HD Request # 1 | Received 1656251 Intraday data records from 2026-10-29 03:10:49.880000 to 2026-10-30 08:37:51.252002 (29.5 hours. Delay: 1.6 seconds) and wrote 1656250 records for ESZ26_FUT_CME 2026-10-30 08:37:52.844 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2026-10-30 12:37:51.252002 2026-10-30 08:37:52.844 | HD Request # 1 | Completion time: 10s. 2026-10-30 08:37:52.844 | HD Request # 1 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 1 2026-10-30 08:37:52.844 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2026-10-30 08:37:52.844 | Removing historical data download ID 1. 2026-10-30 08:37:52.844 | 2026-10-30 08:37:52.844 | No download requests in the queue to start downloads for. 2026-10-30 08:37:52.844 | Historical data for ESZ26_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-10-30 08:37:52.850 | ESZ26_FUT_CME [C] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-30 08:37:52.850 | ESZ26_FUT_CME [C] 5 Min #2 | Reloading chart. 2026-10-30 08:37:52.853 | ESZ26_FUT_CME [C] 60 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-30 08:37:52.855 | ESZ26_FUT_CME [C] 60 Min #3 | Reloading chart. 2026-10-30 08:37:52.890 | ESZ26_FUT_CME [C] 15 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-30 08:37:52.890 | ESZ26_FUT_CME [C] 15 Min #4 | Reloading chart. 2026-10-30 08:37:52.894 | ESZ26_FUT_CME [C] 60 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-30 08:37:52.902 | ESZ26_FUT_CME [C] 60 Min #5 | Reloading chart. 2026-10-30 08:37:52.905 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-30 08:37:52.905 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Reloading chart. 2026-10-30 08:37:52.989 | ESZ26_FUT_CME [C] 5 Min #2 | Reloading chart. 2026-10-30 08:37:53.035 | ESZ26_FUT_CME [C] 60 Min #3 | Reloading chart. 2026-10-30 08:37:53.067 | Socket (3) | Socket gracefully closed by remote side. Socket close state=2 2026-10-30 08:37:53.068 | Socket (3) | Closed. 2026-10-30 08:37:53.084 | ESZ26_FUT_CME [C] 15 Min #4 | Reloading chart. 2026-10-30 08:37:53.121 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Reloading chart. 2026-10-30 08:37:53.168 | ESZ26_FUT_CME [C] 60 Min #5 | Reloading chart. 2026-10-30 08:37:53.187 | Mapping ESZ26_FUT_CME to ESZ26. Service code: cme 2026-10-30 08:37:53.187 | Using symbol data fast lookup vector 2026-10-30 08:37:53.187 | Denali Data Feed | Starting real-time market data updates for: ESZ26_FUT_CME (ESZ26). ID: 1 Service code: cme 2026-10-30 08:37:53.188 | Denali Data Feed | Connecting to the server ds45.sierracharts.com. Port 443 2026-10-30 08:37:53.188 | Denali Data Feed | Requesting security definition data for: ESZ26_FUT_CME (ESZ26). ID: 1 2026-10-30 08:37:53.188 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-10-30 08:37:53.188 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'. 2026-10-30 08:37:53.188 | Triggering next historical data download in queue. 2026-10-30 08:37:53.188 | Removing historical data download ID 2. 2026-10-30 08:37:53.188 | Delaying start of download for ESZ26_FUT_CME. 2026-10-30 08:37:53.196 | DTC Client socket (2) | Creating socket. 2026-10-30 08:37:53.196 | DTC Client socket (2) | New receive buffer size: 0 2026-10-30 08:37:53.196 | DTC Client socket (2) | Connecting to IP: 146.88.135.98 Port: 443. 2026-10-30 08:37:53.235 | Mapping MESZ26_FUT_CME to MESZ26. Service code: cme 2026-10-30 08:37:53.235 | Denali Data Feed | Starting real-time market data updates for: MESZ26_FUT_CME (MESZ26). ID: 2 Service code: cme 2026-10-30 08:37:53.235 | Denali Data Feed | Requesting security definition data for: MESZ26_FUT_CME (MESZ26). ID: 2 2026-10-30 08:37:53.391 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ26_FUT_CME 2026-10-30 08:37:53.391 | Teton CME Routing | Setting external service identifier for symbol ESZ26_FUT_CME to 10252 2026-10-30 08:37:53.391 | Teton CME Routing | Received security definition for symbol ESZ26_FUT_CME 2026-10-30 08:37:53.437 | Denali Data Feed | Network connection to server complete. 2026-10-30 08:37:53.437 | Denali Data Feed | Starting socket receive thread. 2026-10-30 08:37:53.437 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-10-30 08:37:53.438 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ26_FUT_CME 2026-10-30 08:37:53.438 | Teton CME Routing | Setting external service identifier for symbol MESZ26_FUT_CME to 42001581 2026-10-30 08:37:53.438 | Teton CME Routing | Received security definition for symbol MESZ26_FUT_CME 2026-10-30 08:37:53.689 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-10-30 08:37:53.689 | Denali Data Feed | Sending logon request message. 2026-10-30 08:37:54.613 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 08:37:54.822 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-10-30 08:37:55.002 | Denali Data Feed | Received logon response. 2026-10-30 08:37:55.002 | Denali Data Feed | Server Name: SC Realtime Server. 2026-10-30 08:37:55.002 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-10-30 08:37:55.002 | Denali Data Feed | Successfully connected. 2026-10-30 08:37:55.002 | Denali Data Feed | Trading is not supported. 2026-10-30 08:37:55.002 | Denali Data Feed | MarketDepthIsSupported: 1 2026-10-30 08:37:55.002 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ26_FUT_CME -> ESZ26 2026-10-30 08:37:55.002 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ26_FUT_CME -> MESZ26 2026-10-30 08:37:55.346 | Denali Data Feed | Setting external service identifier for symbol ESZ26_FUT_CME to 10252 2026-10-30 08:37:55.346 | Denali Data Feed | Received security definition for symbol ESZ26_FUT_CME 2026-10-30 08:37:55.346 | Denali Data Feed | Setting external service identifier for symbol MESZ26_FUT_CME to 42001581 2026-10-30 08:37:55.346 | Denali Data Feed | Received security definition for symbol MESZ26_FUT_CME 2026-10-30 08:37:55.785 | ESZ26_FUT_CME [C][M] 15 Min #4 | Chart data loading complete. 2026-10-30 08:37:55.999 | ESZ26_FUT_CME [C][M] 60 Min #5 | Chart data loading complete. 2026-10-30 08:37:56.002 | ESZ26_FUT_CME [C][M] 60 Min #3 | Chart data loading complete. 2026-10-30 08:37:56.009 | ESZ26_FUT_CME [C][M] 5 Min #2 | Chart data loading complete. 2026-10-30 08:38:00.998 | HD Request # 2 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-10-30 08:38:00.998 | HD Request # 2 | Download start date-time: 2026-10-30 08:37:51.000000. File last date-time: 2026-10-30 08:37:51.252002 2026-10-30 08:38:00.998 | HD Request # 2 | Using server: ds37.sierracharts.com port 10150 2026-10-30 08:38:01.005 | Socket (3) | Creating socket. 2026-10-30 08:38:01.006 | Socket (3) | New receive buffer size: 0 2026-10-30 08:38:01.006 | Socket (3) | Connecting to IP: 4.8.175.92 Port: 10150. 2026-10-30 08:38:01.573 | HD Request # 2 | Setting DTC encoding to Binary VLS 2026-10-30 08:38:01.573 | HD Request # 2 | Sending historical data logon request message. 2026-10-30 08:38:01.905 | HD Request # 2 | Requesting Intraday data. Start date-time: 2026-10-30 08:37:51. Record interval: 0. Symbol: ESZ26 2026-10-30 08:38:02.180 | HD Request # 2 | Decompressing data. 2026-10-30 08:38:02.455 | HD Request # 2 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-10-30 08:37:51.252000 2026-10-30 08:38:02.455 | Socket (3) | CloseSocket call. 2026-10-30 08:38:02.455 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-10-30 08:38:02.455 | Historical data download thread signaled to stop. 2026-10-30 08:38:02.455 | HD Request # 2 | Timestamp of first Intraday data file record written: 2026-10-30 08:37:52.175000. 2026-10-30 08:38:02.455 | HD Request # 2 | Received 30 Intraday data records from 2026-10-30 08:37:51.252000 to 2026-10-30 08:37:56.544004 (5.3 seconds. Delay: 5.9 seconds) and wrote 27 records for ESZ26_FUT_CME 2026-10-30 08:38:02.460 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2026-10-30 12:37:56.544004 2026-10-30 08:38:02.460 | Added 2 Time and Sales records to Intraday data file for ESZ26_FUT_CME after download. 