Date/Time: Thu, 26 Nov 2026 03:53:36 +0000
FEE
View Count: 484
| [2026-03-27 23:15:47] |
| User166249 - Posts: 28 |
Hi can you tell me how much i pay per month ? If i am considered a non profesionnal? do i pay extra fee for depth market data ? best regards |
| [2026-03-28 19:49:13] |
| Sierra_Chart Engineering - Posts: 25489 |
What you are asking about are exchange fees and they are listed here: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) The exchanges charge an extra fee for market depth data. In the case of the NASDAQ TotalView exchange fee, the market depth is included. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-28 19:50:32
| [2026-03-30 02:27:13] |
Can you tell me how to be sure ive desactivated depth data on my sierra?
| [2026-03-30 04:05:58] |
We see you have this exchange active: COMEX with Market Depth for non-professional Trading accounts We have deactivated this exchange and it will not renew at the beginning of April. So do you just want top of book data for COMEX? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-30 16:40:54] |
thank you How much is the top of book data for comex? |
| [2026-03-30 21:38:26] |
You will find the exchange fees at the following link: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
