Date/Time: Tue, 20 Oct 2026 18:29:32 +0000
Reloading the intraday charts
View Count: 429
[2026-04-10 09:50:15]
gigi71 - Posts: 6
Dear Support,
I made 4 days pause, when I came back I am experiencing some troubles.
After 5 minutes and even with simple charts (1day loaded) I get the waiting to download intraday chart. The system is then blocked (not freezing however). I copy the log. Could you please help me?
Thank you
Gabriele
2026-04-10 11:33:56.273 | Trade activity files set size: 133
2026-04-10 11:33:56.318 | Reading Internal Order ID file.
2026-04-10 11:33:56.319 | Reading Trade Orders file.
2026-04-10 11:33:56.319 | Reading Trade Positions file.
2026-04-10 11:33:56.320 | Reading Trade Account Data files.
2026-04-10 11:33:56.322 | Software version: 2888 64-bit
2026-04-10 11:33:56.323 | OpenGL enabled (NVIDIA Corporation/Quadro P2000/PCIe/SSE2)
2026-04-10 11:33:56.323 | Primary Thread ID: 2420
2026-04-10 11:33:56.323 | Usage end date: 2026-05-29
2026-04-10 11:33:56.323 | Enabled for: Advanced Features 2.
2026-04-10 11:33:56.323 | Enabled for: Sierra Chart Historical Data Service.
2026-04-10 11:33:56.323 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-04-10 11:33:56.323 | Enabled for: Delayed Denali Exchange Data Feed.
2026-04-10 11:33:56.323 | Enabled for exchange2: CME
2026-04-10 11:33:56.323 | Enabled for exchange2: CBOT (Trading Account Required)
2026-04-10 11:33:56.323 | Enabled for exchange2: COMEX (Trading Account Required)
2026-04-10 11:33:56.323 | Enabled for exchange2: NYMEX (Trading Account Required)
2026-04-10 11:33:56.323 | Enabled for exchange2: US Equities Consolidated Tape
2026-04-10 11:33:56.323 | Enabled for exchange2: CBOE Global Indexes
2026-04-10 11:33:56.323 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-04-10 11:33:56.323 | Current selected Data/Trading service: Teton CME Routing
2026-04-10 11:33:56.323 | Custom symbol settings values: enabled
2026-04-10 11:33:56.323 | Chart Update Interval: 50
2026-04-10 11:33:56.323 | Intraday Data Storage Time Unit: 0
2026-04-10 11:33:56.323 | Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00)
2026-04-10 11:33:56.323 | 2026-04-10 09:33:56 Local computer time in UTC
2026-04-10 11:33:56.323 | 2026-04-10 11:33:56 Local computer time in SC Time Zone
2026-04-10 11:33:56.323 | Program path: C:\SierraChart\
2026-04-10 11:33:56.323 | Data Files path: C:\SierraChart\Data\
2026-04-10 11:33:56.323 | OS Version Number: 10.0
2026-04-10 11:33:56.323 | Locale Setting: C
2026-04-10 11:33:56.323 | Crash reporter started: true
2026-04-10 11:33:56.323 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1.
2026-04-10 11:34:00.835 |
2026-04-10 11:34:00.835 | Teton CME Routing | Firm: AMP
2026-04-10 11:34:00.836 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:34:00.836 | DTC Client socket (5) | Creating socket. Using TLS 1.2.
2026-04-10 11:34:00.836 | DTC Client socket (5) | New receive buffer size: 0
2026-04-10 11:34:00.836 | DTC Client socket (5) | Connecting to IP: 4.8.170.26.
2026-04-10 11:34:17.148 | HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:34:17.363 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:34:17.363 | Request for symbol settings MD5 finished unsuccessfully. Request ID: 1. Socket connection closed during the connection attempt.
2026-04-10 11:34:21.877 | DTC Client socket (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:34:21.877 | DTC Client socket (5) | CloseSocket call.
2026-04-10 11:34:21.877 | DTC Client socket (5) | Closed.
2026-04-10 11:34:21.877 | Teton CME Routing | Failed connections: 1
2026-04-10 11:34:21.877 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-04-10 11:34:21.877 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:34:21.893 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:34:21.893 | Teton CME Routing | Disconnected.
2026-04-10 11:34:21.893 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:34:23.889 |
2026-04-10 11:34:23.889 | Teton CME Routing | Firm: AMP
2026-04-10 11:34:23.889 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:34:23.889 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:34:23.890 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:34:23.890 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:34:44.937 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:34:44.937 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:34:44.937 | DTC Client socket (2) | Closed.
2026-04-10 11:34:44.937 | Teton CME Routing | Failed connections: 2
2026-04-10 11:34:44.937 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-04-10 11:34:44.937 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:34:44.952 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:34:44.952 | Teton CME Routing | Disconnected.
2026-04-10 11:34:44.952 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:34:46.947 |
2026-04-10 11:34:46.947 | Teton CME Routing | Firm: AMP
2026-04-10 11:34:46.947 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067
2026-04-10 11:34:46.948 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:34:46.948 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:34:46.948 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:34:47.079 | Teton CME Routing | Network connection to server complete.
2026-04-10 11:34:47.079 | Teton CME Routing | Starting socket receive thread.
2026-04-10 11:34:47.079 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-04-10 11:34:47.476 | Teton CME Routing | Setting DTC encoding to Binary VLS
2026-04-10 11:34:47.476 | Teton CME Routing | Sending logon request message.
2026-04-10 11:34:47.607 | Teton CME Routing | Received logon response.
2026-04-10 11:34:47.607 | Teton CME Routing | Server Name: SC DTC Server.
2026-04-10 11:34:47.607 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:34:47.607 | Teton CME Routing | Logon error received from server: Secondary instance is not allowing connections to this server
2026-04-10 11:34:47.607 | Teton CME Routing | Failed connections: 3
2026-04-10 11:34:47.607 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-04-10 11:34:47.607 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:34:47.630 | Teton CME Routing | Waiting for socket receive thread to end
2026-04-10 11:34:47.631 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:34:47.631 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-04-10 11:34:47.631 | Teton CME Routing | Disconnected.
2026-04-10 11:34:47.631 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:34:47.762 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-04-10 11:34:47.762 | DTC Client socket (2) | Closed.
2026-04-10 11:34:49.639 |
2026-04-10 11:34:49.640 | Teton CME Routing | Firm: AMP
2026-04-10 11:34:49.640 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066
2026-04-10 11:34:49.640 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:34:49.640 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:34:49.640 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:34:49.772 | Teton CME Routing | Network connection to server complete.
2026-04-10 11:34:49.772 | Teton CME Routing | Starting socket receive thread.
2026-04-10 11:34:49.772 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-04-10 11:34:50.181 | Teton CME Routing | Setting DTC encoding to Binary VLS
2026-04-10 11:34:50.181 | Teton CME Routing | Sending logon request message.
2026-04-10 11:34:50.366 | Teton CME Routing | Received logon response.
2026-04-10 11:34:50.366 | Teton CME Routing | Server Name: SC DTC Server. Build=55065.
2026-04-10 11:34:50.366 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:34:50.366 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2026-04-10 11:34:50.366 | Teton CME Routing | Trading is supported.
2026-04-10 11:34:50.366 | Teton CME Routing | Order cancel and replace is supported.
2026-04-10 11:34:50.366 | Teton CME Routing | OCO Orders supported.
2026-04-10 11:34:50.366 | Teton CME Routing | Bracket Orders supported.
2026-04-10 11:34:50.366 | Teton CME Routing | MarketDepthIsSupported: 1
2026-04-10 11:34:50.366 | Teton CME Routing | Connection to server complete.
2026-04-10 11:34:50.367 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-04-10 11:34:50.367 | Teton CME Routing | Performing query for most recent Order Activity Date-Time.
2026-04-10 11:34:50.373 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-04-09 20:05:38.366553
2026-04-10 11:34:50.502 | Updated verified funded futures trading account ending date to: 2026-05-10 09:34:50
2026-04-10 11:35:10.500 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request.
2026-04-10 11:35:31.529 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: . Success=false
2026-04-10 11:35:50.566 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-04-10 11:35:50.566 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-04-10 11:35:50.566 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:35:50.566 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2026-04-10 11:35:50.566 | DTC Client socket (2) | Max send buffers used during socket life: 3
2026-04-10 11:35:50.566 | DTC Client socket (2) | Max send buffer size during socket life: 233
2026-04-10 11:35:50.566 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-04-10 11:35:50.566 | DTC Client socket (2) | Closed.
2026-04-10 11:35:50.566 | Connection to the external service has been lost.
2026-04-10 11:35:50.580 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:35:50.580 | Teton CME Routing | Disconnected.
2026-04-10 11:35:50.580 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:35:52.596 |
2026-04-10 11:35:52.596 | Teton CME Routing | Firm: AMP
2026-04-10 11:35:52.596 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:35:52.597 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:35:52.597 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:35:52.597 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:36:13.621 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:36:13.621 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:36:13.621 | Teton CME Routing | Failed connections: 1
2026-04-10 11:36:13.621 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-04-10 11:36:13.621 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:36:13.621 | DTC Client socket (2) | Closed.
2026-04-10 11:36:13.635 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:36:13.635 | Teton CME Routing | Disconnected.
2026-04-10 11:36:13.636 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:36:15.645 |
2026-04-10 11:36:15.646 | Teton CME Routing | Firm: AMP
2026-04-10 11:36:15.646 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:36:15.649 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:36:15.649 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:36:15.649 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:36:26.499 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2026-04-10 11:36:36.671 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:36:36.671 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:36:36.671 | DTC Client socket (2) | Closed.
2026-04-10 11:36:36.671 | Teton CME Routing | Failed connections: 2
2026-04-10 11:36:36.671 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-04-10 11:36:36.671 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:36:36.686 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:36:36.686 | Teton CME Routing | Disconnected.
2026-04-10 11:36:36.686 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:36:38.706 |
2026-04-10 11:36:38.706 | Teton CME Routing | Firm: AMP
2026-04-10 11:36:38.706 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067
2026-04-10 11:36:38.706 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:36:38.706 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:36:38.706 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:36:38.836 | Teton CME Routing | Network connection to server complete.
2026-04-10 11:36:38.836 | Teton CME Routing | Starting socket receive thread.
2026-04-10 11:36:38.836 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-04-10 11:36:39.228 | Teton CME Routing | Setting DTC encoding to Binary VLS
2026-04-10 11:36:39.228 | Teton CME Routing | Sending logon request message.
2026-04-10 11:36:39.359 | Teton CME Routing | Received logon response.
2026-04-10 11:36:39.359 | Teton CME Routing | Server Name: SC DTC Server.
2026-04-10 11:36:39.359 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:36:39.359 | Teton CME Routing | Logon error received from server: Secondary instance is not allowing connections to this server
2026-04-10 11:36:39.359 | Teton CME Routing | Failed connections: 3
2026-04-10 11:36:39.359 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-04-10 11:36:39.359 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:36:39.370 | Teton CME Routing | Waiting for socket receive thread to end
2026-04-10 11:36:39.370 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:36:39.370 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-04-10 11:36:39.371 | Teton CME Routing | Disconnected.
2026-04-10 11:36:39.371 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:36:39.501 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-04-10 11:36:39.501 | DTC Client socket (2) | Closed.
2026-04-10 11:36:41.379 |
2026-04-10 11:36:41.380 | Teton CME Routing | Firm: AMP
2026-04-10 11:36:41.380 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066
2026-04-10 11:36:41.380 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:36:41.380 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:36:41.380 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:36:41.512 | Teton CME Routing | Network connection to server complete.
2026-04-10 11:36:41.512 | Teton CME Routing | Starting socket receive thread.
2026-04-10 11:36:41.512 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-04-10 11:36:41.917 | Teton CME Routing | Setting DTC encoding to Binary VLS
2026-04-10 11:36:41.917 | Teton CME Routing | Sending logon request message.
2026-04-10 11:36:42.103 | Teton CME Routing | Received logon response.
2026-04-10 11:36:42.103 | Teton CME Routing | Server Name: SC DTC Server. Build=55065.
2026-04-10 11:36:42.103 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:36:42.103 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2026-04-10 11:36:42.103 | Teton CME Routing | Trading is supported.
2026-04-10 11:36:42.103 | Teton CME Routing | Order cancel and replace is supported.
2026-04-10 11:36:42.103 | Teton CME Routing | OCO Orders supported.
2026-04-10 11:36:42.103 | Teton CME Routing | Bracket Orders supported.
2026-04-10 11:36:42.103 | Teton CME Routing | MarketDepthIsSupported: 1
2026-04-10 11:36:42.103 | Teton CME Routing | Connection to server complete.
2026-04-10 11:36:42.104 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-04-10 11:36:42.104 | Updated verified funded futures trading account ending date to: 2026-05-10 09:36:42
2026-04-10 11:36:42.104 | Teton CME Routing | Performing query for most recent Order Activity Date-Time.
2026-04-10 11:36:42.109 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-04-09 20:05:38.366553
2026-04-10 11:36:42.237 | Updated verified funded futures trading account ending date to: 2026-05-10 09:36:42
2026-04-10 11:36:47.883 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-04-10 11:36:47.883 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2026-04-10 11:36:47.883 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2026-04-10 11:37:41.116 | Loading DLL: C:\SierraChart\Data\ColorThemeSwitcher.dll (ColorThemeSwitcher_64.dll). Handle: 66000000
2026-04-10 11:37:41.121 | Loading DLL: C:\SierraChart\Data\StackedImbalances.dll (StackedImbalances_64.dll). Handle: bf30000
2026-04-10 11:37:41.127 | Loading DLL: C:\SierraChart\Data\Dominator.dll (Dominator_64.dll). Handle: d010000
2026-04-10 11:37:41.222 | ESM26_FUT_CME Rev. 12t #2 | Reloading chart.
2026-04-10 11:37:41.228 | Loading DLL: C:\SierraChart\Data\DivergenceDetector.dll (DivergenceDetector_64.dll). Handle: d670000
2026-04-10 11:37:41.242 | Loading DLL: C:\SierraChart\Data\CandleTaper_64 (1).dll (CandleTaper_64 (1).dll). Handle: 60c0000
2026-04-10 11:37:41.249 | Loading DLL: C:\SierraChart\Data\MenthorQLevelsV3.dll (MenthorQLevelsV3.dll). Handle: 7ffe1efc0000
2026-04-10 11:37:41.257 | Loading DLL: C:\SierraChart\Data\PoorStructure.dll (PoorStructure_64.dll). Handle: d980000
2026-04-10 11:37:41.262 | Loading DLL: C:\SierraChart\Data\EndedAuction.dll (EndedAuction_64.dll). Handle: da80000
2026-04-10 11:37:41.267 | Loading DLL: C:\SierraChart\Data\ExahustionDetector.dll (ExahustionDetector_64.dll). Handle: f0f0000
2026-04-10 11:37:41.271 | Loading DLL: C:\SierraChart\Data\LiquidityImbalances.dll (LiquidityImbalances_64.dll). Handle: f1f0000
2026-04-10 11:37:41.433 | ESM26_FUT_CME Rev. 12t #1 | Reloading chart.
2026-04-10 11:37:41.441 | Loading DLL: C:\SierraChart\Data\MarketProfile.dll (MarketProfile_64.dll). Handle: f540000
2026-04-10 11:37:41.612 | ESm26_FUT_CME [CBV] #5 | Reloading chart.
2026-04-10 11:37:41.673 | Starting DelayedDownloadMonitoringTimer
2026-04-10 11:37:41.673 | Starting HDTimeoutTimer
2026-04-10 11:37:41.673 | Added historical Intraday data request for ESM26_FUT_CME to the queue.
2026-04-10 11:37:41.673 | Triggering next historical data download in queue.
2026-04-10 11:37:41.686 | ESm26_FUT_CME [CBV] #5 | Waiting for historical downloads to complete with the IDs: 1,
2026-04-10 11:37:41.740 | CLK26_FUT_CME [CBV] #4 | Reloading chart.
2026-04-10 11:37:41.753 | Added historical Intraday data request for CLK26_FUT_CME to the queue.
2026-04-10 11:37:41.763 | CLK26_FUT_CME [CBV] #4 | Waiting for historical downloads to complete with the IDs: 2,
2026-04-10 11:37:41.821 | CLK26_FUT_CME 1 Min #3 | Reloading chart.
2026-04-10 11:37:41.864 | Loading market depth data.