2026-10-30 08:38:02.460 | HD Request # 2 | Completion time: 2s. 2026-10-30 08:38:02.460 | HD Request # 2 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 2 2026-10-30 08:38:02.460 | Real-time Intraday chart data file updates started for ESZ26_FUT_CME 2026-10-30 08:38:02.460 | Intraday chart data file opened for ESZ26_FUT_CME 2026-10-30 08:38:02.460 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2026-10-30 08:38:02.460 | Removing historical data download ID 2. 2026-10-30 08:38:02.460 | 2026-10-30 08:38:02.460 | No download requests in the queue to start downloads for. 2026-10-30 08:38:02.730 | Socket (3) | Socket gracefully closed by remote side. Socket close state=2 2026-10-30 08:38:02.730 | Socket (3) | Closed. 2026-10-30 08:38:03.199 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-10-30 08:38:04.121 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-11-27"}. Success=true 2026-10-30 08:38:04.203 | Opened cached Intraday file: D:\SierraChart USA - Copy - Phillip 1 - Updated - JP\Data\ESZ26_FUT_CME.scid. Thread ID: 12120 2026-10-30 08:52:37.545 | Saved Chartbook: SPX.Cht. Time: 0.0033 seconds. 2026-10-30 09:07:37.564 | Saved Chartbook: SPX.Cht. Time: 0.0038 seconds. 2026-10-30 09:22:37.196 | Saved Chartbook: SPX.Cht. Time: 0.0030 seconds. 2026-10-30 09:37:37.609 | Saved Chartbook: SPX.Cht. Time: 0.0030 seconds. 2026-10-30 09:43:12.199 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 09:48:04.198 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 | Number times message added: 1 2026-10-30 09:52:37.622 | Saved Chartbook: SPX.Cht. Time: 0.0029 seconds. 2026-10-30 09:54:13.124 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 10:07:16.238 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 2 | Number times message added: 2 2026-10-30 10:07:37.644 | Saved Chartbook: SPX.Cht. Time: 0.0029 seconds. 2026-10-30 10:07:51.313 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 10:08:05.241 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 10:09:40.326 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 10:11:50.857 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-10-30 10:13:24.744 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-10-30 10:17:13.576 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 10:22:37.651 | Saved Chartbook: SPX.Cht. Time: 0.0029 seconds. 2026-10-30 10:27:25.999 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Reloading chart. 2026-10-30 10:27:26.900 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 10:27:26.902 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Chart data loading complete. 2026-10-30 10:29:01.893 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-10-30 10:29:02.792 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 10:29:02.793 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-10-30 10:37:37.666 | Saved Chartbook: SPX.Cht. Time: 0.0031 seconds. 2026-10-30 10:52:37.690 | Saved Chartbook: SPX.Cht. Time: 0.0029 seconds. 2026-10-30 11:07:37.714 | Saved Chartbook: SPX.Cht. Time: 0.0031 seconds. 2026-10-30 11:08:08.154 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 11:10:02.857 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 | Number times message added: 1 2026-10-30 11:14:18.037 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Reloading chart. 2026-10-30 11:14:18.972 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 11:14:18.973 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Chart data loading complete. 2026-10-30 11:15:33.392 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 11:16:30.727 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-10-30 11:16:46.834 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 11:19:23.288 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-10-30 11:19:24.207 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 11:19:24.209 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-10-30 11:22:37.736 | Saved Chartbook: SPX.Cht. Time: 0.0032 seconds. 2026-10-30 11:29:26.111 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Reloading chart. 2026-10-30 11:29:27.017 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 11:29:27.018 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Chart data loading complete. 2026-10-30 11:30:07.567 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 11:30:12.838 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-10-30 11:30:13.762 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 11:30:13.764 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-10-30 11:30:24.013 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 11:30:35.446 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message added: 1 2026-10-30 11:37:37.757 | Saved Chartbook: SPX.Cht. Time: 0.0031 seconds. 2026-10-30 11:52:37.778 | Saved Chartbook: SPX.Cht. Time: 0.0032 seconds. 2026-10-30 12:07:37.790 | Saved Chartbook: SPX.Cht. Time: 0.0030 seconds. 2026-10-30 12:14:15.698 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Reloading chart. 2026-10-30 12:14:16.633 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 12:14:16.635 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Chart data loading complete. 2026-10-30 12:15:15.729 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Reloading chart. 2026-10-30 12:15:16.640 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 12:15:16.642 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Chart data loading complete. 2026-10-30 12:15:17.321 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-10-30 12:15:18.226 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 12:15:18.229 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-10-30 12:21:14.405 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 12:21:46.628 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 | Number times message added: 1 2026-10-30 12:22:37.817 | Saved Chartbook: SPX.Cht. Time: 0.0035 seconds. 2026-10-30 12:30:27.864 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 12:30:46.905 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 2 2026-10-30 12:37:37.844 | Saved Chartbook: SPX.Cht. Time: 0.0031 seconds. 2026-10-30 12:42:06.708 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 12:43:02.965 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-10-30 12:44:38.239 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-10-30 12:44:59.032 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 12:47:31.324 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message added: 3 2026-10-30 12:52:37.870 | Saved Chartbook: SPX.Cht. Time: 0.0036 seconds. 2026-10-30 13:07:00.578 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message added: 1 2026-10-30 13:07:06.950 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Reloading chart. 2026-10-30 13:07:06.951 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-10-30 13:07:06.951 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'. 2026-10-30 13:07:06.951 | Triggering next historical data download in queue. 2026-10-30 13:07:06.951 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Waiting for historical downloads to complete with the IDs: 3, 2026-10-30 13:07:06.951 | Removing historical data download ID 3. 2026-10-30 13:07:06.951 | HD Request # 3 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-10-30 13:07:06.955 | HD Request # 3 | Download start date-time: 2026-10-30 13:07:06.000000. File last date-time: 2026-10-30 13:07:06.001004 2026-10-30 13:07:06.955 | HD Request # 3 | Using server: ds32.sierracharts.com port 10149 2026-10-30 13:07:06.955 | Socket (3) | Creating socket. 