Date/Time: Thu, 26 Nov 2026 04:01:33 +0000
Incorrect candlestick position display
View Count: 373
| [2026-04-02 14:44:14] |
| User193072 - Posts: 1 |
The historical data is fixed in the middle of the chart. How can I delete it and place the latest price candlesticks in the middle? Also, my channels have disappeared for some reason.
| Attachment Deleted. |
| [2026-04-02 17:09:49] |
We are not certain of what you are asking, but we think it may be that you have the "Lock Fill Space" option enabled, and you would need to scroll the chart forward to have the latest bar at that "edge". Or, you may want to turn off the option for "Lock Fill Space". Refer to the following: Working With Charts: Scrolling The Chart and Right Side Fill Space Also, my channels have disappeared for some reason.
If you are referring to the lines not extending to the right side of the screen, then this is probably related to the Lock fill Space. If you are referring to some other channels that are generated from a study, then we would need to know what study, and what is showing or not showing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
