Date/Time: Thu, 26 Nov 2026 04:11:42 +0000
Request: Consider add a text
View Count: 347
| [2026-03-31 11:20:19] |
| ycomp - Posts: 334 |
Hi, please consider adding an input to the Spreadsheet Formula study called "Notes" or "Comments" or "Description" or something like that. The purpose for it is so that the user can explain what the formula does. Quick and Handy way to understand what the formula is doing without investigating what each ID belongs to could be quite helpful. thanks note: somehow the title of the post got mangled, it was longer and more descriptive before.. don't know what happened. Date Time Of Last Edit: 2026-03-31 11:21:21
| [2026-04-17 21:05:22] |
This can be done by setting the "Short Name" for the study. Refer to the following: Chart Studies: Settings and Inputs Tab >> Short Name Our apologies for not seeing/responding to this earlier. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