2026-10-30 13:07:06.955 | Socket (3) | New receive buffer size: 0 2026-10-30 13:07:06.956 | Socket (3) | Connecting to IP: 69.39.70.248 Port: 10149. 2026-10-30 13:07:07.408 | HD Request # 3 | Setting DTC encoding to Binary VLS 2026-10-30 13:07:07.408 | HD Request # 3 | Sending historical data logon request message. 2026-10-30 13:07:07.677 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-10-30 13:07:06. Record interval: 0. Symbol: ESZ26 2026-10-30 13:07:07.901 | HD Request # 3 | Decompressing data. 2026-10-30 13:07:08.141 | HD Request # 3 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-10-30 12:07:04.174000 2026-10-30 13:07:09.707 | Socket (3) | CloseSocket call. 2026-10-30 13:07:09.707 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-10-30 13:07:09.707 | Historical data download thread signaled to stop. 2026-10-30 13:07:09.707 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-10-30 13:07:06.631000. 2026-10-30 13:07:09.707 | HD Request # 3 | Received 162235 Intraday data records from 2026-10-30 12:07:04.174000 to 2026-10-30 13:07:07.671000 (60.1 minutes. Delay: 2.0 seconds) and wrote 84 records for ESZ26_FUT_CME 2026-10-30 13:07:09.711 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-10-30 17:07:07.671000 2026-10-30 13:07:09.711 | Added 5 Time and Sales records to Intraday data file for ESZ26_FUT_CME after download. 2026-10-30 13:07:09.711 | HD Request # 3 | Completion time: 3s. 2026-10-30 13:07:09.711 | HD Request # 3 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 3 2026-10-30 13:07:09.711 | Real-time Intraday chart data file updates started for ESZ26_FUT_CME 2026-10-30 13:07:09.711 | Intraday chart data file opened for ESZ26_FUT_CME 2026-10-30 13:07:09.711 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2026-10-30 13:07:09.711 | Removing historical data download ID 3. 2026-10-30 13:07:09.711 | 2026-10-30 13:07:09.711 | No download requests in the queue to start downloads for. 2026-10-30 13:07:09.810 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-30 13:07:09.810 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Reloading chart. | Number times message added: 1 2026-10-30 13:07:09.931 | Socket (3) | Socket gracefully closed by remote side. Socket close state=2 2026-10-30 13:07:09.931 | Socket (3) | Closed. 2026-10-30 13:07:10.741 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 13:07:10.743 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Chart data loading complete. 2026-10-30 13:07:12.764 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 13:07:14.027 | Opened cached Intraday file: D:\SierraChart USA - Copy - Phillip 1 - Updated - JP\Data\ESZ26_FUT_CME.scid. Thread ID: 12120 2026-10-30 13:07:14.665 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-10-30 13:07:15.597 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-10-30 13:07:15.598 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. |
| [2026-10-30 17:30:58] |
and here is the ss for data inaccuracy, look at the delta value of the 4th last bar, (it is the 13:05 candle, where it happened)
| [2026-11-02 15:18:01] |
One more odd thing is that, I have one more installation of SC where I only use the CBOE index chart and constantly change the timeframes and nothing like this happens there. It only happens at the CME charts. |
| [2026-11-02 18:59:24] |
Just happened again at 13:57, Heres the log. Do yo find anything odd ? 2026-11-02 09:44:13.087 | Trade activity files set size: 461 2026-11-02 09:44:13.117 | Reading Internal Order ID file. 2026-11-02 09:44:13.118 | Reading Trade Orders file. 2026-11-02 09:44:13.118 | Reading Trade Positions file. 2026-11-02 09:44:13.118 | Reading Trade Account Data files. 2026-11-02 09:44:13.121 | Software version: 2980 64-bit 2026-11-02 09:44:13.122 | OpenGL enabled (NVIDIA Corporation/NVIDIA GeForce GTX 1650/PCIe/SSE2) 2026-11-02 09:44:13.122 | Primary Thread ID: 6984 2026-11-02 09:44:13.122 | Usage end date: 2027-01-03 2026-11-02 09:44:13.122 | Enabled for: Advanced Features 2. 2026-11-02 09:44:13.122 | Enabled for: Sierra Chart Historical Data Service. 2026-11-02 09:44:13.122 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-11-02 09:44:13.122 | Enabled for: Delayed Denali Exchange Data Feed. 2026-11-02 09:44:13.122 | Enabled for exchange2: CME 2026-11-02 09:44:13.122 | Enabled for exchange2: CBOE Global Indexes Main 2026-11-02 09:44:13.122 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-11-02 09:44:13.122 | Current selected Data/Trading service: Teton CME Routing 2026-11-02 09:44:13.122 | Custom symbol settings values: enabled 2026-11-02 09:44:13.122 | Chart Update Interval: 100 2026-11-02 09:44:13.122 | Intraday Data Storage Time Unit: 0 2026-11-02 09:44:13.122 | Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-11-02 09:44:13.122 | 2026-11-02 14:44:13 Local computer time in UTC 2026-11-02 09:44:13.122 | 2026-11-02 09:44:13 Local computer time in SC Time Zone 2026-11-02 09:44:13.122 | 2026-11-02 14:44:06 Server time in UTC 2026-11-02 09:44:13.122 | Local computer UTC time and Server UTC time difference: 6 seconds. 2026-11-02 09:44:13.122 | Notice: Your computer's clock is off by 6 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'. 2026-11-02 09:44:13.122 | Program path: D:\SierraChart USA - Copy - Phillip 1 - Updated - NZ\ 2026-11-02 09:44:13.122 | Data Files path: D:\SierraChart USA - Copy - Phillip 1 - Updated - NZ\Data\ 2026-11-02 09:44:13.123 | OS Version Number: 10.0 2026-11-02 09:44:13.123 | Locale Setting: C 2026-11-02 09:44:13.123 | Crash reporter started: true 2026-11-02 09:44:13.123 | 2026-11-02 09:44:13.123 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2026-11-02 09:44:13.244 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-11-02 09:44:13.526 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. Socket close state=2 2026-11-02 09:44:13.526 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-11-02 09:44:13.871 | Received 5 login tokens. 2026-11-02 09:44:14.096 | Symbol settings MD5 received. Request ID: 1. 2026-11-02 09:44:14.096 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2026-11-02 09:44:15.641 | Requested user files to download. 2026-11-02 09:44:16.372 | File to download: Alert triggered.wav. Action: 0 2026-11-02 09:44:16.373 | User files to download complete 2026-11-02 09:44:17.196 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Reloading chart. 2026-11-02 09:44:17.196 | 2026-11-02 09:44:17.196 | Teton CME Routing | Firm: Phillip Capital 2026-11-02 09:44:17.197 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11089 2026-11-02 09:44:17.197 | Starting DelayedDownloadMonitoringTimer 2026-11-02 09:44:17.197 | Starting HDTimeoutTimer 2026-11-02 09:44:17.197 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-11-02 09:44:17.197 | Triggering next historical data download in queue. 2026-11-02 09:44:17.197 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Waiting for historical downloads to complete with the IDs: 1, 2026-11-02 09:44:17.197 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-11-02 09:44:17.197 | DTC Client socket (1) | New receive buffer size: 0 2026-11-02 09:44:17.197 | DTC Client socket (1) | Connecting to IP: 216.200.108.154 Port: 11089. 2026-11-02 09:44:17.437 | ESZ26_FUT_CME [C] 60 Min #3 | Reloading chart. 2026-11-02 09:44:17.438 | ESZ26_FUT_CME [C] 60 Min #3 | Waiting for historical downloads to complete with the IDs: 1, 2026-11-02 09:44:17.478 | ESZ26_FUT_CME [C] 15 Min #4 | Reloading chart. 2026-11-02 09:44:17.478 | ESZ26_FUT_CME [C] 15 Min #4 | Waiting for historical downloads to complete with the IDs: 1, 2026-11-02 09:44:17.504 | ESZ26_FUT_CME [C] 60 Min #5 | Reloading chart. 