2026-04-10 11:37:41.878 | Mapping ESM26_FUT_CME to ESM26. Service code: cme
2026-04-10 11:37:41.878 | Using symbol data fast lookup vector
2026-04-10 11:37:41.878 | HD Request # 1 | Downloading Intraday chart data for ESM26_FUT_CME to the file ESM26_FUT_CME.scid. Service: cme
2026-04-10 11:37:41.879 | HD Request # 1 | Download start date-time: 2026-04-10 11:30:55.000000. File last date-time: 2026-04-10 11:30:55.990003
2026-04-10 11:37:41.880 | HD Request # 1 | Using server: ds26.sierracharts.com port 10149
2026-04-10 11:37:41.880 | Socket (1) | Creating socket.
2026-04-10 11:37:41.880 | Socket (1) | New receive buffer size: 0
2026-04-10 11:37:41.880 | Socket (1) | Connecting to IP: 64.152.155.17.
2026-04-10 11:37:41.893 | ESM26_FUT_CME Rev. 12t #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-10 11:37:41.900 | Loaded depth data records for ESM26_FUT_CME 2026-04-09 from 2026-04-09 21:44:43.730000 to 2026-04-09 23:55:05.002000.
2026-04-10 11:37:41.911 | Chart: ESM26_FUT_CME Rev. 12t #2 | Study: Color Theme Switcher | Color Theme Switcher Applied "Matrix Dark" | BG RGB(5,8,5) | ValScale RGB(90,220,95) | TimeScale RGB(55,165,62) | PriceBox BG RGB(10,30,10) FG RGB(0,220,65) | Up RGB(0,205,65) | Down RGB(215,30,50)
2026-04-10 11:37:41.918 | Loaded depth data records for ESM26_FUT_CME 2026-04-10 from 2026-04-10 10:13:39.329000 to 2026-04-10 11:30:55.990000.
2026-04-10 11:37:41.918 | + Loading additional symbol data.
2026-04-10 11:37:41.950 | Loading market depth data.
2026-04-10 11:37:41.989 | Loaded depth data records for CLK26_FUT_CME 2026-04-09 from 2026-04-09 21:44:46.803000 to 2026-04-09 23:55:36.506000.
2026-04-10 11:37:42.012 | Loaded depth data records for CLK26_FUT_CME 2026-04-10 from 2026-04-10 10:13:38.807000 to 2026-04-10 11:27:34.869353.
2026-04-10 11:37:42.012 | + Loading additional symbol data.
2026-04-10 11:37:42.232 | ESM26_FUT_CME Rev. 12t #2 | Chart data loading complete.
2026-04-10 11:37:42.253 | Chart: ESM26_FUT_CME Rev. 12t #2 | Study: Color Theme Switcher | Color Theme Switcher Applied "Matrix Dark" | BG RGB(5,8,5) | ValScale RGB(90,220,95) | TimeScale RGB(55,165,62) | PriceBox BG RGB(10,30,10) FG RGB(0,220,65) | Up RGB(0,205,65) | Down RGB(215,30,50)
2026-04-10 11:37:42.291 | ESM26_FUT_CME Rev. 12t #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-10 11:37:42.292 | Trace | Is a formula symbol.. Symbol: VIX/VVIX
2026-04-10 11:37:42.292 | Mapping VIX_CGI to VIX_CGI. Service code: cboe_global_indexes.data
2026-04-10 11:37:42.293 | Denali Data Feed | Starting real-time market data updates for: VIX_CGI (VIX_CGI). ID: 3 Service code: cboe_global_indexes.data
2026-04-10 11:37:42.293 | Denali Data Feed | Connecting to the server ds33.sierracharts.com. Port 10047
2026-04-10 11:37:42.293 | Denali Data Feed | Requesting security definition data for: VIX_CGI (VIX_CGI). ID: 3
2026-04-10 11:37:42.293 | Mapping VVIX_CGI to VVIX_CGI. Service code: cboe_global_indexes.data
2026-04-10 11:37:42.293 | Denali Data Feed | Starting real-time market data updates for: VVIX_CGI (VVIX_CGI). ID: 4 Service code: cboe_global_indexes.data
2026-04-10 11:37:42.293 | Denali Data Feed | Requesting security definition data for: VVIX_CGI (VVIX_CGI). ID: 4
2026-04-10 11:37:42.293 | Teton CME Routing | Not subscribing to real-time market data updates directly because it is a composite or formula symbol. VIX/VVIX. ID: 2
2026-04-10 11:37:42.293 | Starting DelayedDownloadMonitoringTimer
2026-04-10 11:37:42.293 | Starting HDTimeoutTimer
2026-04-10 11:37:42.293 | Added historical Intraday data request for VIX/VVIX to the queue.
2026-04-10 11:37:42.293 | Intraday data recording state for symbol VIX/VVIX is set to download 'Pending'.
2026-04-10 11:37:42.293 | DTC Client socket (3) | Creating socket.
2026-04-10 11:37:42.293 | DTC Client socket (3) | New receive buffer size: 0
2026-04-10 11:37:42.293 | DTC Client socket (3) | Connecting to IP: 69.39.70.245.
2026-04-10 11:37:42.293 | Triggering next historical data download in queue.
2026-04-10 11:37:42.293 | ESM26_FUT_CME Rev. 12t #1 | Started historical data download for additional symbol vix/vvix. Download ID: 3
2026-04-10 11:37:42.516 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-04-10 11:37:42.516 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-04-10 11:37:42.942 | Chart: ESM26_FUT_CME Rev. 12t #1 | Study: Color Theme Switcher | Color Theme Switcher Applied "Matrix Dark" | BG RGB(5,8,5) | ValScale RGB(90,220,95) | TimeScale RGB(55,165,62) | PriceBox BG RGB(10,30,10) FG RGB(0,220,65) | Up RGB(0,205,65) | Down RGB(215,30,50)
2026-04-10 11:37:42.963 | ESM26_FUT_CME Rev. 12t #1 | Chart data loading complete.
2026-04-10 11:37:43.009 | CLK26_FUT_CME 1 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-10 11:37:43.383 | DTC Client socket (2) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host.
2026-04-10 11:37:47.070 | Chart: CLK26_FUT_CME 1 Min #3 | Study: Color Theme Switcher | Color Theme Switcher Applied "Matrix Dark" | BG RGB(5,8,5) | ValScale RGB(90,220,95) | TimeScale RGB(55,165,62) | PriceBox BG RGB(10,30,10) FG RGB(0,220,65) | Up RGB(0,205,65) | Down RGB(215,30,50)
2026-04-10 11:37:47.098 | CLK26_FUT_CME 1 Min #3 | Chart data loading complete.
2026-04-10 11:37:47.684 | Chart: ESM26_FUT_CME Rev. 12t #1 | Study: Color Theme Switcher | Color Theme Switcher Applied "Matrix Dark" | BG RGB(5,8,5) | ValScale RGB(90,220,95) | TimeScale RGB(55,165,62) | PriceBox BG RGB(10,30,10) FG RGB(0,220,65) | Up RGB(0,205,65) | Down RGB(215,30,50)
2026-04-10 11:37:51.761 | Chart: CLK26_FUT_CME 1 Min #3 | Study: Color Theme Switcher | Color Theme Switcher Applied "Matrix Dark" | BG RGB(5,8,5) | ValScale RGB(90,220,95) | TimeScale RGB(55,165,62) | PriceBox BG RGB(10,30,10) FG RGB(0,220,65) | Up RGB(0,205,65) | Down RGB(215,30,50)
2026-04-10 11:37:51.787 | Delaying start of download for VIX/VVIX.
2026-04-10 11:37:51.787 | Denali Data Feed | Network connection to server complete.
2026-04-10 11:37:51.787 | Denali Data Feed | Starting socket receive thread.
2026-04-10 11:37:51.787 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2026-04-10 11:37:51.787 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:37:51.787 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2026-04-10 11:37:51.788 | DTC Client socket (2) | Max send buffers used during socket life: 3
2026-04-10 11:37:51.788 | DTC Client socket (2) | Max send buffer size during socket life: 233
2026-04-10 11:37:51.788 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-04-10 11:37:51.788 | DTC Client socket (2) | Closed.
2026-04-10 11:37:51.789 | Connection to the external service has been lost.
2026-04-10 11:37:52.814 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-04-10 11:37:54.608 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:37:54.608 | Teton CME Routing | Disconnected.
2026-04-10 11:37:54.608 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:37:54.608 | HD Request # 2 | Downloading Intraday chart data for VIX/VVIX to the file VIX[VVIX.scid. Service:
2026-04-10 11:37:54.608 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-04-10 11:37:54.609 | HD Request # 2 | Download start date-time: 2026-04-10 11:30:46.000000. File last date-time: 2026-04-10 11:30:46.314000
2026-04-10 11:37:54.610 | HD Request # 2 | Initiating download of VIX_CGI for VIX/VVIX.
2026-04-10 11:37:54.610 | Added historical Intraday data request for VIX_CGI to the queue.
2026-04-10 11:37:54.610 | Intraday data recording state for symbol VIX_CGI is set to download 'Pending'.
2026-04-10 11:37:54.610 | Triggering next historical data download in queue.
2026-04-10 11:37:54.610 | HD Request # 2 | Initiating download of VVIX_CGI for VIX/VVIX.
2026-04-10 11:37:54.610 | Added historical Intraday data request for VVIX_CGI to the queue.
2026-04-10 11:37:54.610 | Intraday data recording state for symbol VVIX_CGI is set to download 'Pending'.
2026-04-10 11:37:54.611 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-04-10 11:37:54.611 | Denali Data Feed | Sending logon request message.
2026-04-10 11:37:54.611 | Denali Data Feed | Server has requested a logoff. Reason: No Logon message received.
2026-04-10 11:37:54.611 | Denali Data Feed | Failed connections: 1
2026-04-10 11:37:54.611 | Denali Data Feed | Waiting for socket receive thread to end
2026-04-10 11:37:54.611 | DTC Client socket (3) | CloseSocket call.
2026-04-10 11:37:54.611 | DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0
2026-04-10 11:37:54.611 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:37:54.611 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-04-10 11:37:54.726 | Mapping CLK26_FUT_CME to CLK26. Service code: nymex
2026-04-10 11:37:54.813 | DTC Client socket (3) | Write has completed. Shutdown being performed.
2026-04-10 11:37:54.813 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-04-10 11:37:54.813 | DTC Client socket (3) | Closed.
2026-04-10 11:37:56.622 |
2026-04-10 11:37:56.622 | Teton CME Routing | Firm: AMP
2026-04-10 11:37:56.622 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:37:56.625 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:37:56.625 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:37:56.625 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:37:57.631 | Denali Data Feed | Connecting to the server ds31.sierracharts.com. Port 10047
2026-04-10 11:37:57.631 | DTC Client socket (3) | Creating socket.
2026-04-10 11:37:57.631 | DTC Client socket (3) | New receive buffer size: 0
2026-04-10 11:37:57.631 | DTC Client socket (3) | Connecting to IP: 64.152.155.116.
2026-04-10 11:38:02.930 | Socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:38:02.930 | Socket (1) | CloseSocket call.
2026-04-10 11:38:02.930 | Socket (0) | CloseSocket call.
2026-04-10 11:38:02.930 | Socket (1) | Closed.
2026-04-10 11:38:02.932 | HD Request # 1 | Error downloading historical Intraday data for ESM26_FUT_CME. The network socket has been closed. Retrying download.
2026-04-10 11:38:02.932 | Added historical Intraday data request for ESM26_FUT_CME to the queue.
2026-04-10 11:38:02.932 | Triggering next historical data download in queue.
2026-04-10 11:38:02.932 | Historical data download thread signaled to stop.
2026-04-10 11:38:02.932 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESM26_FUT_CME
2026-04-10 11:38:02.932 | HD Request # 1 | Completion time: 21s.
2026-04-10 11:38:02.932 | HD Request # 3 | Downloading Intraday chart data for ESM26_FUT_CME to the file ESM26_FUT_CME.scid. Service: cme
2026-04-10 11:38:02.932 | HD Request # 3 | Download start date-time: 2026-04-10 11:30:55.000000. File last date-time: 2026-04-10 11:30:55.990003
2026-04-10 11:38:02.932 | HD Request # 3 | Using server: ds32.sierracharts.com port 10150
2026-04-10 11:38:02.933 | Socket (1) | Creating socket.
2026-04-10 11:38:02.933 | Socket (1) | New receive buffer size: 0
2026-04-10 11:38:02.933 | Socket (1) | Connecting to IP: 69.39.70.248.
2026-04-10 11:38:03.228 | HD Request # 3 | Setting DTC encoding to Binary VLS
2026-04-10 11:38:03.228 | HD Request # 3 | Sending historical data logon request message.
2026-04-10 11:38:03.413 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-04-10 11:30:55. Record interval: 0. Symbol: ESM26
2026-04-10 11:38:03.559 | HD Request # 3 | Decompressing data.
2026-04-10 11:38:04.283 | HD Request # 3 | Receiving Intraday data for ESM26_FUT_CME starting at 2026-04-10 11:30:55.108000
2026-04-10 11:38:04.284 | Socket (1) | CloseSocket call.
2026-04-10 11:38:04.284 | Socket (1) | Shutdown started. Waiting for graceful close.
2026-04-10 11:38:04.293 | Historical data download thread signaled to stop.
2026-04-10 11:38:04.293 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-04-10 11:30:58.888000.
2026-04-10 11:38:04.293 | HD Request # 3 | Received 1396 Intraday data records from 2026-04-10 11:30:55.108000 to 2026-04-10 11:38:02.050002 (7.1 minutes. Delay: 2.2 seconds) and wrote 1391 records for ESM26_FUT_CME
2026-04-10 11:38:04.293 | HD Request # 3 | Completion time: 2s.
2026-04-10 11:38:04.293 | HD Request # 3 | Intraday data download complete for ESM26_FUT_CME. Unique request ID: 1
2026-04-10 11:38:04.293 | Removing historical data download ID 1.
2026-04-10 11:38:04.293 | Real-time Intraday chart data file updates started for ESM26_FUT_CME
2026-04-10 11:38:04.293 | Intraday chart data file opened for ESM26_FUT_CME
2026-04-10 11:38:04.293 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2026-04-10 11:38:04.293 | Triggering next historical data download in queue.
2026-04-10 11:38:04.293 | Historical data for ESM26_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2026-04-10 11:38:04.293 | HD Request # 4 | Downloading Intraday chart data for CLK26_FUT_CME to the file CLK26_FUT_CME.scid. Service: nymex
2026-04-10 11:38:04.293 | HD Request # 4 | Download start date-time: 2026-04-10 11:28:21.000000. File last date-time: 2026-04-10 11:28:21.399000
2026-04-10 11:38:04.293 | HD Request # 4 | Using server: ds28.sierracharts.com port 10149
2026-04-10 11:38:04.323 | Socket (4) | Creating socket.
2026-04-10 11:38:04.323 | Socket (4) | New receive buffer size: 0
2026-04-10 11:38:04.323 | Socket (4) | Connecting to IP: 67.214.125.5.
2026-04-10 11:38:04.371 | ESm26_FUT_CME [CBV] #5 | Download is complete for all contract months in chart. Proceeding with data load.
2026-04-10 11:38:04.371 | ESm26_FUT_CME [CBV] #5 | Reloading chart.
2026-04-10 11:38:04.429 | Socket (1) | Socket gracefully closed by remote side.
2026-04-10 11:38:04.429 | Socket (1) | Closed.
2026-04-10 11:38:04.471 | ESm26_FUT_CME [CBV] #5 | Reloading chart.
2026-04-10 11:38:05.031 | HD Request # 4 | Setting DTC encoding to Binary VLS
2026-04-10 11:38:05.031 | HD Request # 4 | Sending historical data logon request message.
2026-04-10 11:38:05.210 | HD Request # 4 | Requesting Intraday data. Start date-time: 2026-04-10 11:28:21. Record interval: 0. Symbol: CLK26
2026-04-10 11:38:05.356 | HD Request # 4 | Decompressing data.
2026-04-10 11:38:06.788 | HD Request # 4 | Receiving Intraday data for CLK26_FUT_CME starting at 2026-04-10 11:28:21.399000
2026-04-10 11:38:07.106 | Socket (4) | CloseSocket call.
2026-04-10 11:38:07.106 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-04-10 11:38:07.106 | Historical data download thread signaled to stop.
