Date/Time: Thu, 26 Nov 2026 04:21:40 +0000
How to make smaller or get rid of entirely
View Count: 294
[2026-04-29 14:52:29]
User930239 - Posts: 12
So couple questions:
The bottom section for the deltas is waaay too large. How can i minimize the size so that it takes up less space. There is so much unnecessary spacing between the numbers.
Number 2, my Time and Sales chart overlays everything. And I cannot move it around. Its stuck where it is and I can only resize in left to right in order to move it around.
imageScreenshot 2026-04-29 075007.png / V - Attached On 2026-04-29 14:50:35 UTC - Size: 382.5 KB - 119 views
[2026-04-29 17:08:51]
Refer to the following for how to change the size of a region:
Working With Charts: Chart Window and Regions
Your Time and Sales window does not have the "Title Bar" displayed, which is why you can not grab it to move it around. On the Time and Sales Window, select "Settings >> Settings Window". Then on that window set the option for "Show Title Bar" to "Yes" (or enable it, depending on the version you are running).