2026-11-02 09:44:17.504 | ESZ26_FUT_CME [C] 60 Min #5 | Waiting for historical downloads to complete with the IDs: 1, 2026-11-02 09:44:17.547 | ESZ26_FUT_CME [C] 5 Min #2 | Reloading chart. 2026-11-02 09:44:17.547 | ESZ26_FUT_CME [C] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2026-11-02 09:44:17.557 | Removing historical data download ID 1. 2026-11-02 09:44:17.557 | Mapping ESZ26_FUT_CME to ESZ26. Service code: cme 2026-11-02 09:44:17.557 | Using symbol data fast lookup vector 2026-11-02 09:44:17.557 | HD Request # 1 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-11-02 09:44:17.558 | HD Request # 1 | Download start date-time: 2026-11-02 09:41:28.000000. File last date-time: 2026-11-02 09:41:28.394005 2026-11-02 09:44:17.558 | HD Request # 1 | Using server: ds32.sierracharts.com port 10150 2026-11-02 09:44:17.558 | Socket (2) | Creating socket. 2026-11-02 09:44:17.558 | Socket (2) | New receive buffer size: 0 2026-11-02 09:44:17.558 | Socket (2) | Connecting to IP: 69.39.70.248 Port: 10150. 2026-11-02 09:44:17.575 | Teton CME Routing | Network connection to server complete. 2026-11-02 09:44:17.575 | Teton CME Routing | Starting socket receive thread. 2026-11-02 09:44:17.575 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-11-02 09:44:17.993 | HD Request # 1 | Setting DTC encoding to Binary VLS 2026-11-02 09:44:17.993 | HD Request # 1 | Sending historical data logon request message. 2026-11-02 09:44:18.188 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-11-02 09:44:18.188 | Teton CME Routing | Sending logon request message. 2026-11-02 09:44:18.239 | HD Request # 1 | Requesting Intraday data. Start date-time: 2026-11-02 09:41:28. Record interval: 0. Symbol: ESZ26 2026-11-02 09:44:18.444 | Teton CME Routing | Received logon response. 2026-11-02 09:44:18.444 | Teton CME Routing | Server Name: SC DTC Server. Build=58073. 2026-11-02 09:44:18.444 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-11-02 09:44:18.444 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-11-02 09:44:18.444 | Teton CME Routing | Trading is supported. 2026-11-02 09:44:18.444 | Teton CME Routing | Order cancel and replace is supported. 2026-11-02 09:44:18.444 | Teton CME Routing | OCO Orders supported. 2026-11-02 09:44:18.444 | Teton CME Routing | Bracket Orders supported. 2026-11-02 09:44:18.444 | Teton CME Routing | MarketDepthIsSupported: 1 2026-11-02 09:44:18.444 | Teton CME Routing | Connection to server complete. 2026-11-02 09:44:18.444 | No download requests in the queue to start downloads for. | Number times message added: 4 2026-11-02 09:44:18.444 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-11-02 09:44:18.449 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-11-02 14:34:53.126252 2026-11-02 09:44:18.455 | HD Request # 1 | Decompressing data. 2026-11-02 09:44:18.648 | Updated verified funded futures trading account ending date to: 2026-12-02 14:44:18 2026-11-02 09:44:18.653 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=7PV5739 2026-11-02 09:44:18.683 | HD Request # 1 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-11-02 09:41:28.000000 2026-11-02 09:44:18.947 | Socket (2) | CloseSocket call. 2026-11-02 09:44:18.947 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-11-02 09:44:18.947 | Historical data download thread signaled to stop. 2026-11-02 09:44:18.947 | HD Request # 1 | Timestamp of first Intraday data file record written: 2026-11-02 09:41:28.498000. 2026-11-02 09:44:18.947 | HD Request # 1 | Received 9439 Intraday data records from 2026-11-02 09:41:28.000000 to 2026-11-02 09:44:17.409001 (2.8 minutes. Delay: 1.5 seconds) and wrote 9375 records for ESZ26_FUT_CME 2026-11-02 09:44:18.952 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2026-11-02 14:44:17.409001 2026-11-02 09:44:18.952 | HD Request # 1 | Completion time: 1s. 2026-11-02 09:44:18.952 | HD Request # 1 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 1 2026-11-02 09:44:18.952 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2026-11-02 09:44:18.952 | Removing historical data download ID 1. 2026-11-02 09:44:18.952 | 2026-11-02 09:44:18.952 | No download requests in the queue to start downloads for. 2026-11-02 09:44:18.952 | Historical data for ESZ26_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2026-11-02 09:44:18.958 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-11-02 09:44:18.958 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Reloading chart. 2026-11-02 09:44:18.994 | ESZ26_FUT_CME [C] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-11-02 09:44:18.994 | ESZ26_FUT_CME [C] 5 Min #2 | Reloading chart. 2026-11-02 09:44:18.996 | ESZ26_FUT_CME [C] 60 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-11-02 09:44:18.997 | ESZ26_FUT_CME [C] 60 Min #3 | Reloading chart. 2026-11-02 09:44:19.024 | ESZ26_FUT_CME [C] 15 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-11-02 09:44:19.025 | ESZ26_FUT_CME [C] 15 Min #4 | Reloading chart. 2026-11-02 09:44:19.040 | ESZ26_FUT_CME [C] 60 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-11-02 09:44:19.041 | ESZ26_FUT_CME [C] 60 Min #5 | Reloading chart. 2026-11-02 09:44:19.075 | ESZ26_FUT_CME/MESZ26_FUT_CME [C] 5 Min #1 | Reloading chart. 2026-11-02 09:44:19.107 | ESZ26_FUT_CME [C] 60 Min #3 | Reloading chart. 2026-11-02 09:44:19.108 | ESZ26_FUT_CME [C] 5 Min #2 | Reloading chart. 2026-11-02 09:44:19.136 | ESZ26_FUT_CME [C] 15 Min #4 | Reloading chart. 2026-11-02 09:44:19.148 | ESZ26_FUT_CME [C] 60 Min #5 | Reloading chart. 2026-11-02 09:44:19.163 | Socket (2) | Socket gracefully closed by remote side. Socket close state=2 2026-11-02 09:44:19.163 | Socket (2) | Closed. 2026-11-02 09:44:19.178 | Mapping ESZ26_FUT_CME to ESZ26. Service code: cme 2026-11-02 09:44:19.178 | Using symbol data fast lookup vector 2026-11-02 09:44:19.178 | Denali Data Feed | Starting real-time market data updates for: ESZ26_FUT_CME (ESZ26). ID: 1 Service code: cme 2026-11-02 09:44:19.178 | Denali Data Feed | Connecting to the server ds40.sierracharts.com. Port 443 2026-11-02 09:44:19.178 | Denali Data Feed | Requesting security definition data for: ESZ26_FUT_CME (ESZ26). ID: 1 2026-11-02 09:44:19.178 | Mapping MESZ26_FUT_CME to MESZ26. Service code: cme 2026-11-02 09:44:19.178 | Denali Data Feed | Starting real-time market data updates for: MESZ26_FUT_CME (MESZ26). ID: 2 Service code: cme 2026-11-02 09:44:19.178 | Denali Data Feed | Requesting security definition data for: MESZ26_FUT_CME (MESZ26). ID: 2 2026-11-02 09:44:19.178 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-11-02 09:44:19.178 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'. 2026-11-02 09:44:19.178 | Triggering next historical data download in queue. 2026-11-02 09:44:19.178 | Removing historical data download ID 2. 2026-11-02 09:44:19.178 | Delaying start of download for ESZ26_FUT_CME. 2026-11-02 09:44:19.179 | DTC Client socket (2) | Creating socket. 2026-11-02 09:44:19.179 | DTC Client socket (2) | New receive buffer size: 0 2026-11-02 09:44:19.179 | DTC Client socket (2) | Connecting to IP: 116.251.186.157 Port: 443. 2026-11-02 09:44:19.382 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ26_FUT_CME 2026-11-02 09:44:19.382 | Teton CME Routing | Setting external service identifier for symbol ESZ26_FUT_CME to 10252 2026-11-02 09:44:19.382 | Teton CME Routing | Received security definition for symbol ESZ26_FUT_CME 2026-11-02 09:44:19.382 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ26_FUT_CME 2026-11-02 09:44:19.382 | Teton CME Routing | Setting external service identifier for symbol MESZ26_FUT_CME to 42001581 2026-11-02 09:44:19.382 | Teton CME Routing | Received security definition for symbol MESZ26_FUT_CME 2026-11-02 09:44:19.426 | Denali Data Feed | Network connection to server complete. 