2026-04-10 11:38:07.106 | HD Request # 4 | Timestamp of first Intraday data file record written: 2026-04-10 11:28:30.354000.
2026-04-10 11:38:07.106 | HD Request # 4 | Received 1842 Intraday data records from 2026-04-10 11:28:21.399000 to 2026-04-10 11:38:02.233000 (9.7 minutes. Delay: 4.9 seconds) and wrote 1841 records for CLK26_FUT_CME
2026-04-10 11:38:07.106 | HD Request # 4 | Completion time: 3s.
2026-04-10 11:38:07.106 | HD Request # 4 | Intraday data download complete for CLK26_FUT_CME. Unique request ID: 2
2026-04-10 11:38:07.106 | Removing historical data download ID 2.
2026-04-10 11:38:07.106 | Real-time Intraday chart data file updates started for CLK26_FUT_CME
2026-04-10 11:38:07.106 | Intraday chart data file opened for CLK26_FUT_CME
2026-04-10 11:38:07.106 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2026-04-10 11:38:07.106 | Triggering next historical data download in queue.
2026-04-10 11:38:07.106 | Historical data for CLK26_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2026-04-10 11:38:07.106 | HD Request # 5 | Downloading Intraday chart data for VIX_CGI to the file VIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:38:07.106 | HD Request # 5 | Download start date-time: 2026-04-10 11:30:46.000000. File last date-time: 2026-04-10 11:30:46.314000
2026-04-10 11:38:07.106 | HD Request # 5 | Using server: ds33.sierracharts.com port 10150
2026-04-10 11:38:07.107 | Socket (1) | Creating socket.
2026-04-10 11:38:07.107 | Socket (1) | New receive buffer size: 0
2026-04-10 11:38:07.107 | Socket (1) | Connecting to IP: 69.39.70.245.
2026-04-10 11:38:07.168 | CLK26_FUT_CME [CBV] #4 | Download is complete for all contract months in chart. Proceeding with data load.
2026-04-10 11:38:07.168 | CLK26_FUT_CME [CBV] #4 | Reloading chart.
2026-04-10 11:38:07.251 | Socket (4) | Socket gracefully closed by remote side.
2026-04-10 11:38:07.251 | Socket (4) | Closed.
2026-04-10 11:38:07.326 | CLK26_FUT_CME [CBV] #4 | Reloading chart.
2026-04-10 11:38:07.359 | HD Request # 5 | Setting DTC encoding to Binary VLS
2026-04-10 11:38:07.359 | HD Request # 5 | Sending historical data logon request message.
2026-04-10 11:38:07.513 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-04-10 11:30:46. Record interval: 0. Symbol: VIX_CGI
2026-04-10 11:38:07.638 | HD Request # 5 | Decompressing data.
2026-04-10 11:38:07.763 | HD Request # 5 | Receiving Intraday data for VIX_CGI starting at 2026-04-10 11:30:46.314000
2026-04-10 11:38:07.763 | Socket (1) | CloseSocket call.
2026-04-10 11:38:07.763 | Socket (1) | Shutdown started. Waiting for graceful close.
2026-04-10 11:38:07.763 | Historical data download thread signaled to stop.
2026-04-10 11:38:07.763 | HD Request # 5 | Timestamp of first Intraday data file record written: 2026-04-10 11:31:01.324000.
2026-04-10 11:38:07.764 | HD Request # 5 | Received 30 Intraday data records from 2026-04-10 11:30:46.314000 to 2026-04-10 11:38:01.325000 (7.3 minutes. Delay: 6.4 seconds) and wrote 29 records for VIX_CGI
2026-04-10 11:38:07.764 | HD Request # 5 | Completion time: 0s.
2026-04-10 11:38:07.764 | HD Request # 5 | Intraday data download complete for VIX_CGI. Unique request ID: 4
2026-04-10 11:38:07.764 | Removing historical data download ID 4.
2026-04-10 11:38:07.764 | Real-time Intraday chart data file updates started for VIX_CGI
2026-04-10 11:38:07.764 | Intraday chart data file opened for VIX_CGI
2026-04-10 11:38:07.764 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2026-04-10 11:38:07.764 | Triggering next historical data download in queue.
2026-04-10 11:38:07.764 | Historical data for VIX_CGI is delayed because connection to main data feed is not present. Current data will be received upon connection.
2026-04-10 11:38:07.764 | HD Request # 6 | Downloading Intraday chart data for VVIX_CGI to the file VVIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:38:07.764 | HD Request # 6 | Download start date-time: 2026-04-09 22:15:01.000000. File last date-time: 2026-04-09 22:15:01.163000
2026-04-10 11:38:07.764 | HD Request # 6 | Using server: ds31.sierracharts.com port 10149
2026-04-10 11:38:07.764 | Socket (4) | Creating socket.
2026-04-10 11:38:07.764 | Socket (4) | New receive buffer size: 0
2026-04-10 11:38:07.764 | Socket (4) | Connecting to IP: 64.152.155.116.
2026-04-10 11:38:07.889 | Socket (1) | Socket gracefully closed by remote side.
2026-04-10 11:38:07.889 | Socket (1) | Closed.
2026-04-10 11:38:08.232 | ESm26_FUT_CME [CBV][M] #5 | Chart data loading complete.
2026-04-10 11:38:08.270 | CLK26_FUT_CME [CBV][M] #4 | Chart data loading complete.
2026-04-10 11:38:17.670 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:38:17.670 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:38:17.670 | Teton CME Routing | Failed connections: 1
2026-04-10 11:38:17.670 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-04-10 11:38:17.670 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:38:17.670 | DTC Client socket (2) | Closed.
2026-04-10 11:38:17.685 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:38:17.685 | Teton CME Routing | Disconnected.
2026-04-10 11:38:17.685 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:38:18.664 | DTC Client socket (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:38:18.684 | DTC Client socket (3) | CloseSocket call.
2026-04-10 11:38:18.684 | Denali Data Feed | Failed connections: 2
2026-04-10 11:38:18.684 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:38:18.684 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:38:18.684 | DTC Client socket (3) | Closed.
2026-04-10 11:38:18.684 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-04-10 11:38:19.704 |
2026-04-10 11:38:19.705 | Teton CME Routing | Firm: AMP
2026-04-10 11:38:19.705 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:38:19.705 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-04-10 11:38:19.705 | DTC Client socket (1) | New receive buffer size: 0
2026-04-10 11:38:19.705 | DTC Client socket (1) | Connecting to IP: 4.8.170.26.
2026-04-10 11:38:21.691 | Denali Data Feed | Connecting to the server ds30.sierracharts.com. Port 10047
2026-04-10 11:38:21.691 | DTC Client socket (2) | Creating socket.
2026-04-10 11:38:21.691 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:38:21.691 | DTC Client socket (2) | Connecting to IP: 67.214.125.11.
2026-04-10 11:38:21.841 | Denali Data Feed | Network connection to server complete.
2026-04-10 11:38:21.841 | Denali Data Feed | Starting socket receive thread.
2026-04-10 11:38:21.841 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2026-04-10 11:38:22.052 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-04-10 11:38:22.052 | Denali Data Feed | Sending logon request message.
2026-04-10 11:38:22.301 | Denali Data Feed | Received logon response.
2026-04-10 11:38:22.301 | Denali Data Feed | Server Name: SC Realtime Server.
2026-04-10 11:38:22.301 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:38:22.301 | Denali Data Feed | Successfully connected.
2026-04-10 11:38:22.301 | Denali Data Feed | Trading is not supported.
2026-04-10 11:38:22.301 | Denali Data Feed | MarketDepthIsSupported: 1
2026-04-10 11:38:22.301 | Denali Data Feed | Restarting real-time data updates for symbol: VIX_CGI -> VIX_CGI
2026-04-10 11:38:22.301 | Denali Data Feed | Restarting real-time data updates for symbol: VVIX_CGI -> VVIX_CGI
2026-04-10 11:38:22.600 | Denali Data Feed | Setting external service identifier for symbol VIX_CGI to 1348
2026-04-10 11:38:22.600 | Denali Data Feed | Received security definition for symbol VIX_CGI
2026-04-10 11:38:22.600 | Denali Data Feed | Setting external service identifier for symbol VVIX_CGI to 1364
2026-04-10 11:38:22.600 | Denali Data Feed | Received security definition for symbol VVIX_CGI
2026-04-10 11:38:28.813 | Socket (4) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:38:28.813 | Socket (4) | CloseSocket call.
2026-04-10 11:38:28.813 | Socket (0) | CloseSocket call.
2026-04-10 11:38:28.813 | Socket (4) | Closed.
2026-04-10 11:38:28.813 | HD Request # 6 | Error downloading historical Intraday data for VVIX_CGI. The network socket has been closed. Retrying download.
2026-04-10 11:38:28.813 | Added historical Intraday data request for VVIX_CGI to the queue.
2026-04-10 11:38:28.813 | Intraday data recording state for symbol VVIX_CGI is set to download 'Pending'.
2026-04-10 11:38:28.814 | Triggering next historical data download in queue.
2026-04-10 11:38:28.814 | Historical data download thread signaled to stop.
2026-04-10 11:38:28.814 | HD Request # 6 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for VVIX_CGI
2026-04-10 11:38:28.814 | HD Request # 6 | Completion time: 21s.
2026-04-10 11:38:28.814 | HD Request # 7 | Downloading Intraday chart data for VVIX_CGI to the file VVIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:38:28.814 | HD Request # 7 | Download start date-time: 2026-04-09 22:15:01.000000. File last date-time: 2026-04-09 22:15:01.163000
2026-04-10 11:38:28.814 | HD Request # 7 | Using server: ds30.sierracharts.com port 10150
2026-04-10 11:38:28.814 | Socket (3) | Creating socket.
2026-04-10 11:38:28.814 | Socket (3) | New receive buffer size: 0
2026-04-10 11:38:28.814 | Socket (3) | Connecting to IP: 67.214.125.11.
2026-04-10 11:38:28.875 | Teton CME Routing | Network connection to server complete.
2026-04-10 11:38:28.875 | Teton CME Routing | Starting socket receive thread.
2026-04-10 11:38:28.875 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-04-10 11:38:29.116 | HD Request # 7 | Setting DTC encoding to Binary VLS
2026-04-10 11:38:29.116 | HD Request # 7 | Sending historical data logon request message.
2026-04-10 11:38:29.296 | HD Request # 7 | Requesting Intraday data. Start date-time: 2026-04-09 22:15:01. Record interval: 0. Symbol: VVIX_CGI
2026-04-10 11:38:29.445 | HD Request # 7 | Decompressing data.
2026-04-10 11:38:29.594 | HD Request # 7 | Receiving Intraday data for VVIX_CGI starting at 2026-04-09 22:15:01.163000
2026-04-10 11:38:29.594 | Socket (3) | CloseSocket call.
2026-04-10 11:38:29.594 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-04-10 11:38:29.611 | Historical data download thread signaled to stop.
2026-04-10 11:38:29.611 | HD Request # 7 | Received 1 Intraday data record from 2026-04-09 22:15:01.163000 to 2026-04-09 22:15:01.163000 (0.0 seconds. Delay: 13.4 hours) and wrote 0 records for VVIX_CGI
2026-04-10 11:38:29.611 | HD Request # 7 | Completion time: 1s.
2026-04-10 11:38:29.611 | HD Request # 7 | Intraday data download complete for VVIX_CGI. Unique request ID: 5
2026-04-10 11:38:29.611 | Removing historical data download ID 5.
2026-04-10 11:38:29.611 | HD Request # 2 | Calculating bar data for VIX/VVIX.
2026-04-10 11:38:29.611 | Real-time Intraday chart data file updates started for VVIX_CGI
2026-04-10 11:38:29.611 | Intraday chart data file opened for VVIX_CGI
2026-04-10 11:38:29.611 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2026-04-10 11:38:29.611 | No download requests in the queue to start downloads for.
2026-04-10 11:38:29.620 | HD Request # 2 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for VIX/VVIX
2026-04-10 11:38:29.620 | HD Request # 2 | Completion time: 35s.
2026-04-10 11:38:29.620 | HD Request # 2 | Intraday data download complete for VIX/VVIX. Unique request ID: 3
2026-04-10 11:38:29.620 | Removing historical data download ID 3.
2026-04-10 11:38:29.620 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2026-04-10 11:38:29.620 | ESM26_FUT_CME[M] Rev. 12t #1 | Historical data download for additional symbol vix/vvix with ID 3 has completed.
2026-04-10 11:38:29.620 | No download requests in the queue to start downloads for.
2026-04-10 11:38:29.743 | Socket (3) | Socket gracefully closed by remote side.
2026-04-10 11:38:29.743 | Socket (3) | Closed.
2026-04-10 11:38:30.221 | Chart: ESM26_FUT_CME[M] Rev. 12t #1 | Study: Color Theme Switcher | Color Theme Switcher Applied "Matrix Dark" | BG RGB(5,8,5) | ValScale RGB(90,220,95) | TimeScale RGB(55,165,62) | PriceBox BG RGB(10,30,10) FG RGB(0,220,65) | Up RGB(0,205,65) | Down RGB(215,30,50)
2026-04-10 11:38:30.242 | ESM26_FUT_CME[M] Rev. 12t #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-10 11:38:30.259 | Chart: ESM26_FUT_CME[M] Rev. 12t #2 | Study: Color Theme Switcher | Color Theme Switcher Applied "Matrix Dark" | BG RGB(5,8,5) | ValScale RGB(90,220,95) | TimeScale RGB(55,165,62) | PriceBox BG RGB(10,30,10) FG RGB(0,220,65) | Up RGB(0,205,65) | Down RGB(215,30,50) | Number times message added: 1
2026-04-10 11:38:31.246 | ESM26_FUT_CME[M] Rev. 12t #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-10 11:38:31.262 | Chart: ESM26_FUT_CME[M] Rev. 12t #2 | Study: Color Theme Switcher | Color Theme Switcher Applied "Matrix Dark" | BG RGB(5,8,5) | ValScale RGB(90,220,95) | TimeScale RGB(55,165,62) | PriceBox BG RGB(10,30,10) FG RGB(0,220,65) | Up RGB(0,205,65) | Down RGB(215,30,50) | Number times message added: 1
2026-04-10 11:38:43.223 | Teton CME Routing | Setting DTC encoding to Binary VLS
2026-04-10 11:38:43.223 | Teton CME Routing | Sending logon request message.
2026-04-10 11:38:43.403 | Teton CME Routing | Received logon response.
2026-04-10 11:38:43.403 | Teton CME Routing | Server Name: SC DTC Server. Build=55065.
2026-04-10 11:38:43.403 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:38:43.403 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2026-04-10 11:38:43.403 | Teton CME Routing | Trading is supported.
2026-04-10 11:38:43.403 | Teton CME Routing | Order cancel and replace is supported.
2026-04-10 11:38:43.403 | Teton CME Routing | OCO Orders supported.
2026-04-10 11:38:43.403 | Teton CME Routing | Bracket Orders supported.
2026-04-10 11:38:43.403 | Teton CME Routing | MarketDepthIsSupported: 1
2026-04-10 11:38:43.403 | Teton CME Routing | Connection to server complete.
2026-04-10 11:38:43.403 | Denali Data Feed | Waiting for socket receive thread to end
2026-04-10 11:38:43.404 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:38:43.404 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-04-10 11:38:43.404 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:38:43.404 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-04-10 11:38:43.404 | Updated verified funded futures trading account ending date to: 2026-05-10 09:38:43
2026-04-10 11:38:43.405 | Using symbol data fast lookup vector
2026-04-10 11:38:43.405 | Trace | Is a formula symbol.. Symbol: VIX/VVIX
2026-04-10 11:38:43.405 | Mapping VIX_CGI to VIX_CGI. Service code: cboe_global_indexes.data
2026-04-10 11:38:43.405 | Denali Data Feed | Starting real-time market data updates for: VIX_CGI (VIX_CGI). ID: 2 Service code: cboe_global_indexes.data
2026-04-10 11:38:43.405 | Denali Data Feed | Connecting to the server ds33.sierracharts.com. Port 10047
2026-04-10 11:38:43.405 | Denali Data Feed | Requesting security definition data for: VIX_CGI (VIX_CGI). ID: 2
2026-04-10 11:38:43.405 | Mapping VVIX_CGI to VVIX_CGI. Service code: cboe_global_indexes.data
2026-04-10 11:38:43.405 | Denali Data Feed | Starting real-time market data updates for: VVIX_CGI (VVIX_CGI). ID: 3 Service code: cboe_global_indexes.data
2026-04-10 11:38:43.405 | Denali Data Feed | Requesting security definition data for: VVIX_CGI (VVIX_CGI). ID: 3
2026-04-10 11:38:43.405 | Teton CME Routing | Not subscribing to real-time market data updates directly because it is a composite or formula symbol. VIX/VVIX. ID: 1
2026-04-10 11:38:43.405 | Added historical Intraday data request for VIX/VVIX to the queue.
