Date/Time: Thu, 26 Nov 2026 04:33:45 +0000
DTC NOT ACTIVE
View Count: 375
| [2026-05-11 10:07:54] |
| Abhinair00 - Posts: 1 |
Hello, I am connecting Sierra chart to global data feeds for NSE F&O.I subscribed to the data feed, but Sierra shows "DTC NOT ACTIVE" when connecting. Could you please guide. Thank you. |
| [2026-05-11 17:09:17] |
You are on the "Base Advanced" package. You can not connect to data (or trading) services on the "Base" packages. You would need to change to one of the "Advanced" packages to be able to get data from Global Data Feeds. Refer to the following for the information on the packages: Description of Service Packages and Pricing: Packages Refer to the following for the instructions on how to change your package: Sierra Chart Purchase and License Information: Changing Package In case you were not already following them, the instructions to connect to Global Data Feeds is here: Global Data Feeds (India) Data Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
