Date/Time: Thu, 26 Nov 2026 04:11:40 +0000
Downloading Intradday Data from 2019 onwards - what is the best way
View Count: 383
[2026-04-23 03:53:33]
User669167 - Posts: 4
I have a Data of NQ from 2024... now i want to pull from 2019.... somehow i did some setting yesterday, my data got corrupted.. i was doing
-> Edit > Edit/Download Data Intraday...
than i also tried Delete all data and download...
can someone guide me correct way, so i dont lose any data, and it just pulls from 2019 and adjusts it.... thanks...
[2026-04-23 13:30:30]
What do you mean by "adjusts it"?
To get the data for a futures symbol into a single chart going back through multiple contracts, you need to use the "Continuous Futures Contract" option. Refer to the following:
Continuous Futures Contract Charts
If you think you may have messed with the data and want to undo whatever was done, then select "Edit >> Delete All Data and Download". If you have the Continuous Futures Contract setup for that chart, then you will be asked which contracts you want to redownload; otherwise, it will delete all the data for the contract you have loaded and redownload it.
[2026-04-23 16:16:03]
How can i select that like i need data to be downloaded from 2019 onwards....
Do i need to first put the number in Days to Load for Intraday Charts and than Edit >> Delete All Data and Download ?
Suppose i have workings , analysis done on that chart... will those stay when the data is re-downloaded again?
[2026-04-23 17:31:27]
Is this for Futures data or for Equites? What is one symbol for which you are wanting to do this?
