Date/Time: Tue, 20 Oct 2026 18:29:55 +0000
CQG Trading Account connection/Data
View Count: 537
| [2026-04-07 08:57:30] |
| User388695 - Posts: 21 |
Hi SC Support, I am connecting to my Trading account, and while I can connect, I get no data, none of the charts in the workbook appear and open up. What do I need to do please? Thank you |
| [2026-04-07 09:23:05] |
| Sierra_Chart Engineering - Posts: 25226 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-07 10:52:52] |
Thank you. Please see below: 2026-04-07 11:49:36.023 | Software version: 2800 64-bit 2026-04-07 11:49:36.023 | Primary Thread ID: 5828 2026-04-07 11:49:36.023 | Usage end date: 2026-06-05 2026-04-07 11:49:36.023 | Enabled for: Advanced Features 2. 2026-04-07 11:49:36.023 | Enabled for: Sierra Chart Historical Data Service. 2026-04-07 11:49:36.023 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-04-07 11:49:36.023 | Enabled for: Delayed Denali Exchange Data Feed. 2026-04-07 11:49:36.023 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-04-07 11:49:36.023 | Current selected Data/Trading service: CQG WebAPI 2026-04-07 11:49:36.023 | Custom symbol settings values: enabled 2026-04-07 11:49:36.023 | Chart Update Interval: 400 2026-04-07 11:49:36.023 | Intraday Data Storage Time Unit: 0 2026-04-07 11:49:36.023 | Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) 2026-04-07 11:49:36.023 | 2026-04-07 10:49:36 Local computer time in UTC 2026-04-07 11:49:36.023 | 2026-04-07 11:49:36 Local computer time in SC Time Zone 2026-04-07 11:49:36.023 | 2026-04-07 08:54:07 Server time in UTC 2026-04-07 11:49:36.023 | Local computer UTC time and Server UTC time difference: 2 seconds. 2026-04-07 11:49:36.023 | Program path: C:\SierraChart\ 2026-04-07 11:49:36.023 | Data Files path: C:\SierraChart\Data\ 2026-04-07 11:49:36.023 | OS Version Number: 10.0 2026-04-07 11:49:36.023 | Locale Setting: C 2026-04-07 11:49:36.023 | Crash reporter started: true 2026-04-07 11:49:36.023 | 2026-04-07 11:50:14.303 | Saved Chartbook: Octot25.Cht. Time: 0.0068 seconds. 2026-04-07 11:50:38.280 | F.US.EU6M26 1 Min #1 | Reloading chart. 2026-04-07 11:50:38.284 | F.US.EU6M26 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EU6M26.scid 2026-04-07 11:50:38.285 | F.US.EU6M26 1 Min #1 | Chart data loading complete. 2026-04-07 11:50:48.779 | File >> Disconnect selected. 2026-04-07 11:50:48.779 | CQG WebAPI | Sending Web API Logoff message. 2026-04-07 11:50:48.779 | CQG WebSocket socket (1) | CloseSocket call. 2026-04-07 11:50:48.779 | CQG WebSocket | WebSocket closed. 2026-04-07 11:50:48.779 | CQG WebAPI | WebSocket closed. 2026-04-07 11:50:48.779 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-04-07 11:50:48.779 | SC Data with Depth | Waiting for socket receive thread to end 2026-04-07 11:50:48.780 | DTC Client socket (3) | CloseSocket call. 2026-04-07 11:50:48.780 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-04-07 11:50:48.780 | SC Data with Depth | Disconnected from the server. 2026-04-07 11:50:48.780 | CQG WebAPI | Disconnected. 2026-04-07 11:50:48.817 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-04-07 11:50:48.817 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 11:50:48.854 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-04-07 11:50:48.854 | CQG WebSocket socket (1) | Closed. 2026-04-07 11:50:48.909 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-04-07 11:50:48.909 | DTC Client socket (3) | Closed. 