Date/Time: Thu, 26 Nov 2026 04:11:43 +0000
DOM ATM sells after 1 poing in profit
View Count: 281
| [2026-04-24 14:32:24] |
| User672758 - Posts: 8 |
Hi Sierra, I am trading through Rithmic but I am using SC and Denali data. Today I set up a DOM with ATM on a 19 Range ES. The target is 45 ticks and the stop is 25 ticks. It is set to trade on Limit orders the OCO group is set to 1, I am using attached orders and trading 1 contract of ES in SIM I have it set to move to breakeven plus 5 ticks after it hits a profit of 10 ticks. It is liquidating my trade after 1 point in profit! Thanks in advance for your guidance in this. |
| [2026-04-24 15:25:59] |
You would need to look at the information in your Trade Activity Log to see what caused that position to be closed when it was. If one of the attached orders caused this, then you will see that in there. Refer to the following: Trade Activity Log Analysis: Determining the Origin of a New/Modified Order You can also check the "Trade >> Trade Service Log" and see if there is some kind of rejection or some other error that may be related to the position. In this case, you would need to check with your broker on what happened. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
