Date/Time: Thu, 26 Nov 2026 04:33:39 +0000
How does Sierra Chart use WinUI?
View Count: 342
[2026-05-07 08:51:27]
Daniel - Backtesting.club - Posts: 177
I would like to know how Sierra Chart works with WinUI.
I know that the appearance of certain elements, such as the main menu bar, scrollbars, and some menus, is controlled via WinUI. However, when I switch to dark mode in Windows, these elements remain light, whereas in other applications they turn dark.
I’m curious to know why this is the case. Thank you.
[2026-05-07 13:28:17]
Sierra_Chart Engineering - Posts: 25491
We were not sure what this is. And we looked it up. Sierra Chart does not use WinUI.
Date Time Of Last Edit: 2026-05-07 13:28:52
[2026-05-07 14:06:39]
If Sierra Chart doesn't use WinUI 3, how are the elements pointed to by my arrows in the screenshot created? It doesn't appear that the Win32 API is being used for this.
I'm asking because I'm trying to customize the platform's colors, but I can't achieve everything I want by editing the Windows registry.
For example, if I change the MenuBar's color, nothing happens. Other elements can be customized.
imageElements.jpg / V - Attached On 2026-05-07 13:51:26 UTC - Size: 1.28 MB - 148 views