2026-04-07 11:50:55.770 | 2026-04-07 11:50:55.771 | CQG WebAPI | Connecting to server api.cqg.com 2026-04-07 11:50:55.771 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-04-07 11:50:55.915 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 11:50:55.915 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-04-07 11:50:55.915 | CQG WebSocket socket (1) | Connecting to IP: 195.166.124.175. 2026-04-07 11:50:55.941 | CQG WebSocket | Opening WebSocket. 2026-04-07 11:50:55.941 | CQG WebSocket | Sending WebSocket handshake. 2026-04-07 11:50:56.091 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-04-07 11:50:56.091 | CQG WebSocket | Server header | Connection: Upgrade 2026-04-07 11:50:56.091 | CQG WebSocket | Server header | Sec-WebSocket-Accept: Smm+tsPu/sIcSpmaayLGCcPPr4E= 2026-04-07 11:50:56.091 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-04-07 11:50:56.091 | CQG WebSocket | Server header | Upgrade: websocket 2026-04-07 11:50:56.091 | CQG WebSocket | Server header | 2026-04-07 11:50:56.091 | CQG WebSocket | Web socket state is now open. 2026-04-07 11:50:56.091 | CQG WebAPI | WebSocket connected. 2026-04-07 11:50:56.091 | CQG WebAPI | Sending market data logon message. 2026-04-07 11:50:56.349 | CQG WebAPI | Base Time: 2026-03-28T06:49:02. 2026-03-28 06:49:02 2026-04-07 11:50:56.349 | CQG WebAPI | Logon successful. Session Token = mQsB+dD3pnzbzQ91MoUqD3FT/yF8KtCb/GuAjAEl4EIskHW96n6HpyE0+pwD8oYMKCceCDSRRSe 2026-04-07 11:50:56.349 | CQG WebAPI | Connection to server complete. 2026-04-07 11:50:56.350 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-04-07 11:50:56.350 | Updated verified funded futures trading account ending date to: 2026-05-07 10:50:56 2026-04-07 11:50:56.350 | CQG WebAPI | Sending Trade Accounts request message. 2026-04-07 11:50:56.488 | CQG WebAPI | Brokerage name: AMP. Account Name: 121098 2026-04-07 11:50:56.488 | CQG WebAPI | Brokerage name: AMP. Account Name: 121098A 2026-04-07 11:50:56.488 | Updated verified funded futures trading account ending date to: 2026-05-07 10:50:56 2026-04-07 11:50:56.488 | CQG WebAPI | Sending collateral subscribe request. 2026-04-07 11:50:56.562 | Using symbol data fast lookup vector 2026-04-07 11:50:56.562 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EU6M26. ID: 1 2026-04-07 11:50:56.562 | Symbol Error | F.US.EU6M26 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EU6M26. ID: 1 2026-04-07 11:50:56.562 | CQG WebAPI | Using primary service for historical data for F.US.EU6M26 2026-04-07 11:50:56.562 | No historical data client is currently set to download historical Intraday data for F.US.EU6M26. 2026-04-07 11:50:56.562 | Real-time Intraday chart data file updates started for F.US.EU6M26 2026-04-07 11:50:56.562 | Intraday chart data file opened for F.US.EU6M26 2026-04-07 11:50:56.603 | CQG WebAPI | Sending positions subscribe request. RequestID: 689087 2026-04-07 11:50:56.603 | CQG WebAPI | Sending orders subscribe request. RequestID: 689088 |
| [2026-04-07 15:48:46] |
| John - SC Support - Posts: 48273 |
Sierra Chart does not support connectivity with CQG for data for the CME Group and EUREX. So you need to get this data from our Denali Exchange Data Feed. At this time, you do not have data for the CME Group active with our Denali Exchange Data Feed. You did have an exchange active in February, but it did not renew on March 1, 2026, due to insufficient funds in your account at that time. You can activate the exchange(s) you want for the CME Group at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-07 15:48:57
