Date/Time: Thu, 26 Nov 2026 04:33:45 +0000
intraday data period september 2008 to november 2008.
View Count: 256
[2026-05-13 02:30:40]
Galmik - Posts: 44
Hi John!
Hope you are doing well! I would like to access data back to 2008 but i can go back till 2019. How do i bypass that? I want to backtest on 2 min candlebars, period September 2008 till November 2008 or from back then till today. Thank you for your time to answer
Kind Regards,
Michael
[2026-05-13 13:43:34]
What is the symbol for which you are wanting to do this?
[2026-05-13 14:22:10]
Galmik - Posts: 44
ES futures
[2026-05-13 15:33:58]
The data we have for ES starts on May 4, 2008. So you should not have an issue getting the data back that far.
Make sure you are setup as a Continuous Futures Contract and set the "Days to Load" high enough to get the data going back that far. Refer to the following:
Continuous Futures Contract Charts
Once you have a chart that has all that data, then you can set the "Data Limiting" to use the From/To options to set the specific dates for which you want to load the data.