2026-11-02 09:44:19.426 | Denali Data Feed | Starting socket receive thread. 2026-11-02 09:44:19.426 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-11-02 09:44:19.699 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-11-02 09:44:19.699 | Denali Data Feed | Sending logon request message. 2026-11-02 09:44:19.718 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 09:44:19.925 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-11-02 09:44:20.981 | ESZ26_FUT_CME [C][M] 15 Min #4 | Chart data loading complete. 2026-11-02 09:44:20.992 | ESZ26_FUT_CME [C][M] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2025-10-26 00:00:00 2026-11-02 09:44:20.999 | ESZ26_FUT_CME [C][M] 5 Min #2 | Chart data loading complete. 2026-11-02 09:44:21.103 | ESZ26_FUT_CME [C][M] 60 Min #5 | Chart data loading complete. 2026-11-02 09:44:21.107 | ESZ26_FUT_CME [C][M] 60 Min #3 | Chart data loading complete. 2026-11-02 09:44:21.391 | Denali Data Feed | Received logon response. 2026-11-02 09:44:21.391 | Denali Data Feed | Server Name: SC Realtime Server. 2026-11-02 09:44:21.391 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-11-02 09:44:21.391 | Denali Data Feed | Successfully connected. 2026-11-02 09:44:21.391 | Denali Data Feed | Trading is not supported. 2026-11-02 09:44:21.391 | Denali Data Feed | MarketDepthIsSupported: 1 2026-11-02 09:44:21.391 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ26_FUT_CME -> ESZ26 2026-11-02 09:44:21.391 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ26_FUT_CME -> MESZ26 2026-11-02 09:44:21.757 | Denali Data Feed | Setting external service identifier for symbol ESZ26_FUT_CME to 10252 2026-11-02 09:44:21.757 | Denali Data Feed | Received security definition for symbol ESZ26_FUT_CME 2026-11-02 09:44:21.757 | Denali Data Feed | Setting external service identifier for symbol MESZ26_FUT_CME to 42001581 2026-11-02 09:44:21.757 | Denali Data Feed | Received security definition for symbol MESZ26_FUT_CME 2026-11-02 09:44:26.264 | HD Request # 2 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-11-02 09:44:26.265 | HD Request # 2 | Download start date-time: 2026-11-02 09:44:17.000000. File last date-time: 2026-11-02 09:44:17.409001 2026-11-02 09:44:26.265 | HD Request # 2 | Using server: ds37.sierracharts.com port 10149 2026-11-02 09:44:26.265 | Socket (4) | Creating socket. 2026-11-02 09:44:26.265 | Socket (4) | New receive buffer size: 0 2026-11-02 09:44:26.265 | Socket (4) | Connecting to IP: 4.8.175.92 Port: 10149. 2026-11-02 09:44:26.816 | HD Request # 2 | Setting DTC encoding to Binary VLS 2026-11-02 09:44:26.816 | HD Request # 2 | Sending historical data logon request message. 2026-11-02 09:44:27.158 | HD Request # 2 | Requesting Intraday data. Start date-time: 2026-11-02 09:44:17. Record interval: 0. Symbol: ESZ26 2026-11-02 09:44:27.433 | HD Request # 2 | Decompressing data. 2026-11-02 09:44:27.708 | HD Request # 2 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-11-02 09:44:17.144000 2026-11-02 09:44:27.708 | Socket (4) | CloseSocket call. 2026-11-02 09:44:27.708 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-11-02 09:44:27.708 | Historical data download thread signaled to stop. 2026-11-02 09:44:27.708 | HD Request # 2 | Timestamp of first Intraday data file record written: 2026-11-02 09:44:18.251000. 2026-11-02 09:44:27.708 | HD Request # 2 | Received 283 Intraday data records from 2026-11-02 09:44:17.144000 to 2026-11-02 09:44:23.652001 (6.5 seconds. Delay: 4.1 seconds) and wrote 263 records for ESZ26_FUT_CME 2026-11-02 09:44:27.713 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2026-11-02 14:44:23.652001 2026-11-02 09:44:27.713 | Added 10 Time and Sales records to Intraday data file for ESZ26_FUT_CME after download. 2026-11-02 09:44:27.713 | HD Request # 2 | Completion time: 1s. 2026-11-02 09:44:27.713 | HD Request # 2 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 2 2026-11-02 09:44:27.713 | Real-time Intraday chart data file updates started for ESZ26_FUT_CME 2026-11-02 09:44:27.713 | Intraday chart data file opened for ESZ26_FUT_CME 2026-11-02 09:44:27.713 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2026-11-02 09:44:27.713 | Removing historical data download ID 2. 2026-11-02 09:44:27.713 | 2026-11-02 09:44:27.713 | No download requests in the queue to start downloads for. 2026-11-02 09:44:27.983 | Socket (4) | Socket gracefully closed by remote side. Socket close state=2 2026-11-02 09:44:27.983 | Socket (4) | Closed. 2026-11-02 09:44:28.139 | Opened cached Intraday file: D:\SierraChart USA - Copy - Phillip 1 - Updated - NZ\Data\ESZ26_FUT_CME.scid. Thread ID: 3708 2026-11-02 09:44:38.656 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-11-02 09:44:39.380 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-12-02"}. Success=true 2026-11-02 09:45:51.983 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-11-02 09:45:51.983 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'. 2026-11-02 09:45:51.983 | Triggering next historical data download in queue. 2026-11-02 09:45:51.983 | Removing historical data download ID 3. 2026-11-02 09:45:51.983 | HD Request # 3 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-11-02 09:45:51.984 | HD Request # 3 | Download start date-time: 2026-11-02 09:00:00.000000. File last date-time: 2026-11-02 09:45:51.371000 2026-11-02 09:45:51.984 | HD Request # 3 | Disabling Intraday chart updating for symbol. 2026-11-02 09:45:51.984 | HD Request # 3 | Using server: ds28.sierracharts.com port 10150 2026-11-02 09:45:51.987 | Socket (3) | Creating socket. 2026-11-02 09:45:51.987 | Socket (3) | New receive buffer size: 0 2026-11-02 09:45:51.987 | Socket (3) | Connecting to IP: 67.214.125.5 Port: 10150. 2026-11-02 09:45:52.426 | HD Request # 3 | Setting DTC encoding to Binary VLS 2026-11-02 09:45:52.426 | HD Request # 3 | Sending historical data logon request message. 2026-11-02 09:45:52.681 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-11-02 09:00:00. Record interval: 0. Symbol: ESZ26 2026-11-02 09:45:52.898 | HD Request # 3 | Decompressing data. 2026-11-02 09:45:53.127 | HD Request # 3 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-11-02 09:00:00.044000 2026-11-02 09:45:53.127 | HD Request # 3 | Truncating file to starting date-time of 2026-11-02 09:00:00.044. 2026-11-02 09:45:53.570 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-11-02 09:00:00.044000. 2026-11-02 09:45:54.436 | Socket (3) | CloseSocket call. 2026-11-02 09:45:54.436 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-11-02 09:45:54.436 | Historical data download thread signaled to stop. 2026-11-02 09:45:54.436 | HD Request # 3 | Received 106308 Intraday data records from 2026-11-02 09:00:00.044000 to 2026-11-02 09:45:50.639001 (45.8 minutes. Delay: 3.8 seconds) and wrote 106308 records for ESZ26_FUT_CME 2026-11-02 09:45:54.441 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-11-02 14:45:50.639001 2026-11-02 09:45:54.441 | HD Request # 3 | Completion time: 3s. 2026-11-02 09:45:54.441 | HD Request # 3 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 3 2026-11-02 09:45:54.441 | Real-time Intraday chart data file updates started for ESZ26_FUT_CME 2026-11-02 09:45:54.441 | Intraday chart data file opened for ESZ26_FUT_CME 2026-11-02 09:45:54.441 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2026-11-02 09:45:54.441 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Flagging to reload Intraday data on download completion. 2026-11-02 09:45:54.441 | ESZ26_FUT_CME [C][M] 60 Min #3 | Flagging to reload Intraday data on download completion. 