Date/Time: Thu, 26 Nov 2026 04:11:45 +0000
CME Non-Professional Data Eligibility with Small Broker Balance
View Count: 685
| [2026-04-18 11:40:46] |
| User598772 - Posts: 1 |
Hello, I am using Sierra Chart and planning to subscribe to CME non-professional data (Level 1). I would like to confirm: If I connect a Tradovate account with a small balance (around $10–$50), will I still be eligible for real-time CME data through Denali? Or is there a minimum balance requirement to maintain real-time data access? Thank you. |
| [2026-04-18 19:00:03] |
| Sierra_Chart Engineering - Posts: 25489 |
No, for two different reasons: I would like to confirm: If I connect a Tradovate account with a small balance (around $10–$50), will I still be eligible for real-time CME data through Denali? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-18 21:50:03
| [2026-04-18 21:49:44] |
For a solution to this, refer to: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-18 21:49:54
