Date/Time: Thu, 26 Nov 2026 04:33:40 +0000
Multi-Year Backtest Performance and Simulation Account Issues
View Count: 385
[2026-05-07 09:51:11]
User499597 - Posts: 5
I’m encountering issues with the auto-trade bar-based backtest when running longer periods (10+ years).
Context:
•  A separate simulation account is required for each year because processing all years together takes too long.
•  When loading 10+ years at once, after 2 years the backtest speed drops by roughly 50%, and it continues slowing down as the test progresses. However, this may be related to ACSIL complexity and bar counting, but I’m not sure.
•  A simulation account resets automatically when starting a new backtest, so a single account cannot be used across multiple years.
•  Drawdown statistics are incorrect because they reflect only the individual simulation accounts instead of the combined multi-year performance.
Questions:
1.  Is it possible to run a multi-year backtest using a single simulation account while the years are split/loaded after each other?
2.  Is it possible to disable chart visualization and everything unrelated to the backtest in order to improve speed and avoid deceleration?
3.  After more than 10 simulation accounts for each year, the trade log order becomes inconsistent (e.g. the 10th year appears after the 2nd). How can this be solved?
Thank you.
Private File
[2026-05-07 14:29:52]
1. We are not fully understanding the process you are using in this case. If you are running separate backtests for each year, then you should be able to use the same trading account for each backtest.
2. You can always turn off the display of the bars and hide any studies you do not want to see. Refer to the following:
Chart Menu: Graph Draw Types (Chart menu)
Chart Studies: Settings and Inputs Tab >> Hide Study
3. There is no solution to this. This is due to way computers put items in alphabetical order. So you are seeing the items that start with 1s first (i.e. 1, 10, 11, 12, 2, 21, 22, 23...).
[2026-05-07 19:14:25]
1.  Using data range
a. Load 2016.01.01–2016.12.31 – Testing with Sim1.
b. Load 2017.01.01–2017.12.31 – When I press “Start Auto Trade,” it says “Clear trade data for Sim1,” but I want to keep the 2016 Sim1 data and continue building the trade log using the same Sim1 account for 2017.
I need to have one continuous trade log covering all years, so I don’t have to export trade logs from different Sim accounts to Excel and manually merge them into one coherent, continuous format.
Thank you.
[2026-05-07 20:45:18]
You would have to use the Manual Replay Backtesting in order to have Sim1 accumulate all the trades over the entire time. Refer to the following:
Auto Trade System Back Testing: Replay Back Testing - Manual
Note that the information in Step #8 in the above is not correct. You will be prompted for whether you want to clear the data or not. If you do not, then you can accumulate the trades for the Sim1 account.
[2026-05-08 09:19:39]
I think many ACSIL developers would highly appreciate it if Sierra could solve this — both for Auto Trade bar-based systems and for the scanner version as well.
Regarding Replay: it’s just unmanageable to run a couple of decades of data at speeds below 50x. In practice, the data has to be split into smaller periods, such as months. Above 50x speed, trades are no longer accurate, as I experienced.
Also, it would be great if the Trade Activity Log could be arranged by time instead of SIM account number.
These improvements could make algo performance research easier.
By the way, thanks for the effort put into building such a great platform.