2026-11-02 09:45:54.441 | ESZ26_FUT_CME [C][M] 15 Min #4 | Flagging to reload Intraday data on download completion. 2026-11-02 09:45:54.441 | ESZ26_FUT_CME [C][M] 60 Min #5 | Flagging to reload Intraday data on download completion. 2026-11-02 09:45:54.441 | ESZ26_FUT_CME [C][M] 5 Min #2 | Flagging to reload Intraday data on download completion. 2026-11-02 09:45:54.441 | Removing historical data download ID 3. 2026-11-02 09:45:54.441 | 2026-11-02 09:45:54.441 | No download requests in the queue to start downloads for. 2026-11-02 09:45:54.538 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-11-02 09:45:54.545 | ESZ26_FUT_CME [C][M] 15 Min #4 | Reloading chart. 2026-11-02 09:45:54.548 | ESZ26_FUT_CME [C][M] 60 Min #3 | Reloading chart. 2026-11-02 09:45:54.551 | ESZ26_FUT_CME [C][M] 5 Min #2 | Reloading chart. 2026-11-02 09:45:54.553 | ESZ26_FUT_CME [C][M] 60 Min #5 | Reloading chart. 2026-11-02 09:45:54.654 | Socket (3) | Socket gracefully closed by remote side. Socket close state=2 2026-11-02 09:45:54.654 | Socket (3) | Closed. 2026-11-02 09:45:55.294 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 09:45:55.296 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-11-02 09:45:56.311 | ESZ26_FUT_CME [C][M] 15 Min #4 | Chart data loading complete. 2026-11-02 09:45:56.330 | ESZ26_FUT_CME [C][M] 60 Min #5 | Chart data loading complete. 2026-11-02 09:45:56.331 | ESZ26_FUT_CME [C][M] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2025-10-26 00:00:00 2026-11-02 09:45:56.333 | ESZ26_FUT_CME [C][M] 5 Min #2 | Chart data loading complete. 2026-11-02 09:45:56.356 | ESZ26_FUT_CME [C][M] 60 Min #3 | Chart data loading complete. 2026-11-02 09:45:58.269 | Opened cached Intraday file: D:\SierraChart USA - Copy - Phillip 1 - Updated - NZ\Data\ESZ26_FUT_CME.scid. Thread ID: 3708 2026-11-02 09:50:44.266 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-11-02 09:50:44.266 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'. 2026-11-02 09:50:44.266 | Triggering next historical data download in queue. 2026-11-02 09:50:44.266 | Removing historical data download ID 4. 2026-11-02 09:50:44.266 | HD Request # 4 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-11-02 09:50:44.266 | HD Request # 4 | Download start date-time: 2026-11-02 09:00:00.000000. File last date-time: 2026-11-02 09:50:43.958000 2026-11-02 09:50:44.266 | HD Request # 4 | Disabling Intraday chart updating for symbol. 2026-11-02 09:50:44.266 | HD Request # 4 | Using server: ds32.sierracharts.com port 10149 2026-11-02 09:50:44.266 | Socket (3) | Creating socket. 2026-11-02 09:50:44.266 | Socket (3) | New receive buffer size: 0 2026-11-02 09:50:44.266 | Socket (3) | Connecting to IP: 69.39.70.248 Port: 10149. 2026-11-02 09:50:44.703 | HD Request # 4 | Setting DTC encoding to Binary VLS 2026-11-02 09:50:44.703 | HD Request # 4 | Sending historical data logon request message. 2026-11-02 09:50:44.958 | HD Request # 4 | Requesting Intraday data. Start date-time: 2026-11-02 09:00:00. Record interval: 0. Symbol: ESZ26 2026-11-02 09:50:45.175 | HD Request # 4 | Decompressing data. 2026-11-02 09:50:45.408 | HD Request # 4 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-11-02 09:00:00.044000 2026-11-02 09:50:45.408 | HD Request # 4 | Truncating file to starting date-time of 2026-11-02 09:00:00.044. 2026-11-02 09:50:46.062 | HD Request # 4 | Timestamp of first Intraday data file record written: 2026-11-02 09:00:00.044000. 2026-11-02 09:50:46.506 | Socket (3) | CloseSocket call. 2026-11-02 09:50:46.506 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-11-02 09:50:46.506 | Historical data download thread signaled to stop. 2026-11-02 09:50:46.507 | HD Request # 4 | Received 122984 Intraday data records from 2026-11-02 09:00:00.044000 to 2026-11-02 09:50:45.683007 (50.8 minutes. Delay: 0.8 seconds) and wrote 122984 records for ESZ26_FUT_CME 2026-11-02 09:50:46.512 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2026-11-02 14:50:45.683007 2026-11-02 09:50:46.512 | Added 10 Time and Sales records to Intraday data file for ESZ26_FUT_CME after download. 2026-11-02 09:50:46.512 | HD Request # 4 | Completion time: 2s. 2026-11-02 09:50:46.512 | HD Request # 4 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 4 2026-11-02 09:50:46.512 | Real-time Intraday chart data file updates started for ESZ26_FUT_CME 2026-11-02 09:50:46.512 | Intraday chart data file opened for ESZ26_FUT_CME 2026-11-02 09:50:46.512 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2026-11-02 09:50:46.512 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:46.512 | ESZ26_FUT_CME [C][M] 60 Min #3 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:46.512 | ESZ26_FUT_CME [C][M] 15 Min #4 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:46.512 | ESZ26_FUT_CME [C][M] 60 Min #5 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:46.512 | ESZ26_FUT_CME [C][M] 5 Min #2 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:46.512 | Removing historical data download ID 4. 2026-11-02 09:50:46.512 | 2026-11-02 09:50:46.512 | No download requests in the queue to start downloads for. 2026-11-02 09:50:46.526 | ESZ26_FUT_CME [C][M] 60 Min #3 | Reloading chart. 2026-11-02 09:50:46.529 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-11-02 09:50:46.535 | ESZ26_FUT_CME [C][M] 15 Min #4 | Reloading chart. 2026-11-02 09:50:46.537 | ESZ26_FUT_CME [C][M] 60 Min #5 | Reloading chart. 2026-11-02 09:50:46.545 | ESZ26_FUT_CME [C][M] 5 Min #2 | Reloading chart. 2026-11-02 09:50:46.723 | Socket (3) | Socket gracefully closed by remote side. Socket close state=2 2026-11-02 09:50:46.723 | Socket (3) | Closed. 2026-11-02 09:50:47.284 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 09:50:47.286 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-11-02 09:50:48.291 | ESZ26_FUT_CME [C][M] 15 Min #4 | Chart data loading complete. 2026-11-02 09:50:48.320 | ESZ26_FUT_CME [C][M] 60 Min #5 | Chart data loading complete. 2026-11-02 09:50:48.323 | ESZ26_FUT_CME [C][M] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2025-10-26 00:00:00 2026-11-02 09:50:48.328 | ESZ26_FUT_CME [C][M] 5 Min #2 | Chart data loading complete. 2026-11-02 09:50:48.338 | ESZ26_FUT_CME [C][M] 60 Min #3 | Chart data loading complete. 2026-11-02 09:50:48.719 | Opened cached Intraday file: D:\SierraChart USA - Copy - Phillip 1 - Updated - NZ\Data\ESZ26_FUT_CME.scid. Thread ID: 3708 2026-11-02 09:50:50.143 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-11-02 09:50:50.143 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'. 2026-11-02 09:50:50.143 | Triggering next historical data download in queue. 2026-11-02 09:50:50.143 | Removing historical data download ID 5. 2026-11-02 09:50:50.143 | HD Request # 5 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-11-02 09:50:50.143 | HD Request # 5 | Download start date-time: 2026-11-02 09:00:00.000000. File last date-time: 2026-11-02 09:50:49.339000 2026-11-02 09:50:50.143 | HD Request # 5 | Disabling Intraday chart updating for symbol. 2026-11-02 09:50:50.143 | HD Request # 5 | Using server: ds37.sierracharts.com port 10150 2026-11-02 09:50:50.143 | Socket (3) | Creating socket. 2026-11-02 09:50:50.143 | Socket (3) | New receive buffer size: 0 2026-11-02 09:50:50.143 | Socket (3) | Connecting to IP: 4.8.175.92 Port: 10150. 2026-11-02 09:50:50.711 | HD Request # 5 | Setting DTC encoding to Binary VLS 2026-11-02 09:50:50.711 | HD Request # 5 | Sending historical data logon request message. 2026-11-02 09:50:51.051 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-11-02 09:00:00. Record interval: 0. Symbol: ESZ26 2026-11-02 09:50:51.333 | HD Request # 5 | Decompressing data. 2026-11-02 09:50:51.625 | HD Request # 5 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-11-02 09:00:00.044000 2026-11-02 09:50:51.625 | HD Request # 5 | Truncating file to starting date-time of 2026-11-02 09:00:00.044. 