Date/Time: Thu, 26 Nov 2026 04:01:31 +0000
Global Cursor on linked charts only
View Count: 307
| [2026-04-08 02:39:45] |
| X626 - Posts: 2 |
Is this something SC can support? Thanks
| [2026-04-08 03:30:11] |
| Sierra_Chart Engineering - Posts: 25489 |
The closest available is this: Chart Drawing Tools: Synchronize Linked Charts Only (Tools >> Synchronize Linked Charts Only) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-08 03:55:09] |
| X626 - Posts: 2 |
Yeah I know, not the same though, I woudn't ask if it was. Since the linked charts have everything synced including the bar period, it would perhaps make sense to have the cursor synced too for lot of ppl out there. Thanks.
