Date/Time: Thu, 26 Nov 2026 04:01:35 +0000
Mbo + rithmic
View Count: 617
| [2026-04-07 08:12:18] |
| User429218 - Posts: 4 |
Hey i have a prop firm and i want to use the mbo even if pay for denali data feed we can have only 1 connection so i can't connecte my prop firm ?
| [2026-04-07 08:57:31] |
| User135243 - Posts: 337 |
of course you can, you get the data from Denali and connect your Rithmic account for order-routing only
| [2026-04-07 09:23:47] |
Can you explaine to me how pls
| [2026-04-07 09:52:52] |
you just have to create the Rithmic direct connection with Server, username and password and under Common Settings set Allow Support of Sierra Chart Data to YES
| [2026-04-07 10:06:28] |
when i do that my dom is emty
| [2026-04-07 10:10:39] |
File attached
| Attachment Deleted. |
| [2026-04-07 12:31:44] |
I don't know what you mean with "the DOM is empty", I guess you just can see best bid/ask, if yes, in this case you need a Denali data-feed with full market-depth
| [2026-04-07 16:25:55] |
User429218: You are not setup to get any data from our Denali Exchange Data Feed. So right now your data would be coming from Rithmic when you are connected to your Rithmic account. You can use our Denali Exchange Data Feed when connected to Rithmic. And you can get the MBO data from our Denali Exchange Data Feed as well. We are not sure what you are referring to when you state "...we can have only 1 connection so i can't connecte my prop firm ?" Sierra Chart is setup so you can get the data from our Denali Exchange Data Feed while connecting to your trading account. Refer to the following: Denali Exchange Data Feed: Integration with Trading Services With regards to setting up our Denali Exchange Data Feed, you need to keep in mind that in order to get real-time data for the CME Group at the non-professional rates, you need to have a live, funded, futures trading account. And you need to connect your Sierra Chart software to that account at least once a month for verification. Refer to the following: Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Once you have the above worked out, then follow the instructions at the following link to setup the Denali Exchange Data Feed for the CME Group: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