2026-04-10 11:38:43.405 | Intraday data recording state for symbol VIX/VVIX is set to download 'Pending'.
2026-04-10 11:38:43.405 | Triggering next historical data download in queue.
2026-04-10 11:38:43.405 | ESM26_FUT_CME[M] Rev. 12t #1 | Started historical data download for additional symbol vix/vvix. Download ID: 6
2026-04-10 11:38:43.405 | DTC Client socket (3) | Creating socket.
2026-04-10 11:38:43.405 | DTC Client socket (3) | New receive buffer size: 0
2026-04-10 11:38:43.405 | DTC Client socket (3) | Connecting to IP: 69.39.70.245.
2026-04-10 11:38:43.442 | Teton CME Routing | Performing query for most recent Order Activity Date-Time.
2026-04-10 11:38:43.442 | Denali Data Feed | Failed connections: 1
2026-04-10 11:38:43.442 | DTC Client socket (3) | CloseSocket call.
2026-04-10 11:38:43.442 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:38:43.442 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-04-10 11:38:43.442 | DTC Client socket (3) | Closed.
2026-04-10 11:38:43.442 | Delaying start of download for VIX/VVIX.
2026-04-10 11:38:43.443 | Mapping ESm26_FUT_CME to ESM26. Service code: cme
2026-04-10 11:38:43.443 | Denali Data Feed | Starting real-time market data updates for: ESm26_FUT_CME (ESM26). ID: 4 Service code: cme
2026-04-10 11:38:43.443 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048
2026-04-10 11:38:43.443 | Denali Data Feed | Requesting security definition data for: ESm26_FUT_CME (ESM26). ID: 4
2026-04-10 11:38:43.444 | DTC Client socket (3) | Creating socket.
2026-04-10 11:38:43.444 | DTC Client socket (3) | New receive buffer size: 0
2026-04-10 11:38:43.444 | DTC Client socket (3) | Connecting to IP: 64.152.155.17.
2026-04-10 11:38:43.444 | Added historical Intraday data request for ESm26_FUT_CME to the queue.
2026-04-10 11:38:43.444 | Intraday data recording state for symbol ESm26_FUT_CME is set to download 'Pending'.
2026-04-10 11:38:43.444 | Triggering next historical data download in queue.
2026-04-10 11:38:43.448 | Delaying start of download for ESm26_FUT_CME.
2026-04-10 11:38:43.448 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-04-09 20:05:38.366553
2026-04-10 11:38:43.499 | Mapping CLK26_FUT_CME to CLK26. Service code: nymex
2026-04-10 11:38:43.499 | Denali Data Feed | Starting real-time market data updates for: CLK26_FUT_CME (CLK26). ID: 5 Service code: nymex
2026-04-10 11:38:43.499 | Denali Data Feed | Requesting security definition data for: CLK26_FUT_CME (CLK26). ID: 5
2026-04-10 11:38:43.499 | Requesting market depth updates for: CLK26_FUT_CME if supported. NumLevels=100
2026-04-10 11:38:43.499 | Added historical Intraday data request for CLK26_FUT_CME to the queue.
2026-04-10 11:38:43.499 | Intraday data recording state for symbol CLK26_FUT_CME is set to download 'Pending'.
2026-04-10 11:38:43.499 | Triggering next historical data download in queue.
2026-04-10 11:38:43.524 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-04-10 11:38:43.524 | DTC Client socket (2) | Closed.
2026-04-10 11:38:43.568 | Denali Data Feed | Network connection to server complete.
2026-04-10 11:38:43.568 | Denali Data Feed | Starting socket receive thread.
2026-04-10 11:38:43.568 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-04-10 11:38:43.568 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VIX_CGI. ID = 2
2026-04-10 11:38:43.568 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VVIX_CGI. ID = 3
2026-04-10 11:38:43.568 | Requesting market depth updates for: ESm26_FUT_CME if supported. NumLevels=100
2026-04-10 11:38:43.596 | Updated verified funded futures trading account ending date to: 2026-05-10 09:38:43
2026-04-10 11:38:43.688 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESm26_FUT_CME
2026-04-10 11:38:43.688 | Teton CME Routing | Setting external service identifier for symbol ESm26_FUT_CME to 42140864
2026-04-10 11:38:43.688 | Teton CME Routing | Received security definition for symbol ESm26_FUT_CME
2026-04-10 11:38:43.688 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLK26_FUT_CME
2026-04-10 11:38:43.688 | Teton CME Routing | Setting external service identifier for symbol CLK26_FUT_CME to 169926
2026-04-10 11:38:43.688 | Teton CME Routing | Received security definition for symbol CLK26_FUT_CME
2026-04-10 11:38:43.721 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-04-10 11:38:43.721 | Denali Data Feed | Sending logon request message.
2026-04-10 11:38:44.336 | Denali Data Feed | Received logon response.
2026-04-10 11:38:44.336 | Denali Data Feed | Server Name: SC Realtime Server.
2026-04-10 11:38:44.336 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:38:44.336 | Denali Data Feed | Successfully connected.
2026-04-10 11:38:44.336 | Denali Data Feed | Trading is not supported.
2026-04-10 11:38:44.336 | Denali Data Feed | MarketDepthIsSupported: 1
2026-04-10 11:38:44.336 | Denali Data Feed | Restarting real-time data updates for symbol: CLK26_FUT_CME -> CLK26. Market Depth data restarted.
2026-04-10 11:38:44.336 | Denali Data Feed | Restarting real-time data updates for symbol: ESm26_FUT_CME -> ESM26. Market Depth data restarted.
2026-04-10 11:38:44.562 | Denali Data Feed | Clearing market depth for CLK26_FUT_CME
2026-04-10 11:38:44.563 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\CLK26_FUT_CME.2026-04-10.depth
2026-04-10 11:38:44.563 | Denali Data Feed | Setting external service identifier for symbol CLK26_FUT_CME to 169926
2026-04-10 11:38:44.563 | Denali Data Feed | Received security definition for symbol CLK26_FUT_CME
2026-04-10 11:38:44.563 | Denali Data Feed | Clearing market depth for ESm26_FUT_CME
2026-04-10 11:38:44.563 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESm26_FUT_CME.2026-04-10.depth
2026-04-10 11:38:44.563 | Denali Data Feed | Setting external service identifier for symbol ESm26_FUT_CME to 42140864
2026-04-10 11:38:44.563 | Denali Data Feed | Received security definition for symbol ESm26_FUT_CME
2026-04-10 11:38:46.490 | Denali Data Feed | Connecting to the server ds31.sierracharts.com. Port 10047
2026-04-10 11:38:46.491 | DTC Client socket (2) | Creating socket.
2026-04-10 11:38:46.491 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:38:46.491 | DTC Client socket (2) | Connecting to IP: 64.152.155.116.
2026-04-10 11:38:46.607 | Denali Data Feed | Network connection to server complete.
2026-04-10 11:38:46.607 | Denali Data Feed | Starting socket receive thread.
2026-04-10 11:38:46.607 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2026-04-10 11:38:46.756 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-04-10 11:38:46.756 | Denali Data Feed | Sending logon request message.
2026-04-10 11:38:46.956 | Denali Data Feed | Received logon response.
2026-04-10 11:38:46.956 | Denali Data Feed | Server Name: SC Realtime Server.
2026-04-10 11:38:46.956 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:38:46.956 | Denali Data Feed | Successfully connected.
2026-04-10 11:38:46.956 | Denali Data Feed | Trading is not supported.
2026-04-10 11:38:46.956 | Denali Data Feed | MarketDepthIsSupported: 1
2026-04-10 11:38:46.956 | Denali Data Feed | Restarting real-time data updates for symbol: VIX_CGI -> VIX_CGI
2026-04-10 11:38:46.956 | Denali Data Feed | Restarting real-time data updates for symbol: VVIX_CGI -> VVIX_CGI
2026-04-10 11:38:47.196 | Denali Data Feed | Setting external service identifier for symbol VIX_CGI to 1392
2026-04-10 11:38:47.196 | Denali Data Feed | Received security definition for symbol VIX_CGI
2026-04-10 11:38:47.196 | Denali Data Feed | Setting external service identifier for symbol VVIX_CGI to 1408
2026-04-10 11:38:47.196 | Denali Data Feed | Received security definition for symbol VVIX_CGI
2026-04-10 11:38:49.314 | HD Request # 8 | Downloading Intraday chart data for ESm26_FUT_CME to the file ESm26_FUT_CME.scid. Service: cme
2026-04-10 11:38:49.315 | HD Request # 8 | Download start date-time: 2026-04-10 11:38:02.000000. File last date-time: 2026-04-10 11:38:02.050002
2026-04-10 11:38:49.315 | HD Request # 8 | Using server: ds26.sierracharts.com port 10149
2026-04-10 11:38:49.315 | Socket (4) | Creating socket.
2026-04-10 11:38:49.315 | Socket (4) | New receive buffer size: 0
2026-04-10 11:38:49.315 | Socket (4) | Connecting to IP: 64.152.155.17.
2026-04-10 11:38:49.549 | HD Request # 8 | Setting DTC encoding to Binary VLS
2026-04-10 11:38:49.549 | HD Request # 8 | Sending historical data logon request message.
2026-04-10 11:38:49.696 | HD Request # 8 | Requesting Intraday data. Start date-time: 2026-04-10 11:38:02. Record interval: 0. Symbol: ESM26
2026-04-10 11:38:49.812 | HD Request # 8 | Decompressing data.
2026-04-10 11:38:49.929 | HD Request # 8 | Receiving Intraday data for ESm26_FUT_CME starting at 2026-04-10 11:38:02.050000
2026-04-10 11:38:49.929 | Socket (4) | CloseSocket call.
2026-04-10 11:38:49.929 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-04-10 11:38:49.955 | Historical data download thread signaled to stop.
2026-04-10 11:38:49.955 | HD Request # 8 | Timestamp of first Intraday data file record written: 2026-04-10 11:38:04.424000.
2026-04-10 11:38:49.955 | HD Request # 8 | Received 106 Intraday data records from 2026-04-10 11:38:02.050000 to 2026-04-10 11:38:46.983000 (44.9 seconds. Delay: 3.0 seconds) and wrote 103 records for ESm26_FUT_CME
2026-04-10 11:38:49.960 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:38:46.983000
2026-04-10 11:38:49.960 | Added 2 Time and Sales records to Intraday data file for ESm26_FUT_CME after download.
2026-04-10 11:38:49.960 | HD Request # 8 | Completion time: 0s.
2026-04-10 11:38:49.960 | HD Request # 8 | Intraday data download complete for ESm26_FUT_CME. Unique request ID: 7
2026-04-10 11:38:49.960 | Removing historical data download ID 7.
2026-04-10 11:38:49.960 | Real-time Intraday chart data file updates started for ESm26_FUT_CME
2026-04-10 11:38:49.960 | Intraday chart data file opened for ESm26_FUT_CME
2026-04-10 11:38:49.960 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2026-04-10 11:38:49.960 | Triggering next historical data download in queue.
2026-04-10 11:38:49.960 | HD Request # 9 | Downloading Intraday chart data for CLK26_FUT_CME to the file CLK26_FUT_CME.scid. Service: nymex
2026-04-10 11:38:49.960 | HD Request # 9 | Download start date-time: 2026-04-10 11:38:02.000000. File last date-time: 2026-04-10 11:38:02.233000
2026-04-10 11:38:49.960 | HD Request # 9 | Using server: ds32.sierracharts.com port 10150
2026-04-10 11:38:49.960 | Socket (5) | Creating socket.
2026-04-10 11:38:49.960 | Socket (5) | New receive buffer size: 0
2026-04-10 11:38:49.960 | Socket (5) | Connecting to IP: 69.39.70.248.
2026-04-10 11:38:50.045 | Socket (4) | Socket gracefully closed by remote side.
2026-04-10 11:38:50.045 | Socket (4) | Closed.
2026-04-10 11:38:50.197 | HD Request # 9 | Setting DTC encoding to Binary VLS
2026-04-10 11:38:50.197 | HD Request # 9 | Sending historical data logon request message.
2026-04-10 11:38:50.344 | HD Request # 9 | Requesting Intraday data. Start date-time: 2026-04-10 11:38:02. Record interval: 0. Symbol: CLK26
2026-04-10 11:38:50.463 | HD Request # 9 | Decompressing data.
2026-04-10 11:38:50.580 | HD Request # 9 | Receiving Intraday data for CLK26_FUT_CME starting at 2026-04-10 11:38:02.048000
2026-04-10 11:38:50.580 | Socket (5) | CloseSocket call.
2026-04-10 11:38:50.580 | Socket (5) | Shutdown started. Waiting for graceful close.
2026-04-10 11:38:50.590 | Historical data download thread signaled to stop.
2026-04-10 11:38:50.590 | HD Request # 9 | Timestamp of first Intraday data file record written: 2026-04-10 11:38:04.886000.
2026-04-10 11:38:50.590 | HD Request # 9 | Received 61 Intraday data records from 2026-04-10 11:38:02.048000 to 2026-04-10 11:38:46.148000 (44.1 seconds. Delay: 4.4 seconds) and wrote 53 records for CLK26_FUT_CME
2026-04-10 11:38:50.595 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:38:46.148000
2026-04-10 11:38:50.595 | HD Request # 9 | Completion time: 1s.
2026-04-10 11:38:50.595 | HD Request # 9 | Intraday data download complete for CLK26_FUT_CME. Unique request ID: 8
2026-04-10 11:38:50.595 | Removing historical data download ID 8.
2026-04-10 11:38:50.595 | Real-time Intraday chart data file updates started for CLK26_FUT_CME
2026-04-10 11:38:50.595 | Intraday chart data file opened for CLK26_FUT_CME
2026-04-10 11:38:50.595 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2026-04-10 11:38:50.595 | No download requests in the queue to start downloads for.
2026-04-10 11:38:50.697 | Socket (5) | Socket gracefully closed by remote side.
2026-04-10 11:38:50.697 | Socket (5) | Closed.
2026-04-10 11:38:51.831 | Opened cached Intraday file: C:\SierraChart\Data\ESm26_FUT_CME.scid. Thread ID: 53036
2026-04-10 11:38:56.834 | Opened cached Intraday file: C:\SierraChart\Data\CLK26_FUT_CME.scid. Thread ID: 53036
2026-04-10 11:38:59.901 | HD Request # 10 | Downloading Intraday chart data for VIX/VVIX to the file VIX[VVIX.scid. Service:
2026-04-10 11:38:59.901 | HD Request # 10 | Download start date-time: 2026-04-10 11:30:46.000000. File last date-time: 2026-04-10 11:30:46.314000
2026-04-10 11:38:59.901 | HD Request # 10 | Initiating download of VIX_CGI for VIX/VVIX.
2026-04-10 11:38:59.901 | Added historical Intraday data request for VIX_CGI to the queue.
2026-04-10 11:38:59.901 | Intraday data recording state for symbol VIX_CGI is set to download 'Pending'.
2026-04-10 11:38:59.901 | Triggering next historical data download in queue.
2026-04-10 11:38:59.901 | HD Request # 10 | Initiating download of VVIX_CGI for VIX/VVIX.
2026-04-10 11:38:59.901 | Added historical Intraday data request for VVIX_CGI to the queue.
2026-04-10 11:38:59.901 | Intraday data recording state for symbol VVIX_CGI is set to download 'Pending'.
2026-04-10 11:38:59.901 | HD Request # 11 | Downloading Intraday chart data for VIX_CGI to the file VIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:38:59.901 | HD Request # 11 | Download start date-time: 2026-04-10 11:38:01.000000. File last date-time: 2026-04-10 11:38:01.325000
2026-04-10 11:38:59.901 | HD Request # 11 | Using server: ds33.sierracharts.com port 10149
2026-04-10 11:38:59.901 | Socket (4) | Creating socket.
2026-04-10 11:38:59.901 | Socket (4) | New receive buffer size: 0
2026-04-10 11:38:59.901 | Socket (4) | Connecting to IP: 69.39.70.245.
