Date/Time: Thu, 26 Nov 2026 04:01:38 +0000
Highest and lowest value of candle stick
View Count: 373
| [2026-04-09 01:58:08] |
| User223734 - Posts: 120 |
Can I view the status of the highest and lowest value of real time candle stick ?
| [2026-04-09 14:18:01] |
What exactly do you want? What do you mean by the "status"?
| [2026-04-10 03:09:16] |
For OHLC, can I view the H and L value of the bar on real time?
| [2026-04-10 13:39:41] |
We think you are looking for the "Tool Values Window". Refer to the following: Chart Drawing Tools: Tool Values Window There is also the "Compact Tool Values Window", which may be more of what you are wanting: Chart Drawing Tools: Compact Tool Values Window And be sure to look through the various options for those windows by looking through the settings at the following links: Chart Drawing Tools: Chart Values (Global Settings >> Tool Settings >> General) Chart Drawing Tools: Chart Values Tool Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-11 01:27:49] |
| Mercrastius - Posts: 73 |
If you want to see the values on the chart instead of in a tool values window you can add the Highest High / Lowest Low over N bars study. Set the length to 1 so it's returning the values of the current bar. Now you have options on where the values will appear. Chart header, values column, etc... |
