Date/Time: Thu, 26 Nov 2026 04:01:34 +0000
(Use Transparency Drawing Style) (transparency level)
View Count: 476
[2026-04-06 19:55:48]
JoeThanksG - Posts: 33
I need help with these 2 indicators.
I'm not sure how to do this
Large Volume Trade Indicator
has a (Use Transparency Drawing Style)
but it's worthless if it doesn't have a
(transparency level) option
Plus
Market Depth Historical Grath
Needs both
Like you guys have it on (Volume Profile)
I sent you a screenshot that has all three
Best wishes to all, Joe V
imageSierra Charts Large-Volume indicator suggestion.png / V - Attached On 2026-04-06 19:53:04 UTC - Size: 443.68 KB - 214 views
[2026-04-06 21:40:16]
The Transparency Level for the "Large Volume Trade Indicator" is controlled by the "Transparency Level" for the first subgraph (Max Trade Volume For Bar). Refer to the following:
Chart Studies: Subgraphs Tab >> Transparency Level for Fill Styles
There will never be a Transparency applied to the Market Depth Historical Graph. Transparent items are still not handled well by computers, and if the Market Depth Historical Graph were to be made transparent, you would never be able to move the chart.
Date Time Of Last Edit: 2026-04-06 21:41:25
[2026-04-12 03:30:51]
Thank you for your help.
I figured it out!! (Google)
What you just send me has nothing to do with (Large Volume Trade Indicator)
But, it is in the "Subgraphs Tab" Transparency Level for Fill Style.
Thank you again
