Date/Time: Fri, 17 May 2024 22:05:17 +0000
Charting queries
View Count: 842
[2014-10-28 05:15:58] |
User33774 - Posts: 1 |
Hello Can you please guide me on the two issues I have mentioned on my attached file..? Thanks. |
Sierra Charts.pptx - Attached On 2014-10-28 05:15:37 UTC - Size: 445.59 KB - 325 views Attachment Deleted. |
[2014-10-28 17:59:08] |
1. The reason you see the Profit/Loss is -40 Ticks is because of the 5 contracts. There are other formats available including the currency value. Refer to Position Profit /Loss here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ProfitLossDisplay 2. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOMPositionPLColumn Also, it is easiest if you just attach chart images by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
