Date/Time: Thu, 26 Nov 2026 04:01:31 +0000
Trade Window &
View Count: 465
| [2026-04-13 18:39:10] |
| JoeThanksG - Posts: 33 |
I apologize to start!! As you know, Sierra Charts is a little intense with the million settings!!!! But the truth is, That's the reason I'm falling in love with Sierra!!! I could completely customize almost everything, "Amazing" I need the help from your amazing brain (The smart people "programmers") I've tried going through Sierra chart documents, Self-support, Google ( I normally find everything in Google) "when I get stuck" How do I re-organize my (Bracket Order) I don't know if I'm saying this right. What I'm trying to find is how do I change the position up or down of my (Bracket Orders) For Different situation in the market, I use different (Bracket Orders) I would like to be able to move the position of my (Bracket Orders) in the "Trade Window" I know there has to be a way to organize the (order of my Bracket Orders) See attached screenshot |
| [2026-04-13 18:58:13] |
I'm still stuck, can't figure out how to re-organize my (Bracket Orders) in the "Trade Window" |
| [2026-04-13 19:00:30] |
The items you are referencing are the "Trade Configurations". The order of the items in that list in the Trade Window is by Alphabetical Order. So the only way to get them in a certain order is to change the names such that you have what you want first and so on. You can either re-save the configurations to new names or you can change the names through the file system. The names are the names of the files. The Trade Configuration files have an extension of .twconfig and are in the "Data" folder under your main Sierra Chart installation folder. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-13 19:14:06] |
John Thank You !!! I didn't know this. This knowledge will help me! Now I know how to organize my Bracket Orders Best wishes to you, Joe V PS. It would be much easier if you guys just put an Up & Down arrow in the (Trade Window Configuration) something to think about |
| [2026-04-13 19:21:43] |
| Mercrastius - Posts: 73 |
I suspect you'll be better off creating a custom control bar with buttons for each of your trade window configurations. Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings) Control Bar: Control Bar Trade Window Configuration Buttons Clicking one button will be much easier/faster/less likely to mis-click than using the dropdown, and it won't matter what order they are in the list. |
