Date/Time: Sat, 18 May 2024 00:06:19 +0000
how can I make the hand tool includes also the crosshair lines
View Count: 1626
[2014-10-27 16:41:04] |
jgomez - Posts: 6 |
Hi, after making a previous update of sierra chart, when I selected the hand tool I saw nicely how besides the hand tool that allowed me to move the charts also appeared the crosshair lines within the hand tool, so in a single tool I had both the tool to move the charts and also the tool to see the crosshair lines to see what the market was doing at a specific time but in different time frame charts when the global cursor on is active. However, I just updated again the sierra chart to the last version, and when I select the hand tool, I do not see the crosshair lines anymore, if I want to see the crosshair lines, I need to select the chart values/crosshair tool, but with that tool I cannot move the charts. So, how can I have the charting moving option and the crosshair lines in the single hand tool as I had it before the last update. Thanks in advance. |
[2014-10-28 04:02:15] |
Enable: Global Settings >> Tool Settings >> Chart Values >>Always on When Using Other Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