2026-04-10 11:39:00.155 | HD Request # 11 | Setting DTC encoding to Binary VLS
2026-04-10 11:39:00.155 | HD Request # 11 | Sending historical data logon request message.
2026-04-10 11:39:00.312 | HD Request # 11 | Requesting Intraday data. Start date-time: 2026-04-10 11:38:01. Record interval: 0. Symbol: VIX_CGI
2026-04-10 11:39:00.437 | HD Request # 11 | Decompressing data.
2026-04-10 11:39:00.563 | HD Request # 11 | Receiving Intraday data for VIX_CGI starting at 2026-04-10 11:38:01.325000
2026-04-10 11:39:00.563 | Socket (4) | CloseSocket call.
2026-04-10 11:39:00.563 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-04-10 11:39:00.563 | Historical data download thread signaled to stop.
2026-04-10 11:39:00.563 | HD Request # 11 | Timestamp of first Intraday data file record written: 2026-04-10 11:38:16.316000.
2026-04-10 11:39:00.563 | HD Request # 11 | Received 4 Intraday data records from 2026-04-10 11:38:01.325000 to 2026-04-10 11:38:46.223000 (44.9 seconds. Delay: 14.3 seconds) and wrote 3 records for VIX_CGI
2026-04-10 11:39:00.567 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:38:46.223000
2026-04-10 11:39:00.567 | HD Request # 11 | Completion time: 1s.
2026-04-10 11:39:00.567 | HD Request # 11 | Intraday data download complete for VIX_CGI. Unique request ID: 9
2026-04-10 11:39:00.567 | Removing historical data download ID 9.
2026-04-10 11:39:00.567 | Real-time Intraday chart data file updates started for VIX_CGI
2026-04-10 11:39:00.567 | Intraday chart data file opened for VIX_CGI
2026-04-10 11:39:00.567 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2026-04-10 11:39:00.567 | Triggering next historical data download in queue.
2026-04-10 11:39:00.567 | HD Request # 12 | Downloading Intraday chart data for VVIX_CGI to the file VVIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:39:00.567 | HD Request # 12 | Download start date-time: 2026-04-09 22:15:01.000000. File last date-time: 2026-04-09 22:15:01.163000
2026-04-10 11:39:00.567 | HD Request # 12 | Using server: ds31.sierracharts.com port 10150
2026-04-10 11:39:00.568 | Socket (5) | Creating socket.
2026-04-10 11:39:00.568 | Socket (5) | New receive buffer size: 0
2026-04-10 11:39:00.568 | Socket (5) | Connecting to IP: 64.152.155.116.
2026-04-10 11:39:00.688 | Socket (4) | Socket gracefully closed by remote side.
2026-04-10 11:39:00.688 | Socket (4) | Closed.
2026-04-10 11:39:01.840 | Opened cached Intraday file: C:\SierraChart\Data\VIX_CGI.scid. Thread ID: 53036
2026-04-10 11:39:21.600 | Socket (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:39:21.601 | Socket (5) | CloseSocket call.
2026-04-10 11:39:21.601 | Socket (0) | CloseSocket call.
2026-04-10 11:39:21.601 | Socket (5) | Closed.
2026-04-10 11:39:21.601 | HD Request # 12 | Error downloading historical Intraday data for VVIX_CGI. The network socket has been closed. Retrying download.
2026-04-10 11:39:21.601 | Added historical Intraday data request for VVIX_CGI to the queue.
2026-04-10 11:39:21.601 | Triggering next historical data download in queue.
2026-04-10 11:39:21.601 | Historical data download thread signaled to stop.
2026-04-10 11:39:21.601 | HD Request # 12 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for VVIX_CGI
2026-04-10 11:39:21.601 | HD Request # 12 | Completion time: 21s.
2026-04-10 11:39:21.601 | HD Request # 13 | Downloading Intraday chart data for VVIX_CGI to the file VVIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:39:21.601 | HD Request # 13 | Download start date-time: 2026-04-09 22:15:01.000000. File last date-time: 2026-04-09 22:15:01.163000
2026-04-10 11:39:21.601 | HD Request # 13 | Using server: ds30.sierracharts.com port 10149
2026-04-10 11:39:21.601 | Socket (5) | Creating socket.
2026-04-10 11:39:21.601 | Socket (5) | New receive buffer size: 0
2026-04-10 11:39:21.601 | Socket (5) | Connecting to IP: 67.214.125.11.
2026-04-10 11:39:21.845 | HD Request # 13 | Setting DTC encoding to Binary VLS
2026-04-10 11:39:21.845 | HD Request # 13 | Sending historical data logon request message.
2026-04-10 11:39:21.997 | HD Request # 13 | Requesting Intraday data. Start date-time: 2026-04-09 22:15:01. Record interval: 0. Symbol: VVIX_CGI
2026-04-10 11:39:22.118 | HD Request # 13 | Decompressing data.
2026-04-10 11:39:22.240 | HD Request # 13 | Receiving Intraday data for VVIX_CGI starting at 2026-04-09 22:15:01.163000
2026-04-10 11:39:22.240 | Socket (5) | CloseSocket call.
2026-04-10 11:39:22.240 | Socket (5) | Shutdown started. Waiting for graceful close.
2026-04-10 11:39:22.240 | Historical data download thread signaled to stop.
2026-04-10 11:39:22.240 | HD Request # 13 | Received 1 Intraday data record from 2026-04-09 22:15:01.163000 to 2026-04-09 22:15:01.163000 (0.0 seconds. Delay: 13.4 hours) and wrote 0 records for VVIX_CGI
2026-04-10 11:39:22.240 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2026-04-09 20:15:01.163000
2026-04-10 11:39:22.240 | HD Request # 13 | Completion time: 1s.
2026-04-10 11:39:22.240 | HD Request # 13 | Intraday data download complete for VVIX_CGI. Unique request ID: 10
2026-04-10 11:39:22.240 | Removing historical data download ID 10.
2026-04-10 11:39:22.240 | HD Request # 10 | Calculating bar data for VIX/VVIX.
2026-04-10 11:39:22.240 | Real-time Intraday chart data file updates started for VVIX_CGI
2026-04-10 11:39:22.240 | Intraday chart data file opened for VVIX_CGI
2026-04-10 11:39:22.240 | HD Request # 13 | Enabling Intraday chart updating for symbol.
2026-04-10 11:39:22.240 | No download requests in the queue to start downloads for.
2026-04-10 11:39:22.247 | HD Request # 10 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for VIX/VVIX
2026-04-10 11:39:22.247 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:30:46.314000
2026-04-10 11:39:22.247 | HD Request # 10 | Receiving Intraday data for VIX/VVIX starting at 2026-04-10 11:39:01.314000
2026-04-10 11:39:22.247 | Added 2 Time and Sales records to Intraday data file for VIX/VVIX after download.
2026-04-10 11:39:22.247 | HD Request # 10 | Timestamp of first Intraday data file record written: 2026-04-10 11:39:01.314000.
2026-04-10 11:39:22.248 | HD Request # 10 | Completion time: 23s.
2026-04-10 11:39:22.248 | HD Request # 10 | Intraday data download complete for VIX/VVIX. Unique request ID: 6
2026-04-10 11:39:22.248 | Removing historical data download ID 6.
2026-04-10 11:39:22.248 | Real-time Intraday chart data file updates started for VIX/VVIX
2026-04-10 11:39:22.248 | Intraday chart data file opened for VIX/VVIX
2026-04-10 11:39:22.248 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2026-04-10 11:39:22.248 | No download requests in the queue to start downloads for.
2026-04-10 11:39:22.361 | Socket (5) | Socket gracefully closed by remote side.
2026-04-10 11:39:22.361 | Socket (5) | Closed.
2026-04-10 11:39:36.892 | Opened cached Intraday file: C:\SierraChart\Data\VIX[VVIX.scid. Thread ID: 53036
2026-04-10 11:39:39.740 | Teton CME Routing | There has been no activity on the network socket for 46s. Will reconnect.
2026-04-10 11:39:39.740 | Connection to the external service has been lost.
2026-04-10 11:39:39.756 | Teton CME Routing | Waiting for socket receive thread to end
2026-04-10 11:39:39.756 | DTC Client socket (1) | CloseSocket call.
2026-04-10 11:39:39.756 | DTC Client socket (1) | Max send buffers used during socket life: 4
2026-04-10 11:39:39.756 | DTC Client socket (1) | Max send buffer size during socket life: 265
2026-04-10 11:39:39.756 | DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0
2026-04-10 11:39:39.756 | Teton CME Routing | Disconnected.
2026-04-10 11:39:39.756 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:39:41.765 |
2026-04-10 11:39:41.765 | Teton CME Routing | Firm: AMP
2026-04-10 11:39:41.765 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:39:41.765 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2026-04-10 11:39:41.765 | DTC Client socket (4) | New receive buffer size: 0
2026-04-10 11:39:41.765 | DTC Client socket (4) | Connecting to IP: 4.8.170.26.
2026-04-10 11:39:43.566 | DTC Client socket (1) | Write has completed. Shutdown being performed.
2026-04-10 11:39:43.566 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-04-10 11:39:43.566 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-04-10 11:39:43.566 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-04-10 11:39:43.566 | DTC Client socket (1) | Closed.
2026-04-10 11:39:44.917 | Teton CME Routing | Network connection to server complete.
2026-04-10 11:39:44.917 | Teton CME Routing | Starting socket receive thread.
2026-04-10 11:39:44.917 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-04-10 11:39:47.088 | Teton CME Routing | Setting DTC encoding to Binary VLS
2026-04-10 11:39:47.088 | Teton CME Routing | Sending logon request message.
2026-04-10 11:39:47.282 | Teton CME Routing | Received logon response.
2026-04-10 11:39:47.282 | Teton CME Routing | Server Name: SC DTC Server. Build=55065.
2026-04-10 11:39:47.282 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:39:47.282 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2026-04-10 11:39:47.282 | Teton CME Routing | Trading is supported.
2026-04-10 11:39:47.282 | Teton CME Routing | Order cancel and replace is supported.
2026-04-10 11:39:47.282 | Teton CME Routing | OCO Orders supported.
2026-04-10 11:39:47.282 | Teton CME Routing | Bracket Orders supported.
2026-04-10 11:39:47.282 | Teton CME Routing | MarketDepthIsSupported: 1
2026-04-10 11:39:47.282 | Teton CME Routing | Connection to server complete.
2026-04-10 11:39:47.282 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-04-10 11:39:47.282 | Updated verified funded futures trading account ending date to: 2026-05-10 09:39:47
2026-04-10 11:39:47.282 | Teton CME Routing | Performing query for most recent Order Activity Date-Time.
2026-04-10 11:39:47.288 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-04-09 20:05:38.366553
2026-04-10 11:39:48.088 | Updated verified funded futures trading account ending date to: 2026-05-10 09:39:48
2026-04-10 11:40:03.442 | Denali Data Feed | There has been no activity on the network socket for 46s. Will reconnect.
2026-04-10 11:40:03.442 | Denali Data Feed | Waiting for socket receive thread to end
2026-04-10 11:40:03.442 | DTC Client socket (3) | CloseSocket call.
2026-04-10 11:40:03.442 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:40:03.442 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-04-10 11:40:03.442 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2026-04-10 11:40:06.447 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443
2026-04-10 11:40:06.448 | DTC Client socket (5) | Creating socket.
2026-04-10 11:40:06.448 | DTC Client socket (5) | New receive buffer size: 0
2026-04-10 11:40:06.448 | DTC Client socket (5) | Connecting to IP: 64.152.155.18.
2026-04-10 11:40:22.418 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-04-10 11:40:22.418 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-04-10 11:40:22.418 | DTC Client socket (3) | Closed.
2026-04-10 11:40:27.485 | DTC Client socket (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:40:27.485 | DTC Client socket (5) | CloseSocket call.
2026-04-10 11:40:27.485 | Denali Data Feed | Failed connections: 1
2026-04-10 11:40:27.485 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:40:27.485 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:40:27.485 | DTC Client socket (5) | Closed.
2026-04-10 11:40:27.485 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-04-10 11:40:30.479 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048
2026-04-10 11:40:30.479 | DTC Client socket (3) | Creating socket.
2026-04-10 11:40:30.479 | DTC Client socket (3) | New receive buffer size: 0
2026-04-10 11:40:30.479 | DTC Client socket (3) | Connecting to IP: 67.214.125.6.
2026-04-10 11:40:30.597 | Denali Data Feed | Network connection to server complete.
2026-04-10 11:40:30.597 | Denali Data Feed | Starting socket receive thread.
2026-04-10 11:40:30.597 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-04-10 11:40:30.750 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-04-10 11:40:30.750 | Denali Data Feed | Sending logon request message.
2026-04-10 11:40:31.280 | Denali Data Feed | Received logon response.
2026-04-10 11:40:31.280 | Denali Data Feed | Server Name: SC Realtime Server.
2026-04-10 11:40:31.280 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:40:31.280 | Denali Data Feed | Successfully connected.
2026-04-10 11:40:31.280 | Denali Data Feed | Trading is not supported.
2026-04-10 11:40:31.280 | Denali Data Feed | MarketDepthIsSupported: 1
2026-04-10 11:40:31.280 | Added historical Intraday data request for CLK26_FUT_CME to the queue.
2026-04-10 11:40:31.280 | Intraday data recording state for symbol CLK26_FUT_CME is set to download 'Pending'.
2026-04-10 11:40:31.280 | Triggering next historical data download in queue.
2026-04-10 11:40:31.280 | Denali Data Feed | Restarting real-time data updates for symbol: CLK26_FUT_CME -> CLK26. Market Depth data restarted.
2026-04-10 11:40:31.280 | Added historical Intraday data request for ESm26_FUT_CME to the queue.
2026-04-10 11:40:31.280 | Intraday data recording state for symbol ESm26_FUT_CME is set to download 'Pending'.
2026-04-10 11:40:31.280 | Denali Data Feed | Restarting real-time data updates for symbol: ESm26_FUT_CME -> ESM26. Market Depth data restarted.
2026-04-10 11:40:31.280 | HD Request # 14 | Downloading Intraday chart data for CLK26_FUT_CME to the file CLK26_FUT_CME.scid. Service: nymex
2026-04-10 11:40:31.286 | HD Request # 14 | Download start date-time: 2026-04-10 11:39:16.000000. File last date-time: 2026-04-10 11:39:16.620000
2026-04-10 11:40:31.286 | HD Request # 14 | Using server: ds28.sierracharts.com port 10150
2026-04-10 11:40:31.286 | Socket (5) | Creating socket.
2026-04-10 11:40:31.286 | Socket (5) | New receive buffer size: 0
2026-04-10 11:40:31.286 | Socket (5) | Connecting to IP: 67.214.125.5.
2026-04-10 11:40:31.501 | Denali Data Feed | Clearing market depth for CLK26_FUT_CME
2026-04-10 11:40:31.501 | Denali Data Feed | Setting external service identifier for symbol CLK26_FUT_CME to 169926
2026-04-10 11:40:31.501 | Denali Data Feed | Received security definition for symbol CLK26_FUT_CME
2026-04-10 11:40:31.501 | Denali Data Feed | Clearing market depth for ESm26_FUT_CME
2026-04-10 11:40:31.501 | Denali Data Feed | Setting external service identifier for symbol ESm26_FUT_CME to 42140864
2026-04-10 11:40:31.501 | Denali Data Feed | Received security definition for symbol ESm26_FUT_CME
2026-04-10 11:40:31.523 | HD Request # 14 | Setting DTC encoding to Binary VLS
2026-04-10 11:40:31.523 | HD Request # 14 | Sending historical data logon request message.
2026-04-10 11:40:31.672 | HD Request # 14 | Requesting Intraday data. Start date-time: 2026-04-10 11:39:16. Record interval: 0. Symbol: CLK26
2026-04-10 11:40:31.790 | HD Request # 14 | Decompressing data.
2026-04-10 11:40:31.907 | HD Request # 14 | Receiving Intraday data for CLK26_FUT_CME starting at 2026-04-10 11:39:16.620000
2026-04-10 11:40:31.907 | Socket (5) | CloseSocket call.
2026-04-10 11:40:31.907 | Socket (5) | Shutdown started. Waiting for graceful close.
2026-04-10 11:40:31.907 | Historical data download thread signaled to stop.
