Date/Time: Thu, 26 Nov 2026 04:33:44 +0000
Getting accurate info for MES but not ES
View Count: 409
| [2026-04-28 16:01:49] |
| User558370 - Posts: 26 |
For the study Prev. Value Area (Volume Area Lines) to have pVPOC displayed on my chart, I get accurate data only if MESm26 is the symbol with Continuous Futures Contract - Volume Based Rollover, Back Adjusted However when I use ESM26, I do not get the accurate pVPOC (it is about 10 points higher) I have tried various fields in the Continuous Contract (List) to no avail. I would like to have ES charts as they have more volume... please advise as to what I need to adjust. Thank you. |
| [2026-04-28 18:01:43] |
Why do you state that Previous Volume Point of Control for ES that is different from MES is wrong? These are two different products, so they could have these differences.
| [2026-04-28 18:15:20] |
If both their values are the same, ie, they're both showing 7163, why should the pVPOC have a 10 point difference? The values on Monday, where the pVPOC is derived from, are the same as well. MES is showing pVPOC is 7195 --- which is correct. ES is showing pVPOC is 7206, which is incorrect. It appears ES is not extracting data from the previous day, which correctly shows pVPOC at 7195. I've attached screenshots - ES has the correct value on the previous day, but not today. |
| Attachment Deleted. |
| [2026-04-28 18:52:35] |
Please get us those charts so we can take a look. But chances are that these are correct values. The trading on these two product is similar, but not exactly the same. So there can/will be differences between them. Refer to the following for how to get us the charts - ignore the fact that it asks for only 1 chart - we need the two of them: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-07 16:41:24] |
I've attached the two charts to a new chartbook. 1 is MES and 1 is ES. As you can see the pdVPOC is vastly different. This affects the pVAH and range. |
| [2026-05-07 17:44:19] |
A few items of note: - Your session times are different between the two charts. You would need these to have exactly the same Regular Trading Hours (day session) times for proper comparison. - We do not know what your Global Time Zone is set to, but one chart has the Time Zone set to "Chicago" and the other uses the Global Time Zone. So if the Global Time Zone is not Chicago, then this will also change the underlying data. But, having said this, we checked what we get from the "Volume Value Area Lines" study, setup exactly as you have it (i.e. we saved a Study Collection from your study and applied it to our own charts) and we see the following values showing in today's lines (i.e. the previous day's day session Point of Control): - ES M 2026 contract: 7387.75 - MES M 2026 Contract: 7365.00 So there is a differences in the Point of Control values between ES and MES. As we originally stated, these are two different contracts with different volumes and prices. They trend together, but they are not exactly the same. So you should NOT expect to have the exact same point of control. Also, we added our Volume by Price study to the charts and set it to have day only profiles. Looking at the Point of Control from that study gave the exact same values as the Volume by Price study. We have absolutely no reason to believe our calculations are incorrect for these studies. What you are seeing is normal. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
