Date/Time: Thu, 26 Nov 2026 04:21:44 +0000
Sound Alert on Chart Drawing - Extended Rextangle - over CHarts different Time Frames
View Count: 231
| [2026-04-29 08:05:58] |
| User683382 - Posts: 5 |
Hello Guys, i cant make it work the way i want: I draw extended Rectangles in my Analysis Charts which are Montly weekly and daily TPO with 1h - 30 min and 10 min. TPOs. I execute in a 1 min. CHart. I want the sound alert from the rectangle which i draw in the higher time frame to get triggered every time a new 1 min. candle touches or is within the Extended Rectangle. I use different tool configs for the extended rectangle to have different coloured zones. weirdly soem of tehm produce the alert and some never. All have the same sound alert settings an alert sound for drawing is set on. the ones workoing only produce the sound alert on every 1 min candle when i draw it in the 1 min chart. This is very time consuming because i have to scroll and readjust to find teh right place from the higher time fraem in the 1 mnin chart. Cost me 15 min everyday which could be 2 min when the drawings from the higher tame frame would work the weway i want in the 1 min chart. Is there a solution to get the trigger in every 1 min candle? is there something i might have not looked at to make all chart drawing alerts work? Appreciate any feedback |
| [2026-04-29 16:52:58] |
Chart Drawing Alerts are only determined on the chart that has the original drawing. If you copy the drawing to another chart, and setup an alert on that copied chart, it will only apply on the source chart. But if you are wanting an alert when price touches the rectangle, then it does not matter what the timeframe of the chart is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