2026-04-10 11:40:31.908 | HD Request # 14 | Timestamp of first Intraday data file record written: 2026-04-10 11:39:17.956000.
2026-04-10 11:40:31.908 | HD Request # 14 | Received 89 Intraday data records from 2026-04-10 11:39:16.620000 to 2026-04-10 11:40:30.069000 (73.4 seconds. Delay: 1.8 seconds) and wrote 88 records for CLK26_FUT_CME
2026-04-10 11:40:31.913 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:40:30.069000
2026-04-10 11:40:31.913 | HD Request # 14 | Completion time: 0s.
2026-04-10 11:40:31.913 | HD Request # 14 | Intraday data download complete for CLK26_FUT_CME. Unique request ID: 11
2026-04-10 11:40:31.913 | Removing historical data download ID 11.
2026-04-10 11:40:31.913 | Real-time Intraday chart data file updates started for CLK26_FUT_CME
2026-04-10 11:40:31.913 | Intraday chart data file opened for CLK26_FUT_CME
2026-04-10 11:40:31.913 | HD Request # 14 | Enabling Intraday chart updating for symbol.
2026-04-10 11:40:31.913 | Triggering next historical data download in queue.
2026-04-10 11:40:31.913 | HD Request # 15 | Downloading Intraday chart data for ESm26_FUT_CME to the file ESm26_FUT_CME.scid. Service: cme
2026-04-10 11:40:31.913 | HD Request # 15 | Download start date-time: 2026-04-10 11:39:16.000000. File last date-time: 2026-04-10 11:39:16.629000
2026-04-10 11:40:31.913 | HD Request # 15 | Using server: ds26.sierracharts.com port 10149
2026-04-10 11:40:31.913 | Socket (6) | Creating socket.
2026-04-10 11:40:31.913 | Socket (6) | New receive buffer size: 0
2026-04-10 11:40:31.913 | Socket (6) | Connecting to IP: 64.152.155.17.
2026-04-10 11:40:32.024 | Socket (5) | Socket gracefully closed by remote side.
2026-04-10 11:40:32.024 | Socket (5) | Closed.
2026-04-10 11:40:36.991 | Opened cached Intraday file: C:\SierraChart\Data\CLK26_FUT_CME.scid. Thread ID: 53036
2026-04-10 11:40:46.306 | ESM26_FUT_CME Rev. 10t #2 | Reloading chart.
2026-04-10 11:40:46.392 | ESM26_FUT_CME 60 Min #6 | Reloading chart.
2026-04-10 11:40:47.633 | ESM26_FUT_CME[M] 60 Min #6 | Chart data loading complete.
2026-04-10 11:40:49.048 | Loading market depth data.
2026-04-10 11:40:50.709 | Loaded depth data records for ESM26_FUT_CME 2026-03-31 from 2026-03-31 11:39:16.632000 to 2026-04-01 00:16:34.050163.
2026-04-10 11:40:51.364 | Loaded depth data records for ESM26_FUT_CME 2026-04-01 from 2026-04-01 10:18:45.304000 to 2026-04-01 21:47:32.712515.
2026-04-10 11:40:52.115 | Loaded depth data records for ESM26_FUT_CME 2026-04-02 from 2026-04-02 09:19:49.372000 to 2026-04-02 17:02:29.619549.
2026-04-10 11:40:52.133 | Loaded depth data records for ESM26_FUT_CME 2026-04-03 from 2026-04-03 08:29:54.355000 to 2026-04-03 21:01:21.644704.
2026-04-10 11:40:52.134 | Loaded depth data records for ESM26_FUT_CME 2026-04-04 from 2026-04-04 06:26:16.159000 to 2026-04-04 21:51:53.086642.
2026-04-10 11:40:52.165 | Loaded depth data records for ESM26_FUT_CME 2026-04-06 from 2026-04-06 05:04:24.230000 to 2026-04-06 06:42:17.413000.
2026-04-10 11:40:52.178 | Loaded depth data records for ESM26_FUT_CME 2026-04-09 from 2026-04-09 21:44:43.730000 to 2026-04-09 23:55:05.002000.
2026-04-10 11:40:52.190 | Loaded depth data records for ESM26_FUT_CME 2026-04-10 from 2026-04-10 10:13:39.329000 to 2026-04-10 11:39:16.629000.
2026-04-10 11:40:52.190 | + Loading additional symbol data.
2026-04-10 11:40:52.204 | ESM26_FUT_CME[M] Rev. 10t #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-10 11:40:52.944 | Socket (6) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:40:52.944 | Socket (6) | CloseSocket call.
2026-04-10 11:40:52.944 | Socket (0) | CloseSocket call.
2026-04-10 11:40:52.944 | Socket (6) | Closed.
2026-04-10 11:40:56.312 | ESM26_FUT_CME[M] Rev. 10t #2 | Chart data loading complete.
2026-04-10 11:41:00.106 | HD Request # 15 | Error downloading historical Intraday data for ESm26_FUT_CME. The network socket has been closed. Retrying download.
2026-04-10 11:41:00.106 | Added historical Intraday data request for ESm26_FUT_CME to the queue.
2026-04-10 11:41:00.106 | Triggering next historical data download in queue.
2026-04-10 11:41:00.107 | Historical data download thread signaled to stop.
2026-04-10 11:41:00.107 | HD Request # 15 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESm26_FUT_CME
2026-04-10 11:41:00.107 | HD Request # 15 | Completion time: 29s.
2026-04-10 11:41:00.108 | HD Request # 16 | Downloading Intraday chart data for ESm26_FUT_CME to the file ESm26_FUT_CME.scid. Service: cme
2026-04-10 11:41:00.108 | HD Request # 16 | Download start date-time: 2026-04-10 11:39:16.000000. File last date-time: 2026-04-10 11:39:16.629000
2026-04-10 11:41:00.108 | HD Request # 16 | Using server: ds32.sierracharts.com port 10150
2026-04-10 11:41:00.108 | Socket (1) | Creating socket.
2026-04-10 11:41:00.108 | Socket (1) | New receive buffer size: 0
2026-04-10 11:41:00.108 | Socket (1) | Connecting to IP: 69.39.70.248.
2026-04-10 11:41:00.344 | HD Request # 16 | Setting DTC encoding to Binary VLS
2026-04-10 11:41:00.344 | HD Request # 16 | Sending historical data logon request message.
2026-04-10 11:41:00.493 | HD Request # 16 | Requesting Intraday data. Start date-time: 2026-04-10 11:39:16. Record interval: 0. Symbol: ESM26
2026-04-10 11:41:00.610 | HD Request # 16 | Decompressing data.
2026-04-10 11:41:00.728 | HD Request # 16 | Receiving Intraday data for ESm26_FUT_CME starting at 2026-04-10 11:39:16.172000
2026-04-10 11:41:00.728 | Socket (1) | CloseSocket call.
2026-04-10 11:41:00.728 | Socket (1) | Shutdown started. Waiting for graceful close.
2026-04-10 11:41:00.845 | Socket (1) | Socket gracefully closed by remote side.
2026-04-10 11:41:00.845 | Socket (1) | Closed.
2026-04-10 11:41:03.502 | Historical data download thread signaled to stop.
2026-04-10 11:41:03.502 | HD Request # 16 | Timestamp of first Intraday data file record written: 2026-04-10 11:39:17.329000.
2026-04-10 11:41:03.502 | HD Request # 16 | Received 365 Intraday data records from 2026-04-10 11:39:16.172000 to 2026-04-10 11:40:59.018000 (102.8 seconds. Delay: 4.5 seconds) and wrote 363 records for ESm26_FUT_CME
2026-04-10 11:41:03.508 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:40:59.018000
2026-04-10 11:41:03.508 | Added 10 Time and Sales records to Intraday data file for ESm26_FUT_CME after download.
2026-04-10 11:41:03.508 | HD Request # 16 | Completion time: 3s.
2026-04-10 11:41:03.508 | HD Request # 16 | Intraday data download complete for ESm26_FUT_CME. Unique request ID: 12
2026-04-10 11:41:03.508 | Removing historical data download ID 12.
2026-04-10 11:41:03.508 | Real-time Intraday chart data file updates started for ESm26_FUT_CME
2026-04-10 11:41:03.508 | Intraday chart data file opened for ESm26_FUT_CME
2026-04-10 11:41:03.508 | HD Request # 16 | Enabling Intraday chart updating for symbol.
2026-04-10 11:41:03.508 | No download requests in the queue to start downloads for.
2026-04-10 11:41:07.034 | Opened cached Intraday file: C:\SierraChart\Data\ESm26_FUT_CME.scid. Thread ID: 53036
2026-04-10 11:41:55.045 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-04-10 11:41:55.045 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-04-10 11:41:55.048 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:41:55.048 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2026-04-10 11:41:55.049 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-04-10 11:41:55.049 | DTC Client socket (2) | Closed.
2026-04-10 11:41:55.049 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:41:55.049 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:41:55.049 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-04-10 11:41:58.070 | Denali Data Feed | Connecting to the server ds30.sierracharts.com. Port 10047
2026-04-10 11:41:58.073 | DTC Client socket (1) | Creating socket.
2026-04-10 11:41:58.073 | DTC Client socket (1) | New receive buffer size: 0
2026-04-10 11:41:58.073 | DTC Client socket (1) | Connecting to IP: 67.214.125.11.
2026-04-10 11:41:58.201 | Denali Data Feed | Network connection to server complete.
2026-04-10 11:41:58.201 | Denali Data Feed | Starting socket receive thread.
2026-04-10 11:41:58.201 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2026-04-10 11:41:58.399 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-04-10 11:41:58.399 | Denali Data Feed | Sending logon request message.
2026-04-10 11:41:58.715 | Denali Data Feed | Received logon response.
2026-04-10 11:41:58.715 | Denali Data Feed | Server Name: SC Realtime Server.
2026-04-10 11:41:58.715 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:41:58.715 | Denali Data Feed | Successfully connected.
2026-04-10 11:41:58.715 | Denali Data Feed | Trading is not supported.
2026-04-10 11:41:58.715 | Denali Data Feed | MarketDepthIsSupported: 1
2026-04-10 11:41:58.715 | Added historical Intraday data request for VIX_CGI to the queue.
2026-04-10 11:41:58.715 | Intraday data recording state for symbol VIX_CGI is set to download 'Pending'.
2026-04-10 11:41:58.715 | Triggering next historical data download in queue.
2026-04-10 11:41:58.715 | Denali Data Feed | Restarting real-time data updates for symbol: VIX_CGI -> VIX_CGI
2026-04-10 11:41:58.715 | Added historical Intraday data request for VVIX_CGI to the queue.
2026-04-10 11:41:58.715 | Intraday data recording state for symbol VVIX_CGI is set to download 'Pending'.
2026-04-10 11:41:58.715 | Denali Data Feed | Restarting real-time data updates for symbol: VVIX_CGI -> VVIX_CGI
2026-04-10 11:41:58.715 | HD Request # 17 | Downloading Intraday chart data for VIX_CGI to the file VIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:41:58.722 | HD Request # 17 | Download start date-time: 2026-04-10 11:41:01.000000. File last date-time: 2026-04-10 11:41:01.328000
2026-04-10 11:41:58.722 | HD Request # 17 | Using server: ds33.sierracharts.com port 10149
2026-04-10 11:41:58.722 | Socket (2) | Creating socket.
2026-04-10 11:41:58.722 | Socket (2) | New receive buffer size: 0
2026-04-10 11:41:58.722 | Socket (2) | Connecting to IP: 69.39.70.245.
2026-04-10 11:41:58.934 | Denali Data Feed | Setting external service identifier for symbol VIX_CGI to 1348
2026-04-10 11:41:58.934 | Denali Data Feed | Received security definition for symbol VIX_CGI
2026-04-10 11:41:58.934 | Denali Data Feed | Setting external service identifier for symbol VVIX_CGI to 1364
2026-04-10 11:41:58.934 | Denali Data Feed | Received security definition for symbol VVIX_CGI
2026-04-10 11:41:58.976 | HD Request # 17 | Setting DTC encoding to Binary VLS
2026-04-10 11:41:58.976 | HD Request # 17 | Sending historical data logon request message.
2026-04-10 11:41:59.128 | HD Request # 17 | Requesting Intraday data. Start date-time: 2026-04-10 11:41:01. Record interval: 0. Symbol: VIX_CGI
2026-04-10 11:41:59.253 | HD Request # 17 | Decompressing data.
2026-04-10 11:41:59.379 | HD Request # 17 | Receiving Intraday data for VIX_CGI starting at 2026-04-10 11:41:01.328000
2026-04-10 11:41:59.379 | Socket (2) | CloseSocket call.
2026-04-10 11:41:59.379 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-04-10 11:41:59.381 | Historical data download thread signaled to stop.
2026-04-10 11:41:59.381 | HD Request # 17 | Timestamp of first Intraday data file record written: 2026-04-10 11:41:16.314000.
2026-04-10 11:41:59.381 | HD Request # 17 | Received 4 Intraday data records from 2026-04-10 11:41:01.328000 to 2026-04-10 11:41:46.314000 (45.0 seconds. Delay: 13.1 seconds) and wrote 3 records for VIX_CGI
2026-04-10 11:41:59.387 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:41:46.314000
2026-04-10 11:41:59.387 | HD Request # 17 | Completion time: 1s.
2026-04-10 11:41:59.387 | HD Request # 17 | Intraday data download complete for VIX_CGI. Unique request ID: 13
2026-04-10 11:41:59.387 | Removing historical data download ID 13.
2026-04-10 11:41:59.387 | Real-time Intraday chart data file updates started for VIX_CGI
2026-04-10 11:41:59.387 | Intraday chart data file opened for VIX_CGI
2026-04-10 11:41:59.387 | HD Request # 17 | Enabling Intraday chart updating for symbol.
2026-04-10 11:41:59.388 |
2026-04-10 11:41:59.388 | Triggering next historical data download in queue.
2026-04-10 11:41:59.388 | HD Request # 18 | Downloading Intraday chart data for VVIX_CGI to the file VVIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:41:59.388 | HD Request # 18 | Download start date-time: 2026-04-09 22:15:01.000000. File last date-time: 2026-04-09 22:15:01.163000
2026-04-10 11:41:59.388 | HD Request # 18 | Using server: ds31.sierracharts.com port 10150
2026-04-10 11:41:59.388 | Socket (5) | Creating socket.
2026-04-10 11:41:59.388 | Socket (5) | New receive buffer size: 0
2026-04-10 11:41:59.388 | Socket (5) | Connecting to IP: 64.152.155.116.
2026-04-10 11:41:59.504 | Socket (2) | Socket gracefully closed by remote side.
2026-04-10 11:41:59.504 | Socket (2) | Closed.
2026-04-10 11:42:02.116 | Opened cached Intraday file: C:\SierraChart\Data\VIX_CGI.scid. Thread ID: 53036
2026-04-10 11:42:20.409 | Socket (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:42:20.410 | Socket (5) | CloseSocket call.
2026-04-10 11:42:20.410 | Socket (0) | CloseSocket call.
2026-04-10 11:42:20.410 | Socket (5) | Closed.
2026-04-10 11:42:20.421 | HD Request # 18 | Error downloading historical Intraday data for VVIX_CGI. The network socket has been closed. Retrying download.
2026-04-10 11:42:20.421 | Added historical Intraday data request for VVIX_CGI to the queue.
2026-04-10 11:42:20.421 | Triggering next historical data download in queue.
2026-04-10 11:42:20.421 | Historical data download thread signaled to stop.
2026-04-10 11:42:20.421 | HD Request # 18 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for VVIX_CGI
2026-04-10 11:42:20.421 | HD Request # 18 | Completion time: 21s.
2026-04-10 11:42:20.421 | HD Request # 19 | Downloading Intraday chart data for VVIX_CGI to the file VVIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:42:20.421 | HD Request # 19 | Download start date-time: 2026-04-09 22:15:01.000000. File last date-time: 2026-04-09 22:15:01.163000
2026-04-10 11:42:20.421 | HD Request # 19 | Using server: ds30.sierracharts.com port 10149
2026-04-10 11:42:20.421 | Socket (2) | Creating socket.
2026-04-10 11:42:20.421 | Socket (2) | New receive buffer size: 0
2026-04-10 11:42:20.421 | Socket (2) | Connecting to IP: 67.214.125.11.
2026-04-10 11:42:20.665 | HD Request # 19 | Setting DTC encoding to Binary VLS
2026-04-10 11:42:20.665 | HD Request # 19 | Sending historical data logon request message.
