Date/Time: Thu, 26 Nov 2026 04:11:48 +0000
Information regarding spread sheet study.
View Count: 341
[2026-04-16 15:39:02]
User752704 - Posts: 2
Hi Team,
I an having trouble in using Spreadsheet study and need some more
information.
While my study displays Single prints and VAH and VAL and POC but when i
add Spreadsheet study to my chart it writes the values as 0.
Could you please help with this? I need to get the values of my visual
representation into Spreadsheet or if they can be pulled through DTC
Protocol.
Thanks and Regards
[2026-04-16 15:58:06]
Since you reference Single Prints, we assume that you are referring to the information for a TPO.
None of the data you are looking for is directly available from the TPO study itself. The Subgraphs for those items are just to define the colors and/or sizes for the display.
You can get the VAH, VAL, and POC information by using another chart and using the "TPO Value Area Lines" study. If you then need that information in the TPO chart where the Spreadsheet Study is located, in order to get the data into the Spreadsheet Study, then use the "Study/Price Overlay" to get the information to the TPO chart. You can hide the Study/Price Overlay. Refer to the following:
Study/Price Overlay Study
The Single Prints information is not available in any fashion.
[2026-04-17 08:06:46]
Hi Team,
Could you please confirm if we can use ASCIL code to extract all these values.
If i write a custom study are there any system defined global variables that can be used for extracting them without study overlays.
Regards
Srikanth
[2026-04-17 13:08:28]
Using ACSIL, you can get the POC, VAH, and VAL price levels. Refer to the following:
ACSIL Interface Members - Functions: sc.GetStudyProfileInformation
