Date/Time: Thu, 26 Nov 2026 04:01:36 +0000
VPS
View Count: 480
| [2026-04-07 23:33:49] |
| User787305 - Posts: 25 |
I'm looking at signing up with a VPS due to high latency on my internet, etc. I wanted to ask if Sierra Chart has any comments/issues with setting up the system, chartbooks, etc on a remote server. Can I still maintain Sierra Charts on my pc?? I would execute from the VPS (Quant VPS if that matters). Thanks. Mike Allen |
| [2026-04-08 13:32:47] |
The only item that we want to point out is that if you are going to be getting the data from our Denali Exchange Data Feed to two computers at the same time, then you will need to pay a second set of exchange fees. Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously In terms of setting up the system, refer to the following if you want to have the same setup as your current system: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