2026-04-10 11:42:20.815 | HD Request # 19 | Requesting Intraday data. Start date-time: 2026-04-09 22:15:01. Record interval: 0. Symbol: VVIX_CGI
2026-04-10 11:42:20.936 | HD Request # 19 | Decompressing data.
2026-04-10 11:42:21.058 | HD Request # 19 | Receiving Intraday data for VVIX_CGI starting at 2026-04-09 22:15:01.163000
2026-04-10 11:42:21.058 | Socket (2) | CloseSocket call.
2026-04-10 11:42:21.058 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-04-10 11:42:21.060 | Historical data download thread signaled to stop.
2026-04-10 11:42:21.060 | HD Request # 19 | Received 1 Intraday data record from 2026-04-09 22:15:01.163000 to 2026-04-09 22:15:01.163000 (0.0 seconds. Delay: 13.5 hours) and wrote 0 records for VVIX_CGI
2026-04-10 11:42:21.060 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2026-04-09 20:15:01.163000
2026-04-10 11:42:21.060 | HD Request # 19 | Completion time: 1s.
2026-04-10 11:42:21.060 | HD Request # 19 | Intraday data download complete for VVIX_CGI. Unique request ID: 14
2026-04-10 11:42:21.060 | Removing historical data download ID 14.
2026-04-10 11:42:21.060 | Real-time Intraday chart data file updates started for VVIX_CGI
2026-04-10 11:42:21.060 | Intraday chart data file opened for VVIX_CGI
2026-04-10 11:42:21.060 | HD Request # 19 | Enabling Intraday chart updating for symbol.
2026-04-10 11:42:21.060 | No download requests in the queue to start downloads for.
2026-04-10 11:42:21.178 | Socket (2) | Socket gracefully closed by remote side.
2026-04-10 11:42:21.178 | Socket (2) | Closed.
2026-04-10 11:43:01.864 | Teton CME Routing | There has been no activity on the network socket for 1m 6s. Will reconnect.
2026-04-10 11:43:01.864 | Connection to the external service has been lost.
2026-04-10 11:43:01.888 | Teton CME Routing | Waiting for socket receive thread to end
2026-04-10 11:43:01.888 | DTC Client socket (4) | CloseSocket call.
2026-04-10 11:43:01.888 | Teton CME Routing | Disconnected.
2026-04-10 11:43:01.888 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:43:01.888 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2026-04-10 11:43:03.899 |
2026-04-10 11:43:03.899 | Teton CME Routing | Firm: AMP
2026-04-10 11:43:03.899 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:43:03.899 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:43:03.899 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:43:03.899 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:43:15.787 | DTC Client socket (4) | Socket gracefully closed by remote side.
2026-04-10 11:43:15.787 | DTC Client socket (4) | Closed.
2026-04-10 11:43:24.953 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
2026-04-10 11:43:25.056 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:43:25.056 | Teton CME Routing | Failed connections: 1
2026-04-10 11:43:25.056 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-04-10 11:43:25.056 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:43:25.056 | DTC Client socket (2) | Closed.
2026-04-10 11:43:25.089 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:43:25.089 | Teton CME Routing | Disconnected.
2026-04-10 11:43:25.089 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:43:25.100 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\CLK26_FUT_CME.2026-04-10.depth
2026-04-10 11:43:25.330 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESm26_FUT_CME.2026-04-10.depth
2026-04-10 11:43:27.208 |
2026-04-10 11:43:27.208 | Teton CME Routing | Firm: AMP
2026-04-10 11:43:27.208 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:43:27.208 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-04-10 11:43:27.208 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:43:27.208 | DTC Client socket (2) | Connecting to IP: 4.8.170.26.
2026-04-10 11:43:36.430 | Teton CME Routing | Network connection to server complete.
2026-04-10 11:43:36.430 | Teton CME Routing | Starting socket receive thread.
2026-04-10 11:43:36.430 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-04-10 11:43:56.446 | Teton CME Routing | Did not receive Encoding Response from server. Disconnecting. *
2026-04-10 11:43:56.446 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-04-10 11:43:56.446 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:43:56.477 | Teton CME Routing | Waiting for socket receive thread to end
2026-04-10 11:43:56.477 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:43:56.477 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-04-10 11:43:56.478 | Teton CME Routing | Disconnected.
2026-04-10 11:43:56.478 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-04-10 11:43:56.589 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESm26_FUT_CME.2026-04-10.depth
2026-04-10 11:43:56.701 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\CLK26_FUT_CME.2026-04-10.depth
2026-04-10 11:43:58.547 |
2026-04-10 11:43:58.547 | Teton CME Routing | Firm: AMP
2026-04-10 11:43:58.547 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066
2026-04-10 11:43:58.548 | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2026-04-10 11:43:58.548 | DTC Client socket (4) | New receive buffer size: 0
2026-04-10 11:43:58.548 | DTC Client socket (4) | Connecting to IP: 4.8.170.26.
2026-04-10 11:43:58.693 | Teton CME Routing | Network connection to server complete.
2026-04-10 11:43:58.693 | Teton CME Routing | Starting socket receive thread.
2026-04-10 11:43:58.694 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-04-10 11:43:59.473 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-04-10 11:43:59.473 | DTC Client socket (2) | Closed.
2026-04-10 11:44:00.139 | Teton CME Routing | Setting DTC encoding to Binary VLS
2026-04-10 11:44:00.139 | Teton CME Routing | Sending logon request message.
2026-04-10 11:44:01.148 | Teton CME Routing | Received logon response.
2026-04-10 11:44:01.148 | Teton CME Routing | Server Name: SC DTC Server. Build=55065.
2026-04-10 11:44:01.148 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:44:01.148 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2026-04-10 11:44:01.148 | Teton CME Routing | Trading is supported.
2026-04-10 11:44:01.148 | Teton CME Routing | Order cancel and replace is supported.
2026-04-10 11:44:01.148 | Teton CME Routing | OCO Orders supported.
2026-04-10 11:44:01.148 | Teton CME Routing | Bracket Orders supported.
2026-04-10 11:44:01.148 | Teton CME Routing | MarketDepthIsSupported: 1
2026-04-10 11:44:01.148 | Teton CME Routing | Connection to server complete.
2026-04-10 11:44:01.148 | Denali Data Feed | Waiting for socket receive thread to end
2026-04-10 11:44:01.148 | DTC Client socket (3) | CloseSocket call.
2026-04-10 11:44:01.148 | DTC Client socket (3) | Max send buffers used during socket life: 3
2026-04-10 11:44:01.148 | DTC Client socket (3) | Max send buffer size during socket life: 218
2026-04-10 11:44:01.148 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2026-04-10 11:44:01.148 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:44:01.148 | DTC Client socket (1) | CloseSocket call.
2026-04-10 11:44:01.148 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-04-10 11:44:01.149 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-04-10 11:44:01.149 | Updated verified funded futures trading account ending date to: 2026-05-10 09:44:01
2026-04-10 11:44:01.149 | Using symbol data fast lookup vector
2026-04-10 11:44:01.149 | Trace | Is a formula symbol.. Symbol: VIX/VVIX
2026-04-10 11:44:01.149 | Mapping VIX_CGI to VIX_CGI. Service code: cboe_global_indexes.data
2026-04-10 11:44:01.149 | Denali Data Feed | Starting real-time market data updates for: VIX_CGI (VIX_CGI). ID: 2 Service code: cboe_global_indexes.data
2026-04-10 11:44:01.149 | Denali Data Feed | Connecting to the server ds33.sierracharts.com. Port 10047
2026-04-10 11:44:01.149 | Denali Data Feed | Requesting security definition data for: VIX_CGI (VIX_CGI). ID: 2
2026-04-10 11:44:01.149 | Mapping VVIX_CGI to VVIX_CGI. Service code: cboe_global_indexes.data
2026-04-10 11:44:01.149 | Denali Data Feed | Starting real-time market data updates for: VVIX_CGI (VVIX_CGI). ID: 3 Service code: cboe_global_indexes.data
2026-04-10 11:44:01.149 | Denali Data Feed | Requesting security definition data for: VVIX_CGI (VVIX_CGI). ID: 3
2026-04-10 11:44:01.149 | Teton CME Routing | Not subscribing to real-time market data updates directly because it is a composite or formula symbol. VIX/VVIX. ID: 1
2026-04-10 11:44:01.149 | Added historical Intraday data request for VIX/VVIX to the queue.
2026-04-10 11:44:01.149 | Intraday data recording state for symbol VIX/VVIX is set to download 'Pending'.
2026-04-10 11:44:01.149 | Triggering next historical data download in queue.
2026-04-10 11:44:01.149 | ESM26_FUT_CME[M] Rev. 10t #2 | Started historical data download for additional symbol vix/vvix. Download ID: 15
2026-04-10 11:44:01.149 | DTC Client socket (2) | Creating socket.
2026-04-10 11:44:01.149 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:44:01.149 | DTC Client socket (2) | Connecting to IP: 69.39.70.245.
2026-04-10 11:44:01.151 | Teton CME Routing | Performing query for most recent Order Activity Date-Time.
2026-04-10 11:44:01.151 | Denali Data Feed | Failed connections: 1
2026-04-10 11:44:01.151 | DTC Client socket (2) | CloseSocket call.
2026-04-10 11:44:01.151 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:44:01.151 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-04-10 11:44:01.151 | Delaying start of download for VIX/VVIX.
2026-04-10 11:44:01.151 | DTC Client socket (2) | Closed.
2026-04-10 11:44:01.151 | Mapping ESM26_FUT_CME to ESM26. Service code: cme
2026-04-10 11:44:01.151 | Denali Data Feed | Starting real-time market data updates for: ESM26_FUT_CME (ESM26). ID: 4 Service code: cme
2026-04-10 11:44:01.151 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443
2026-04-10 11:44:01.151 | Denali Data Feed | Requesting security definition data for: ESM26_FUT_CME (ESM26). ID: 4
2026-04-10 11:44:01.151 | Requesting market depth updates for: ESM26_FUT_CME if supported. NumLevels=100
2026-04-10 11:44:01.151 | Added historical Intraday data request for ESM26_FUT_CME to the queue.
2026-04-10 11:44:01.151 | Intraday data recording state for symbol ESM26_FUT_CME is set to download 'Pending'.
2026-04-10 11:44:01.151 | Triggering next historical data download in queue.
2026-04-10 11:44:01.151 | DTC Client socket (2) | Creating socket.
2026-04-10 11:44:01.151 | DTC Client socket (2) | New receive buffer size: 0
2026-04-10 11:44:01.151 | DTC Client socket (2) | Connecting to IP: 67.214.125.6.
2026-04-10 11:44:01.175 | Delaying start of download for ESM26_FUT_CME.
2026-04-10 11:44:01.175 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-04-09 20:05:38.366553
2026-04-10 11:44:01.292 | Denali Data Feed | Network connection to server complete.
2026-04-10 11:44:01.292 | Denali Data Feed | Starting socket receive thread.
2026-04-10 11:44:01.292 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-04-10 11:44:01.385 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VIX_CGI. ID = 2
2026-04-10 11:44:01.385 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: VVIX_CGI. ID = 3
2026-04-10 11:44:01.416 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-04-10 11:44:01.416 | Denali Data Feed | Sending logon request message.
2026-04-10 11:44:01.430 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-04-10 11:44:01.430 | DTC Client socket (3) | Closed.
2026-04-10 11:44:01.434 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-04-10 11:44:01.434 | DTC Client socket (1) | Closed.
2026-04-10 11:44:01.978 | Denali Data Feed | Received logon response.
2026-04-10 11:44:01.978 | Denali Data Feed | Server Name: SC Realtime Server.
2026-04-10 11:44:01.978 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:44:01.978 | Denali Data Feed | Successfully connected.
2026-04-10 11:44:01.978 | Denali Data Feed | Trading is not supported.
2026-04-10 11:44:01.978 | Denali Data Feed | MarketDepthIsSupported: 1
2026-04-10 11:44:01.978 | Denali Data Feed | Restarting real-time data updates for symbol: ESM26_FUT_CME -> ESM26. Market Depth data restarted.
2026-04-10 11:44:02.197 | Denali Data Feed | Clearing market depth for ESM26_FUT_CME
2026-04-10 11:44:02.197 | Denali Data Feed | Setting external service identifier for symbol ESM26_FUT_CME to 42140864
2026-04-10 11:44:02.197 | Denali Data Feed | Received security definition for symbol ESM26_FUT_CME
2026-04-10 11:44:02.198 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM26_FUT_CME.2026-04-10.depth
2026-04-10 11:44:04.163 | Denali Data Feed | Connecting to the server ds31.sierracharts.com. Port 10047
2026-04-10 11:44:04.163 | DTC Client socket (1) | Creating socket.
2026-04-10 11:44:04.163 | DTC Client socket (1) | New receive buffer size: 0
2026-04-10 11:44:04.163 | DTC Client socket (1) | Connecting to IP: 64.152.155.116.
2026-04-10 11:44:04.288 | Denali Data Feed | Network connection to server complete.
2026-04-10 11:44:04.288 | Denali Data Feed | Starting socket receive thread.
2026-04-10 11:44:04.288 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2026-04-10 11:44:07.142 | Updated verified funded futures trading account ending date to: 2026-05-10 09:44:07
2026-04-10 11:44:07.142 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM26_FUT_CME
2026-04-10 11:44:07.142 | Teton CME Routing | Setting external service identifier for symbol ESM26_FUT_CME to 42140864
2026-04-10 11:44:07.142 | Teton CME Routing | Received security definition for symbol ESM26_FUT_CME
2026-04-10 11:44:07.433 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-04-10 11:44:07.433 | Denali Data Feed | Sending logon request message.
2026-04-10 11:44:07.730 | Denali Data Feed | Received logon response.
2026-04-10 11:44:07.730 | Denali Data Feed | Server Name: SC Realtime Server.
2026-04-10 11:44:07.730 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:44:07.730 | Denali Data Feed | Successfully connected.
2026-04-10 11:44:07.730 | Denali Data Feed | Trading is not supported.
2026-04-10 11:44:07.730 | Denali Data Feed | MarketDepthIsSupported: 1
2026-04-10 11:44:07.730 | Denali Data Feed | Restarting real-time data updates for symbol: VIX_CGI -> VIX_CGI
2026-04-10 11:44:07.730 | Denali Data Feed | Restarting real-time data updates for symbol: VVIX_CGI -> VVIX_CGI
2026-04-10 11:44:07.859 | HD Request # 20 | Downloading Intraday chart data for ESM26_FUT_CME to the file ESM26_FUT_CME.scid. Service: cme
2026-04-10 11:44:07.859 | HD Request # 20 | Download start date-time: 2026-04-10 11:43:23.000000. File last date-time: 2026-04-10 11:43:23.140000
2026-04-10 11:44:07.859 | HD Request # 20 | Using server: ds28.sierracharts.com port 10150
2026-04-10 11:44:07.859 | Socket (5) | Creating socket.
2026-04-10 11:44:07.859 | Socket (5) | New receive buffer size: 0
2026-04-10 11:44:07.859 | Socket (5) | Connecting to IP: 67.214.125.5.
2026-04-10 11:44:08.096 | HD Request # 20 | Setting DTC encoding to Binary VLS
2026-04-10 11:44:08.096 | HD Request # 20 | Sending historical data logon request message.
2026-04-10 11:44:08.245 | HD Request # 20 | Requesting Intraday data. Start date-time: 2026-04-10 11:43:23. Record interval: 0. Symbol: ESM26
2026-04-10 11:44:08.363 | HD Request # 20 | Decompressing data.
2026-04-10 11:44:08.480 | HD Request # 20 | Receiving Intraday data for ESM26_FUT_CME starting at 2026-04-10 11:43:23.140000
2026-04-10 11:44:08.480 | Socket (5) | CloseSocket call.
2026-04-10 11:44:08.480 | Socket (5) | Shutdown started. Waiting for graceful close.
2026-04-10 11:44:08.545 | Historical data download thread signaled to stop.
2026-04-10 11:44:08.545 | HD Request # 20 | Timestamp of first Intraday data file record written: 2026-04-10 11:43:27.007000.
2026-04-10 11:44:08.545 | HD Request # 20 | Received 85 Intraday data records from 2026-04-10 11:43:23.140000 to 2026-04-10 11:44:06.455001 (43.3 seconds. Delay: 2.1 seconds) and wrote 84 records for ESM26_FUT_CME
2026-04-10 11:44:08.550 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:44:06.455001
2026-04-10 11:44:08.551 | HD Request # 20 | Completion time: 1s.
