Date/Time: Mon, 09 Nov 2026 06:09:23 +0000
Cost effective way to test Simulated order flow trading
View Count: 903
[2026-03-23 05:55:50]
User747984 - Posts: 4
Hi, Hope you are all well. I am reaching out understand what would be the most cost effective option in term of service package and data etc.
Tools required:
- Big orders (Large vol. trade indicator)
- Volume profile/market profile
- Footprint charts (Optional)
- CVD (cumulative vol. delta)
Looking forward to hearing from you soon.
Thanks and regards
[2026-03-23 17:20:31]
John - SC Support - Posts: 48459
Since you state that you want "Market Profile", this means that you would need to be on one of the "Advanced" packages.
If you are wanting to connect to data and trading services, then you would also need to be on one of the "Integrated" packages, therefore the "Integrated Advanced" would be the best option.
But, if you do not need to connect to trading and data services, and you are fine with using our Delayed Streaming Data (you are still learing the system, you want some additional time to test you trading concepts, you are still developing how you want to trade, etc.), then you can be on one of the "Base" packages, in which case the "Base Advanced" would be the best option.
Refer to the information on the packages at the following link:
Description of Service Packages and Pricing: Packages
What are the exchanges for which you are wanting data?
[2026-03-25 03:40:58]
Hi John, Thanks for your response.
My apologies, I missed to clarify few things before.
I like to simulate on historical data so I can cover more data quickly rather than waiting for the live candle to form. My strategy will be based US indices, XAUUSD on 5min, 1min. chart or whatever instrument for which I don't have to get additional data package. I won't need live data for now.
I would also like to have the tools that I mentioned above apart from one correction i.e volume profile.
Tools required:
- Volume profile
Is it possible to get that in Base Sierra Chart with Advanced Features (Service Package 5).
[2026-03-25 14:45:25]
Yes, you can get all that with the "Base Advanced" package. You will then have access to our Delayed Streaming Data for the CME Group, EUREX, U.S. Equities and CFE.
You mention XAUUSD, which is a CFD. We have real-time data from FXCM for CFDs and FOREX at no additional cost (also available with any package). Refer to the following:
Sierra Chart Real Time and Historical Forex and CFD Data Service
And with any package, you have access to all our historical data. Refer to the following:
Sierra Chart Historical Data Service
[2026-06-10 12:41:45]
Hi John, I am writing to request an extension or reset of my Sierra Chart trial account.
Unfortunately, due to external scheduling constraints and complexity of platform, I was unable to dedicate enough time during the initial trial period to thoroughly explore and evaluate all of the platform's advanced features, custom studies, and charting capabilities. I want to properly test the software before committing to a paid package.
Thank you.
[2026-06-10 14:52:02]
User747984:
The best we can do is to give you 5 days of Trial time, as you have used most of the initial time from your trial.
Keep in mind that the "Base" packages are less expensive options that are meant for use to continue to learn Sierra Chart or work out specific tactics. Refer to the information on the packages at the following link:
[2026-06-23 04:29:26]
Hi John, hope you’re well.
Before I go ahead with my purchase I wanted to check few things with you one more time.
With the base package- advance, the visualisation and timing of large volume, CVD, DOM and footprint chart would be exactly same as it would be with live data and that applies to simulation and replay mode too?
Only difference would be Delayed Streaming Data, right?
Date Time Of Last Edit: 2026-06-23 04:35:44
[2026-06-23 13:39:09]
Correct.
