Date/Time: Thu, 26 Nov 2026 04:33:49 +0000
SC version update to current version
View Count: 450
| [2026-05-14 04:44:14] |
| User359177 - Posts: 2 |
I am running SC version 2679 for the past 18 months since Sept, 2024. Teton order routing was installed Dec 2024. Are there any issues/precautions updating the platform to the current version?
| [2026-05-14 14:42:09] |
The one thing you should be aware of are changes to the MDI Windows (the chart and spreadsheet windows that are contained within the main Sierra Chart application). Refer to the following thread specifically: Notice: Solution to: Chart/Chartbook Tabs Visibility Issues, Portions of Chart Window Cut Off The following settings are specific to these new windows. Make note of the "MDI Child Window Minimize Method" if this is something you use. General Settings Window: Multiple Document Interface (MDI) and Custom Title Bar Settings (Global Settings >> General Settings >> GUI) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
