Date/Time: Thu, 26 Nov 2026 04:33:47 +0000
I'd like to manage a trade, but Sierra Chart won't let me log on.
View Count: 224
| [2026-05-11 06:42:03] |
| User359632 - Posts: 8 |
| [2026-05-11 07:22:17] |
| Sierra_Chart Engineering - Posts: 25491 |
Contact your broker immediately to manage your trade. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
