Date/Time: Thu, 26 Nov 2026 04:33:47 +0000
NQTV vs Normal Stock Ticker - Difference in CVD Pattern
View Count: 267
| [2026-05-14 01:43:52] |
| User794005 - Posts: 51 |
Hello, I have two pictures of the same ticker called DUOL. One has -NQTV at the end. I noticed that the CVD is different both. Is it possible to combine all the volume data into one ticker? |
| [2026-05-14 08:26:39] |
| Sierra_Chart Engineering - Posts: 25491 |
When it comes to Cumulative Delta, NASDAQ TotalView works very different. In a way it is perfectly accurate but it does not have all of the volume. DUOL already has all of the volume data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-14 08:27:59
| [2026-05-14 15:18:44] |
Refer to the following to understand the differences in these data: US Stock/Equities Consolidated Tape Data Feed Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Denali Exchange Data Feed: U.S. Equities Consolidated Tape with NASDAQ TotalView For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
