Date/Time: Thu, 26 Nov 2026 03:53:29 +0000
I cant log in to rithmic
View Count: 381
[2026-04-02 14:10:18]
User849502 - Posts: 485
John,
Now I can't log into Rithmic execution only. I have the right login and password, but the data won't come thru. I have done everything in your check list after googling. Do you see what is wrong? I have email support at Apex but they take forever to answer thank you so much John
karen
imagenologin.png / V - Attached On 2026-04-02 14:09:53 UTC - Size: 101.37 KB - 152 views
[2026-04-02 14:15:44]
User135243 - Posts: 337
Click: Common Settings and there set Allow Support For Sierra Chart Data Feeds to YES
[2026-04-02 14:23:17]
Get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
