Date/Time: Thu, 26 Nov 2026 04:21:36 +0000
Chart Alerts
View Count: 282
| [2026-04-29 13:55:55] |
| Jaydtrade - Posts: 125 |
I am trying to get an easy way to set alerts on my chart when price touches the exact price. Ive been using horizontal line drawing and setting alert on it. However sometimes it fires sometimes it doesnt. I dont know if its because I just copy the same horizontal line drawing and set it other places or what but I need help figuring this out.
| [2026-04-29 16:35:09] |
One option is to use a Symbol Alert rather than a Drawing Alert. Refer to the following: Alerts Manager: Symbol Alerts If you want to use the Drawing Alert, then how do you have the options setup for that alert? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