2026-11-02 09:50:52.472 | HD Request # 5 | Timestamp of first Intraday data file record written: 2026-11-02 09:00:00.044000. 2026-11-02 09:50:53.049 | Socket (3) | CloseSocket call. 2026-11-02 09:50:53.049 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-11-02 09:50:53.049 | Historical data download thread signaled to stop. 2026-11-02 09:50:53.050 | HD Request # 5 | Received 123451 Intraday data records from 2026-11-02 09:00:00.044000 to 2026-11-02 09:50:52.282008 (50.9 minutes. Delay: 0.8 seconds) and wrote 123451 records for ESZ26_FUT_CME 2026-11-02 09:50:53.054 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2026-11-02 14:50:52.282008 2026-11-02 09:50:53.054 | Added 12 Time and Sales records to Intraday data file for ESZ26_FUT_CME after download. 2026-11-02 09:50:53.054 | HD Request # 5 | Completion time: 3s. 2026-11-02 09:50:53.054 | HD Request # 5 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 5 2026-11-02 09:50:53.054 | Real-time Intraday chart data file updates started for ESZ26_FUT_CME 2026-11-02 09:50:53.054 | Intraday chart data file opened for ESZ26_FUT_CME 2026-11-02 09:50:53.054 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2026-11-02 09:50:53.054 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:53.054 | ESZ26_FUT_CME [C][M] 60 Min #3 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:53.054 | ESZ26_FUT_CME [C][M] 15 Min #4 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:53.054 | ESZ26_FUT_CME [C][M] 60 Min #5 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:53.054 | ESZ26_FUT_CME [C][M] 5 Min #2 | Flagging to reload Intraday data on download completion. 2026-11-02 09:50:53.054 | Removing historical data download ID 5. 2026-11-02 09:50:53.054 | 2026-11-02 09:50:53.054 | No download requests in the queue to start downloads for. 2026-11-02 09:50:53.098 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-11-02 09:50:53.100 | ESZ26_FUT_CME [C][M] 60 Min #3 | Reloading chart. 2026-11-02 09:50:53.102 | ESZ26_FUT_CME [C][M] 5 Min #2 | Reloading chart. 2026-11-02 09:50:53.112 | ESZ26_FUT_CME [C][M] 60 Min #5 | Reloading chart. 2026-11-02 09:50:53.117 | ESZ26_FUT_CME [C][M] 15 Min #4 | Reloading chart. 2026-11-02 09:50:53.330 | Socket (3) | Socket gracefully closed by remote side. Socket close state=2 2026-11-02 09:50:53.330 | Socket (3) | Closed. 2026-11-02 09:50:53.731 | Opened cached Intraday file: D:\SierraChart USA - Copy - Phillip 1 - Updated - NZ\Data\ESZ26_FUT_CME.scid. Thread ID: 3708 2026-11-02 09:50:53.857 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 09:50:53.859 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-11-02 09:50:54.863 | ESZ26_FUT_CME [C][M] 60 Min #5 | Chart data loading complete. 2026-11-02 09:50:54.867 | ESZ26_FUT_CME [C][M] 15 Min #4 | Chart data loading complete. 2026-11-02 09:50:54.896 | ESZ26_FUT_CME [C][M] 5 Min #2 | StartDateTimeForLoadingOrderFills: 2025-10-26 00:00:00 2026-11-02 09:50:54.901 | ESZ26_FUT_CME [C][M] 5 Min #2 | Chart data loading complete. 2026-11-02 09:50:54.912 | ESZ26_FUT_CME [C][M] 60 Min #3 | Chart data loading complete. 2026-11-02 09:59:13.094 | Saved Chartbook: SPX.Cht. Time: 0.0039 seconds. 2026-11-02 10:02:13.881 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 10:04:08.034 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 10:10:17.453 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message added: 1 2026-11-02 10:14:13.112 | Saved Chartbook: SPX.Cht. Time: 0.0036 seconds. 2026-11-02 10:22:06.874 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message added: 4 2026-11-02 10:22:10.071 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Reloading chart. 2026-11-02 10:22:10.813 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 10:22:10.815 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Chart data loading complete. 2026-11-02 10:22:20.248 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-11-02 10:22:20.985 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 10:22:20.986 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-11-02 10:24:40.682 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 10:29:13.132 | Saved Chartbook: SPX.Cht. Time: 0.0035 seconds. 2026-11-02 10:44:13.156 | Saved Chartbook: SPX.Cht. Time: 0.0032 seconds. 2026-11-02 10:47:30.994 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 10:47:48.530 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 10:59:13.192 | Saved Chartbook: SPX.Cht. Time: 0.0033 seconds. 2026-11-02 11:05:00.224 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message added: 1 2026-11-02 11:14:13.212 | Saved Chartbook: SPX.Cht. Time: 0.0033 seconds. 2026-11-02 11:20:27.808 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 11:20:44.229 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 11:20:55.047 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message added: 1 2026-11-02 11:29:13.230 | Saved Chartbook: SPX.Cht. Time: 0.0032 seconds. 2026-11-02 11:32:41.411 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 11:33:44.341 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 | Number times message added: 1 2026-11-02 11:44:13.255 | Saved Chartbook: SPX.Cht. Time: 0.0031 seconds. 2026-11-02 11:51:47.530 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 11:59:13.285 | Saved Chartbook: SPX.Cht. Time: 0.0039 seconds. 2026-11-02 12:00:25.434 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 12:00:43.428 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 12:00:55.620 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 12:14:13.300 | Saved Chartbook: SPX.Cht. Time: 0.0041 seconds. 2026-11-02 12:21:43.859 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 12:24:54.923 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-11-02 12:25:05.553 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 12:25:06.352 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Reloading chart. 2026-11-02 12:25:07.121 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 12:25:07.123 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Chart data loading complete. 2026-11-02 12:25:09.782 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message added: 1 2026-11-02 12:25:16.625 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-11-02 12:25:17.400 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 12:25:17.402 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-11-02 12:29:13.324 | Saved Chartbook: SPX.Cht. Time: 0.0035 seconds. 2026-11-02 12:36:14.964 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 12:44:13.339 | Saved Chartbook: SPX.Cht. Time: 0.0033 seconds. 2026-11-02 12:59:13.367 | Saved Chartbook: SPX.Cht. Time: 0.0032 seconds. 2026-11-02 13:14:13.386 | Saved Chartbook: SPX.Cht. Time: 0.0034 seconds. 2026-11-02 13:23:24.442 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Reloading chart. 2026-11-02 13:23:25.219 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:23:25.220 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Chart data loading complete. 2026-11-02 13:23:27.537 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-11-02 13:23:28.316 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:23:28.318 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-11-02 13:25:18.604 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:25:35.042 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message added: 1 2026-11-02 13:25:44.028 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Reloading chart. 2026-11-02 13:25:44.829 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:25:44.832 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | Chart data loading complete. 