Date/Time: Thu, 26 Nov 2026 04:01:30 +0000
RTH VbP still showing volume profile for most recent candle in evening session
View Count: 514
[2026-04-06 11:41:23]
User994149 - Posts: 9
Hi there,
I am having an issue where my RTH volume profile is showing the volume profile for the most recent candle during the evening session. Due to the attached file upload limit I have attached only two screenshots of my volume by price study settings, but I believe these contain the settings that pertain to this issue. My chart session times settings are 08:30 - 15:59:59 for the intraday, and 15:00:00 - 08:29:59 for the evening session.
Here is a link to the chart image showing the volume profile for the most recent candle in the evening session, which to my understanding should not be there, but something is clearly wrong with my settings - https://www.sierrachart.com/image.php?Image=1775475223274.png
Any help would be appreciated.
Thank you.
imageSierraChart_64_qTpk82eBK1.png / V - Attached On 2026-04-06 11:36:53 UTC - Size: 53.53 KB - 197 views
imageSierraChart_64_hlupw0yPvW.png / V - Attached On 2026-04-06 11:37:02 UTC - Size: 56.06 KB - 214 views
[2026-04-06 16:09:08]
To start with, your Session Times are incorrect. You have an overlap in the times, as you RTH ends at 15:59:59 and your ETH starts at 15:00:00. You need to correct this.
Then, in your Volume by Price settings, you have your "End Time" sete to "15:00:00", which means that it will include the bar that starts at 15:00:00. If you have your RTH end at 14:59:59, then you need to set the End Time in the VbP to 14:59:59
