Date/Time: Thu, 26 Nov 2026 04:21:41 +0000
TPO chart question
View Count: 373
[2026-04-25 16:14:12]
User922418 - Posts: 42
I am using a TPO - Period 1 Days chart. I have it set to load the prior 14 days.
I have this chart split into two times zones: 6PM ET to next day 9:29:59AM. 9:30AM to 4:59PM.
One of my studies in this chart, I am using DAILY OHLC - single point to draw a horizontal line, which then displays the 9:30AM open number. This is good. This isn't the problem.
I want to have a horizontal line in my chart to also display (with a horizontal line too) the 6PM open print too. BUT, I can't figure this out. In my same TPO chart, I have another study, OHLC|0 ms|Calcorder 7. This shows a horizontal line which matches another chart on my chartbook for the 6PM open number. All I want is to have two different open numbers on this TPO split time zone chart.
How do I get the 6PM open line to display the number?
Thanks for your help
[2026-04-27 15:13:40]
We assume that your Session Times are set as the following:
Day Session: 09:30 - 16:59
Evening Session: 18:00 - 09:29:59
As such, you would need another chart for the same symbol, but without the TPO on it. Put another Daily OHLC study on that chart and set the following in that study (set other items as you want):
- Use Day Session Only: Yes
Then use the Study/Price Overlay to overlay that Daily OHLC to the TPO Chart.
Refer to the following:
Daily OHLC
Study/Price Overlay Study
[2026-04-27 15:17:35]
Thanks John