2026-11-02 13:25:45.435 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:25:57.240 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Reloading chart. 2026-11-02 13:25:58.039 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:25:58.041 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | Chart data loading complete. 2026-11-02 13:25:59.918 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:26:58.301 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:27:26.822 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-11-02 13:28:02.951 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-11-02 13:28:35.552 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:29:13.403 | Saved Chartbook: SPX.Cht. Time: 0.0032 seconds. 2026-11-02 13:40:33.710 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:40:43.896 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 2 2026-11-02 13:44:13.421 | Saved Chartbook: SPX.Cht. Time: 0.0031 seconds. 2026-11-02 13:45:19.544 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:52:08.481 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 3 2026-11-02 13:53:58.477 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-11-02 13:57:07.933 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 | Number times message previously added: 1 2026-11-02 13:57:11.640 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Reloading chart. 2026-11-02 13:57:11.640 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-11-02 13:57:11.640 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'. 2026-11-02 13:57:11.640 | Triggering next historical data download in queue. 2026-11-02 13:57:11.640 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Waiting for historical downloads to complete with the IDs: 6, 2026-11-02 13:57:11.641 | Removing historical data download ID 6. 2026-11-02 13:57:11.641 | HD Request # 6 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-11-02 13:57:11.644 | HD Request # 6 | Download start date-time: 2026-11-02 13:57:10.000000. File last date-time: 2026-11-02 13:57:10.948000 2026-11-02 13:57:11.644 | HD Request # 6 | Using server: ds28.sierracharts.com port 10149 2026-11-02 13:57:11.646 | Socket (3) | Creating socket. 2026-11-02 13:57:11.646 | Socket (3) | New receive buffer size: 0 2026-11-02 13:57:11.646 | Socket (3) | Connecting to IP: 67.214.125.5 Port: 10149. 2026-11-02 13:57:12.102 | HD Request # 6 | Setting DTC encoding to Binary VLS 2026-11-02 13:57:12.102 | HD Request # 6 | Sending historical data logon request message. 2026-11-02 13:57:12.370 | HD Request # 6 | Requesting Intraday data. Start date-time: 2026-11-02 13:57:10. Record interval: 0. Symbol: ESZ26 2026-11-02 13:57:12.597 | HD Request # 6 | Decompressing data. 2026-11-02 13:57:12.842 | HD Request # 6 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-11-02 12:57:07.960000 2026-11-02 13:57:14.322 | Socket (3) | CloseSocket call. 2026-11-02 13:57:14.322 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-11-02 13:57:14.322 | Historical data download thread signaled to stop. 2026-11-02 13:57:14.322 | HD Request # 6 | Timestamp of first Intraday data file record written: 2026-11-02 13:57:11.288000. 2026-11-02 13:57:14.322 | HD Request # 6 | Received 132454 Intraday data records from 2026-11-02 12:57:07.960000 to 2026-11-02 13:57:11.466002 (60.1 minutes. Delay: 2.9 seconds) and wrote 19 records for ESZ26_FUT_CME 2026-11-02 13:57:14.327 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2026-11-02 18:57:11.466002 2026-11-02 13:57:14.327 | Added 1 Time and Sales records to Intraday data file for ESZ26_FUT_CME after download. 2026-11-02 13:57:14.327 | HD Request # 6 | Completion time: 3s. 2026-11-02 13:57:14.327 | HD Request # 6 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 6 2026-11-02 13:57:14.327 | Real-time Intraday chart data file updates started for ESZ26_FUT_CME 2026-11-02 13:57:14.327 | Intraday chart data file opened for ESZ26_FUT_CME 2026-11-02 13:57:14.327 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2026-11-02 13:57:14.327 | Removing historical data download ID 6. 2026-11-02 13:57:14.327 | 2026-11-02 13:57:14.327 | No download requests in the queue to start downloads for. 2026-11-02 13:57:14.450 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-11-02 13:57:14.450 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Reloading chart. 2026-11-02 13:57:14.549 | Socket (3) | Socket gracefully closed by remote side. Socket close state=2 2026-11-02 13:57:14.549 | Socket (3) | Closed. 2026-11-02 13:57:14.607 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Reloading chart. 2026-11-02 13:57:15.234 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 09:30:00 2026-11-02 13:57:15.236 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Chart data loading complete. 2026-11-02 13:57:17.183 | Opened cached Intraday file: D:\SierraChart USA - Copy - Phillip 1 - Updated - NZ\Data\ESZ26_FUT_CME.scid. Thread ID: 3708 |
| [2026-11-02 22:22:29] |
| Sierra_Chart Engineering - Posts: 25440 |
This is unusual: 2026-11-02 13:57:11.640 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Reloading chart.
It does not make sense that a historical data download is being done, just from changing the timeframe of chart bars.2026-11-02 13:57:11.640 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-11-02 13:57:11.640 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'. 2026-11-02 13:57:11.640 | Triggering next historical data download in queue. 2026-11-02 13:57:11.640 | ESZ26_FUT_CME/MESZ26_FUT_CME [C][M] 1 Min #1 | Waiting for historical downloads to complete with the IDs: 6, 2026-11-02 13:57:11.641 | Removing historical data download ID 6. 2026-11-02 13:57:11.641 | HD Request # 6 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-11-02 13:57:11.644 | HD Request # 6 | Download start date-time: 2026-11-02 13:57:10.000000. File last date-time: 2026-11-02 13:57:10.948000 2026-11-02 13:57:11.644 | HD Request # 6 | Using server: ds28.sierracharts.com port 10149 Attach that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-11-03 12:46:22] |
| Jimmyy - Posts: 358 |
I have attached it. The problem is not the that it goes to download when changing timeframe, i dont mind it. the problem is that when it does do that, the data then becomes inaccurate. So instead, i just tried to delete and download the data randomly at bars during live market and i still found that sometimes the data randomly becomes inaccurate, which i believe is because of fast market activity, microsecond trade(s) get missed while downloading which i think is because of brief interruption when it changes to downloading data. The data becoming inaccurate also happens when sometimes my internet completely disconnects and then reconnects. At this time SC completely loses connection and then reconnects and does the downloading of the chart and it is at this time too that the data becomes inaccurate. So i believe it is actually at the downloading part during live market (regardless of how it happens) where the data becomes inaccurate. Date Time Of Last Edit: 2026-11-03 15:00:22
Private File |
| [2026-11-03 23:31:54] |
The unnecessary download problem is solved. Update to version 2982. See if you still you have this inaccuracy problem but we really do not understand why there would be anything like that. Update: We think we might know what the inaccuracy could be from. What do you have this set to: Data/Trade Service Settings: Number of Stored Time and Sales Records (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) We want you to increase it to 10000. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-11-04 00:33:33
