Date/Time: Tue, 24 Nov 2026 18:17:05 +0000
Stage5 account connection
View Count: 944
[2026-03-26 14:27:33]
User731603 - Posts: 3
Hello, could you please verify if my Stage5 account is connected to SierraChart? I can't connect to real-time data as of now.
Best regards,
Jakub
[2026-03-26 14:29:21]
Sierra_Chart Engineering - Posts: 25476
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
[2026-03-26 14:38:17]
Hello, I appreciate your fast response. Coppied Message Log below:
2026-03-26 14:35:34.217 | Software version: 2880 64-bit
2026-03-26 14:35:34.217 | Primary Thread ID: 20412
2026-03-26 14:35:34.217 | Usage end date: 2026-09-11
2026-03-26 14:35:34.217 | Enabled for: Advanced Features 2.
2026-03-26 14:35:34.217 | Enabled for: Sierra Chart Historical Data Service.
2026-03-26 14:35:34.217 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-03-26 14:35:34.217 | Enabled for: Delayed Denali Exchange Data Feed.
2026-03-26 14:35:34.217 | Enabled for exchange2: CME
2026-03-26 14:35:34.217 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-03-26 14:35:34.217 | Current selected Data/Trading service: Teton CME Routing
2026-03-26 14:35:34.217 | Custom symbol settings values: enabled
2026-03-26 14:35:34.217 | Chart Update Interval: 400
2026-03-26 14:35:34.217 | Intraday Data Storage Time Unit: 0
2026-03-26 14:35:34.217 | Time Zone: +00:00:00 (UTC+00)
2026-03-26 14:35:34.217 | 2026-03-26 14:35:34 Local computer time in UTC
2026-03-26 14:35:34.217 | 2026-03-26 14:35:34 Local computer time in SC Time Zone
2026-03-26 14:35:34.217 | 2026-03-26 14:02:10 Server time in UTC
2026-03-26 14:35:34.217 | Local computer UTC time and Server UTC time difference: 2 seconds.
2026-03-26 14:35:34.217 | Program path: C:\SierraChart\
2026-03-26 14:35:34.217 | Data Files path: C:\SierraChart\Data\
2026-03-26 14:35:34.217 | OS Version Number: 10.0
2026-03-26 14:35:34.217 | Locale Setting: C
2026-03-26 14:35:34.217 | Crash reporter started: true
2026-03-26 14:35:46.988 |
2026-03-26 14:35:46.988 | Teton CME Routing | Firm: Dorman/Stage5
2026-03-26 14:35:46.988 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11092
2026-03-26 14:35:46.989 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-03-26 14:35:46.989 | DTC Client socket (1) | New receive buffer size: 0
2026-03-26 14:35:46.989 | DTC Client socket (1) | Connecting to IP: 4.8.170.26.
2026-03-26 14:35:47.120 | Teton CME Routing | Network connection to server complete.
2026-03-26 14:35:47.120 | Teton CME Routing | Starting socket receive thread.
2026-03-26 14:35:47.120 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-03-26 14:35:47.531 | Teton CME Routing | Setting DTC encoding to Binary VLS
2026-03-26 14:35:47.531 | Teton CME Routing | Sending logon request message.
2026-03-26 14:35:47.715 | Teton CME Routing | Received logon response.
2026-03-26 14:35:47.715 | Teton CME Routing | Server Name: SC DTC Server.
2026-03-26 14:35:47.715 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2026-03-26 14:35:47.715 | Teton CME Routing | Connection error: No trade accounts assigned *
2026-03-26 14:35:47.715 | Teton CME Routing | Failed connections: 11
2026-03-26 14:35:47.716 | Teton CME Routing | Waiting for socket receive thread to end
2026-03-26 14:35:47.716 | DTC Client socket (1) | CloseSocket call.
2026-03-26 14:35:47.716 | Teton CME Routing | Disconnected.
2026-03-26 14:35:47.717 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-03-26 14:35:47.854 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-03-26 14:35:47.854 | DTC Client socket (1) | Closed.
[2026-03-26 14:39:52]
I can see that log says I don't have a trade account assigned. Could you please verify if my Stage5 account is connected?
[2026-03-26 15:45:24]
John - SC Support - Posts: 48643
You need to check with Stage 5 to see if they have completed the setup for your account. If not, then you need to wait for them to finish before you can connect.
If they say they have it done, then verify that you are selecting the correct "Clearing Firm".
If all of that is correct, and you are still getting the error of "No Trade Accounts Assigned", then check that Stage 5 has correctly setup your Teton account with the proper Account Name, which is your Sierra Chart Account Name. Make sure they have entered it properly.
