Date/Time: Thu, 26 Nov 2026 04:11:47 +0000
NYMEX Energy Calendars - CL / RBOB / HO
View Count: 317
| [2026-04-17 10:21:00] |
| User758540 - Posts: 4 |
I tried pulling up NYMEX exchange traded spreads but isnt giving me the option to open. Where can I get calendar spreads for each of CL / RBOB / HO? Thanks |
| [2026-04-17 13:19:43] |
We are not seeing any issues with getting the exchange traded spreads. What exactly do you mean "isnt giving me the option to open"? Are you not getting the list of spreads? Are you not able to select one? Are you not able to get any data? The instructions to pull up the spread symbols when connected to an external trading service is here: Denali Exchange Data Feed: Denali Exchange Traded Spread Data with Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-17 14:09:11] |
I can get the list of spreads but when try opening one on either chart or DOM it is blank; in chart it says dont have data...
| [2026-04-17 14:59:59] |
Please give us one symbol for which you have this issue.
