Date/Time: Thu, 26 Nov 2026 04:21:42 +0000
Can't move my Stop manually on the DOM
View Count: 323
| [2026-04-30 04:40:15] |
| User672758 - Posts: 8 |
Hi Sierra Chart, I am a new user. When trading on Sim, I was able to set up an ATM on the DOM with a stop to breakeven that I could manually trail on the DOM. I am using SC data and trading with Rithmic (Broker is Apex) and when the stop moves to breakeven (breakeven +2-10 depending on range bar size) the stop seems fixed. I would like to be able to manually trail it. Is there a setting that I am missing? Thank you Date Time Of Last Edit: 2026-04-30 14:21:37
| [2026-04-30 14:24:03] |
There is no reason you should not be able to move the Stop manually. There are no settings that prevent this. Our guess is that the move is being rejected by Rithmic for some reason. When you have this issue, look in your "Trade >> Trade Service Log" and see if there is any information there from Rithmic regarding a rejection of the move. If you want, you can post the information from your Trade Service Log to this thread for us to look at. -- Be aware that this is a public forum, so please do not post any personal information. We removed your name and phone number from your post. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-30 14:24:48
| [2026-05-02 00:49:33] |
l found the reason I could not trail my stop: I had not detached the chart window from the DOM! I can only trail my stop manually on the DOM in either SIM or my Rithmic account when I detach the Trade Window.
| [2026-05-03 20:58:13] |
| Sierra_Chart Engineering - Posts: 25489 |
This does not make sense and could not be the cause of the issue : I can only trail my stop manually on the DOM in either SIM or my Rithmic account when I detach the Trade Window.
One potential reason for the issue is that Trade >> Chart Trade Mode On was not enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-03 20:58:28
