Date/Time: Thu, 26 Nov 2026 04:33:39 +0000
Cannot find label tab in drawings properties
View Count: 249
[2026-05-07 17:30:04]
JHunt - Posts: 13
I cannot see the label tab in the line properties, nor in the horizontal line/ray .
Screen shot attached:
What should I do?
imageScreenshot 2026-05-07 181531.jpg / V - Attached On 2026-05-07 17:29:10 UTC - Size: 94.19 KB - 113 views
[2026-05-07 18:21:27]
There is no "Label" tab for any drawings.
If you are referring to the "Text" tab, then refer to the following setting to define whether it shows or not:
Chart Drawing Tools: Display 'Text' Tab on Chart Drawing Properties Window (Global Settings >> Tool Settings >> General >> Shortcut Menu and Properties Window)
[2026-05-07 19:24:59]
JHunt - Posts: 13
Thanks , enabling that option activated what I needed :)