2026-04-10 11:44:08.551 | HD Request # 20 | Intraday data download complete for ESM26_FUT_CME. Unique request ID: 16
2026-04-10 11:44:08.551 | Removing historical data download ID 16.
2026-04-10 11:44:08.551 | Real-time Intraday chart data file updates started for ESM26_FUT_CME
2026-04-10 11:44:08.551 | Intraday chart data file opened for ESM26_FUT_CME
2026-04-10 11:44:08.551 | HD Request # 20 | Enabling Intraday chart updating for symbol.
2026-04-10 11:44:08.551 | No download requests in the queue to start downloads for.
2026-04-10 11:44:08.597 | Socket (5) | Socket gracefully closed by remote side.
2026-04-10 11:44:08.597 | Socket (5) | Closed.
2026-04-10 11:44:08.760 | Denali Data Feed | Setting external service identifier for symbol VIX_CGI to 1392
2026-04-10 11:44:08.760 | Denali Data Feed | Received security definition for symbol VIX_CGI
2026-04-10 11:44:08.760 | Denali Data Feed | Setting external service identifier for symbol VVIX_CGI to 1408
2026-04-10 11:44:08.760 | Denali Data Feed | Received security definition for symbol VVIX_CGI
2026-04-10 11:44:12.279 | Opened cached Intraday file: C:\SierraChart\Data\ESM26_FUT_CME.scid. Thread ID: 53036
2026-04-10 11:44:15.325 | ESM26_FUT_CME[M] Rev. 10t #2 | Reloading chart.
2026-04-10 11:44:15.342 | Loading market depth data.
2026-04-10 11:44:15.349 | Loaded depth data records for ESM26_FUT_CME 2026-04-09 from 2026-04-09 22:00:41.049170 to 2026-04-09 23:55:05.002000.
2026-04-10 11:44:15.356 | Loaded depth data records for ESM26_FUT_CME 2026-04-10 from 2026-04-10 10:13:39.329000 to 2026-04-10 11:44:09.634000.
2026-04-10 11:44:15.356 | + Loading additional symbol data.
2026-04-10 11:44:15.357 | ESM26_FUT_CME[M] Rev. 10t #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-10 11:44:16.032 | ESM26_FUT_CME[M] Rev. 10t #2 | Chart data loading complete.
2026-04-10 11:44:16.543 | ESM26_FUT_CME[M] Rev. 10t #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-10 11:44:17.409 | HD Request # 21 | Downloading Intraday chart data for VIX/VVIX to the file VIX[VVIX.scid. Service:
2026-04-10 11:44:17.409 | HD Request # 21 | Download start date-time: 2026-04-10 11:43:16.000000. File last date-time: 2026-04-10 11:43:16.314000
2026-04-10 11:44:17.409 | HD Request # 21 | Initiating download of VIX_CGI for VIX/VVIX.
2026-04-10 11:44:17.409 | Added historical Intraday data request for VIX_CGI to the queue.
2026-04-10 11:44:17.409 | Intraday data recording state for symbol VIX_CGI is set to download 'Pending'.
2026-04-10 11:44:17.409 | Triggering next historical data download in queue.
2026-04-10 11:44:17.409 | HD Request # 21 | Initiating download of VVIX_CGI for VIX/VVIX.
2026-04-10 11:44:17.409 | Added historical Intraday data request for VVIX_CGI to the queue.
2026-04-10 11:44:17.409 | Intraday data recording state for symbol VVIX_CGI is set to download 'Pending'.
2026-04-10 11:44:17.409 | HD Request # 22 | Downloading Intraday chart data for VIX_CGI to the file VIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:44:17.409 | HD Request # 22 | Download start date-time: 2026-04-10 11:43:16.000000. File last date-time: 2026-04-10 11:43:16.314000
2026-04-10 11:44:17.409 | HD Request # 22 | Using server: ds33.sierracharts.com port 10149
2026-04-10 11:44:17.409 | Socket (5) | Creating socket.
2026-04-10 11:44:17.410 | Socket (5) | New receive buffer size: 0
2026-04-10 11:44:17.410 | Socket (5) | Connecting to IP: 69.39.70.245.
2026-04-10 11:44:17.663 | HD Request # 22 | Setting DTC encoding to Binary VLS
2026-04-10 11:44:17.663 | HD Request # 22 | Sending historical data logon request message.
2026-04-10 11:44:17.819 | HD Request # 22 | Requesting Intraday data. Start date-time: 2026-04-10 11:43:16. Record interval: 0. Symbol: VIX_CGI
2026-04-10 11:44:17.944 | HD Request # 22 | Decompressing data.
2026-04-10 11:44:18.069 | HD Request # 22 | Receiving Intraday data for VIX_CGI starting at 2026-04-10 11:43:16.314000
2026-04-10 11:44:18.070 | Socket (5) | CloseSocket call.
2026-04-10 11:44:18.070 | Socket (5) | Shutdown started. Waiting for graceful close.
2026-04-10 11:44:18.070 | Historical data download thread signaled to stop.
2026-04-10 11:44:18.070 | HD Request # 22 | Timestamp of first Intraday data file record written: 2026-04-10 11:43:31.320000.
2026-04-10 11:44:18.070 | HD Request # 22 | Received 4 Intraday data records from 2026-04-10 11:43:16.314000 to 2026-04-10 11:44:01.324000 (45.0 seconds. Delay: 16.7 seconds) and wrote 3 records for VIX_CGI
2026-04-10 11:44:18.075 | HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:44:01.324000
2026-04-10 11:44:18.075 | HD Request # 22 | Completion time: 1s.
2026-04-10 11:44:18.075 | HD Request # 22 | Intraday data download complete for VIX_CGI. Unique request ID: 17
2026-04-10 11:44:18.075 | Removing historical data download ID 17.
2026-04-10 11:44:18.075 | Real-time Intraday chart data file updates started for VIX_CGI
2026-04-10 11:44:18.075 | Intraday chart data file opened for VIX_CGI
2026-04-10 11:44:18.075 | HD Request # 22 | Enabling Intraday chart updating for symbol.
2026-04-10 11:44:18.075 | Triggering next historical data download in queue.
2026-04-10 11:44:18.075 | HD Request # 23 | Downloading Intraday chart data for VVIX_CGI to the file VVIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:44:18.075 | HD Request # 23 | Download start date-time: 2026-04-09 22:15:01.000000. File last date-time: 2026-04-09 22:15:01.163000
2026-04-10 11:44:18.075 | HD Request # 23 | Using server: ds31.sierracharts.com port 10150
2026-04-10 11:44:18.075 | Socket (6) | Creating socket.
2026-04-10 11:44:18.075 | Socket (6) | New receive buffer size: 0
2026-04-10 11:44:18.075 | Socket (6) | Connecting to IP: 64.152.155.116.
2026-04-10 11:44:18.195 | Socket (5) | Socket gracefully closed by remote side.
2026-04-10 11:44:18.195 | Socket (5) | Closed.
2026-04-10 11:44:21.538 | HD Request # 23 | Setting DTC encoding to Binary VLS
2026-04-10 11:44:21.538 | HD Request # 23 | Sending historical data logon request message.
2026-04-10 11:44:21.897 | HD Request # 23 | Requesting Intraday data. Start date-time: 2026-04-09 22:15:01. Record interval: 0. Symbol: VVIX_CGI
2026-04-10 11:44:31.228 | HD Request # 23 | Decompressing data.
2026-04-10 11:44:37.901 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-04-10 11:44:37.901 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-04-10 11:44:37.901 | DTC Client socket (1) | CloseSocket call.
2026-04-10 11:44:37.901 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0
2026-04-10 11:44:37.902 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-04-10 11:44:37.902 | DTC Client socket (1) | Closed.
2026-04-10 11:44:37.902 | DTC Client socket (0) | CloseSocket call.
2026-04-10 11:44:37.902 | Denali Data Feed | Disconnected from the server.
2026-04-10 11:44:37.902 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2026-04-10 11:44:40.918 | Denali Data Feed | Connecting to the server ds30.sierracharts.com. Port 10047
2026-04-10 11:44:40.919 | DTC Client socket (1) | Creating socket.
2026-04-10 11:44:40.919 | DTC Client socket (1) | New receive buffer size: 0
2026-04-10 11:44:40.919 | DTC Client socket (1) | Connecting to IP: 67.214.125.11.
2026-04-10 11:44:41.040 | Denali Data Feed | Network connection to server complete.
2026-04-10 11:44:41.040 | Denali Data Feed | Starting socket receive thread.
2026-04-10 11:44:41.040 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2026-04-10 11:44:41.165 | Denali Data Feed | Setting DTC encoding to Binary VLS
2026-04-10 11:44:41.165 | Denali Data Feed | Sending logon request message.
2026-04-10 11:44:41.383 | Denali Data Feed | Received logon response.
2026-04-10 11:44:41.383 | Denali Data Feed | Server Name: SC Realtime Server.
2026-04-10 11:44:41.383 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2026-04-10 11:44:41.383 | Denali Data Feed | Successfully connected.
2026-04-10 11:44:41.383 | Denali Data Feed | Trading is not supported.
2026-04-10 11:44:41.383 | Denali Data Feed | MarketDepthIsSupported: 1
2026-04-10 11:44:41.383 | Added historical Intraday data request for VIX_CGI to the queue.
2026-04-10 11:44:41.383 | Intraday data recording state for symbol VIX_CGI is set to download 'Pending'.
2026-04-10 11:44:41.383 | Triggering next historical data download in queue.
2026-04-10 11:44:41.383 | Denali Data Feed | Restarting real-time data updates for symbol: VIX_CGI -> VIX_CGI
2026-04-10 11:44:41.383 | Denali Data Feed | Restarting real-time data updates for symbol: VVIX_CGI -> VVIX_CGI
2026-04-10 11:44:41.602 | Denali Data Feed | Setting external service identifier for symbol VIX_CGI to 1348
2026-04-10 11:44:41.602 | Denali Data Feed | Received security definition for symbol VIX_CGI
2026-04-10 11:44:41.602 | Denali Data Feed | Setting external service identifier for symbol VVIX_CGI to 1364
2026-04-10 11:44:41.602 | Denali Data Feed | Received security definition for symbol VVIX_CGI
2026-04-10 11:44:52.600 | HD Request # 23 | Receiving Intraday data for VVIX_CGI starting at 2026-04-09 22:15:01.163000
2026-04-10 11:44:52.600 | Socket (6) | CloseSocket call.
2026-04-10 11:44:52.600 | Socket (6) | Shutdown started. Waiting for graceful close.
2026-04-10 11:44:52.600 | Historical data download thread signaled to stop.
2026-04-10 11:44:52.600 | HD Request # 23 | Received 1 Intraday data record from 2026-04-09 22:15:01.163000 to 2026-04-09 22:15:01.163000 (0.0 seconds. Delay: 13.5 hours) and wrote 0 records for VVIX_CGI
2026-04-10 11:44:52.600 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2026-04-09 20:15:01.163000
2026-04-10 11:44:52.600 | HD Request # 23 | Completion time: 34s.
2026-04-10 11:44:52.600 | HD Request # 23 | Intraday data download complete for VVIX_CGI. Unique request ID: 18
2026-04-10 11:44:52.600 | Removing historical data download ID 18.
2026-04-10 11:44:52.600 | HD Request # 21 | Calculating bar data for VIX/VVIX.
2026-04-10 11:44:52.600 | Real-time Intraday chart data file updates started for VVIX_CGI
2026-04-10 11:44:52.600 | Intraday chart data file opened for VVIX_CGI
2026-04-10 11:44:52.600 | HD Request # 23 | Enabling Intraday chart updating for symbol.
2026-04-10 11:44:52.600 | Triggering next historical data download in queue.
2026-04-10 11:44:52.600 | HD Request # 24 | Downloading Intraday chart data for VIX_CGI to the file VIX_CGI.scid. Service: cboe_global_indexes.data
2026-04-10 11:44:52.601 | HD Request # 24 | Download start date-time: 2026-04-10 11:44:01.000000. File last date-time: 2026-04-10 11:44:01.324000
2026-04-10 11:44:52.601 | HD Request # 24 | Using server: ds30.sierracharts.com port 10149
2026-04-10 11:44:52.601 | Socket (5) | Creating socket.
2026-04-10 11:44:52.601 | Socket (5) | New receive buffer size: 0
2026-04-10 11:44:52.601 | Socket (5) | Connecting to IP: 67.214.125.11.
2026-04-10 11:44:52.601 | HD Request # 21 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for VIX/VVIX
2026-04-10 11:44:52.601 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:43:16.314000
2026-04-10 11:44:52.601 | HD Request # 21 | Completion time: 35s.
2026-04-10 11:44:52.601 | HD Request # 21 | Intraday data download complete for VIX/VVIX. Unique request ID: 15
2026-04-10 11:44:52.601 | Removing historical data download ID 15.
2026-04-10 11:44:52.601 | Real-time Intraday chart data file updates started for VIX/VVIX
2026-04-10 11:44:52.601 | Intraday chart data file opened for VIX/VVIX
2026-04-10 11:44:52.601 | HD Request # 21 | Enabling Intraday chart updating for symbol.
2026-04-10 11:44:52.601 | ESM26_FUT_CME[M] Rev. 10t #2 | Historical data download for additional symbol vix/vvix with ID 15 has completed.
2026-04-10 11:44:52.601 | No download requests in the queue to start downloads for.
2026-04-10 11:44:52.716 | Socket (6) | Socket gracefully closed by remote side.
2026-04-10 11:44:52.716 | Socket (6) | Closed.
2026-04-10 11:44:52.845 | HD Request # 24 | Setting DTC encoding to Binary VLS
2026-04-10 11:44:52.845 | HD Request # 24 | Sending historical data logon request message.
2026-04-10 11:44:52.998 | HD Request # 24 | Requesting Intraday data. Start date-time: 2026-04-10 11:44:01. Record interval: 0. Symbol: VIX_CGI
2026-04-10 11:44:53.119 | HD Request # 24 | Decompressing data.
2026-04-10 11:44:53.240 | HD Request # 24 | Receiving Intraday data for VIX_CGI starting at 2026-04-10 11:44:01.324000
2026-04-10 11:44:53.240 | Socket (5) | CloseSocket call.
2026-04-10 11:44:53.240 | Socket (5) | Shutdown started. Waiting for graceful close.
2026-04-10 11:44:53.241 | Historical data download thread signaled to stop.
2026-04-10 11:44:53.241 | HD Request # 24 | Timestamp of first Intraday data file record written: 2026-04-10 11:44:16.332000.
2026-04-10 11:44:53.241 | HD Request # 24 | Received 4 Intraday data records from 2026-04-10 11:44:01.324000 to 2026-04-10 11:44:46.312000 (45.0 seconds. Delay: 6.9 seconds) and wrote 3 records for VIX_CGI
2026-04-10 11:44:53.246 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2026-04-10 09:44:46.312000
2026-04-10 11:44:53.246 | HD Request # 24 | Completion time: 1s.
2026-04-10 11:44:53.246 | HD Request # 24 | Intraday data download complete for VIX_CGI. Unique request ID: 19
2026-04-10 11:44:53.246 | Removing historical data download ID 19.
2026-04-10 11:44:53.246 | Real-time Intraday chart data file updates started for VIX_CGI
2026-04-10 11:44:53.246 | Intraday chart data file opened for VIX_CGI
2026-04-10 11:44:53.246 | HD Request # 24 | Enabling Intraday chart updating for symbol.
2026-04-10 11:44:53.246 | No download requests in the queue to start downloads for.
2026-04-10 11:44:53.361 | Socket (5) | Socket gracefully closed by remote side.
2026-04-10 11:44:53.361 | Socket (5) | Closed.
2026-04-10 11:45:02.344 | Opened cached Intraday file: C:\SierraChart\Data\VIX[VVIX.scid. Thread ID: 53036
2026-04-10 11:45:02.344 | Opened cached Intraday file: C:\SierraChart\Data\VIX_CGI.scid. Thread ID: 53036
[2026-04-10 16:55:06]
John - SC Support - Posts: 48273
We see the following items in your log:
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. *
So you are having intermittent connectivity issues. There is nothing on our end that is having a specific issue, so this is something with your connectivity.
Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
