Date/Time: Thu, 26 Nov 2026 04:21:36 +0000
Sierrachart Plays OrderEvent Alert Sounds from all SubInstances instead of one.
View Count: 306
[2026-04-29 13:01:42]
User629079 - Posts: 15
At the beginning, some introduction to know what I am talking about.
My configuration is:
Main_Instance: do nothing
Sub_Instance_2: Crude Oil charts only
Sub_Instance_3: Gold charts only
Sub_Instance_4: Dow Jones charts only
Sub_Instance_5: Russel charts only
Additionally, for all Sub_Instances, I use "Play Alerts ..." for OrderEvents like: "Play Alert When Order Rejected"
(Menu->Trade->General Trade Settings->Notifications)
In Sub_Instance_2 I have alert "Play Alert When Order Rejected": Alert 24. Where Alert 24 has sound "Order Rejected for Crude.wav"
In Sub_Instance_3 I have alert "Play Alert When Order Rejected": Alert 24. Where Alert 24 has sound "Order Rejected for Gold.wav"
In Sub_Instance_4 I have alert "Play Alert When Order Rejected": Alert 24. Where Alert 24 has sound "Order Rejected for Dow Jones.wav"
In Sub_Instance_5 I have alert "Play Alert When Order Rejected": Alert 24. Where Alert 24 has sound "Order Rejected for Russel.wav"
The Problem and my Question are:
When I place an Order for Gold(Sub_Instance_3). And this Order is Rejected. Then I hear all 4 sounds instead of "Order Rejected for Gold.wav" only!
What should I do/change to hear sound only from Sub_Instance_3(from SubInstance where order was placed), and not to hear from all for SubInstances?
Why OrderRejection is received by all SubInstances if Order was placed only in one SubInstance?
My understanding of the flow of OrderPlacing is as follow:
Sub_Instance_3(Gold) sends PlaceOrder to Main_Instance.
Main_Instance sends PlaceOrder(Gold) to Outside(Broker, Exchange).
From Outside comes Message(OrderRejected) to Main_Instance.
Main_Instance forward this Message(OrderRejected) to all SubInstances, not to only Sub_Instance_3(Gold) from which PlacingOrdger was originated.
Anyway, still my question is: how to change my settings to achieve that Order Messages related to Sub_Instance_X comeback to Sub_Instance_X only?
[2026-04-29 13:41:59]
Sierra_Chart Engineering - Posts: 25489
There is a misunderstanding about how these Order Alerts work. You cannot accomplish what you want to do.
An order update is provided to all sub instances and Order Alerts are not specific to an individual symbol.
There simply is not a way to do what you want, using the built-in alert functionality.
[2026-04-29 15:38:12]
Maybe following solution. I am not sure if it is relevant and possible.
Please let me know:
Is it possible to use different TradeAccount for each SubInstance?
And if Yes, will it help to solve this problem?
[2026-04-29 22:01:13]
Yes that can be used to solve the problem since there is a way to filter out alerts based on the Trade Account.
Date Time Of Last Edit: 2026-04-29 22:01:30
[2026-04-30 08:20:23]
I use:
Teton CME Routing [trading]
Clearing Firm: AMP
Where should I ask to create SubTradeAccounts?
Should I ask AMP Futures? (With their web control panel).
or
Should I ask SierraChart with web Account Control Panel?
When already, I will have 4 SubTradeAccounts (1 SubTradeAccount for each of 4 SubInstances):
How/Where in SierraChart Settings setup each SubInstance for placing order with particular SubTradeAccount?
How/Where to setup in Main Instance?
[2026-04-30 14:27:01]
To add additional accounts with your brokerage, you need to talk to your broker. It does not matter that you are using Teton, this is done through your broker.
To select a specific trading account, refer to the following:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
