Date/Time: Sat, 17 Oct 2026 14:03:28 +0000
The Absolute Need For Total Return Dividend Adjusted Charts.
View Count: 627
| [2026-03-21 20:58:33] |
| User677437 - Posts: 102 |
Tell us how expensive, how practical, this would be to implement - It's been asked before, and the docs show that the option to download dividend adjusted data doesn't apply anymore. Data/Trade Service Settings: Download Dividend Adjusted Historical Data (Global Settings >> Data/Trade Service Settings >> Common Settings >> Historical Daily Data) This feature alone is so important to the professionals / advisors that are focused on reinvesting dividend income to see Total Return. Right now Bonds are so important for Income Management - Take a look at GOVT and AGG on Sierra, and then look at the adjusted total return on TradingView. The absolute difference in simple price action structure - like a double bottom and trendlines between the adjusted and non adjusted for GOVT - is GAME CHANGING. By not having this feature - You are excluding your customer base by hundreds, if not thousands. In the professional world this matters more than footprint charts, market profiles, heatmap etc. This should be at the top of the priority list. I'd be completely fine with a _TRADJ - Total Return Adjusted Chart format. I wouldn't expect a button in the control bar to switch it over like Tradingview. And I use detached windows, So I can just slide the chart under, the non adjusted chart. I understand how this could be complicated, how people could get confused and try trading from the other chart, but that's on them to distinguish the two charts with different colors of custom text, if the title bar is not enough. From a percentage standpoint, from a ratio standpoint, there are some really interesting things to do with Total Return Dividend Adjusted Charts. GOVT is up 14.25% from october 24, 2023 with dividend adjusted on a non adjusted chart it's up 5%...... This is so misleading, especially for ETFs that are focused on income generation, that is supposed to be reinvested back into the ETF, for more income on the next dividend. With that logic - that is why there is a double bottom on GOVT dividend adjusted in October 2023. |
| [2026-03-23 15:07:46] |
| John - SC Support - Posts: 48239 |
We are checking into this to see what can be done.
| [2026-07-16 14:46:36] |
| Sierra_Chart Engineering - Posts: 25199 |
We apologize for the delay on this. We are going to offer dividend adjusted US equities end of day data, in August 2026. There is some programming required for this. Please follow up with us in August regarding this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-28 07:25:19] |
Dividend adjusted historical data is now supported for US Equities historical daily data. Instructions: Update to the latest prerelease 2933. Instructions: Software Download: Fast Update Set these as follows: Global Settings >> Data/Trade Service Settings >> Common Settings >> Historical Daily Data >> Download Dividend Adjusted Historical Equities Data : Yes Global Settings >> Data/Trade Service Settings >> Common Settings >> Historical Daily Data >> Historical Daily Data Source For US Equities : "External Barchart Historical Data Service" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-29 02:00:16] |
This had not been fully implemented what is described above. It is now. You need to be running the latest prerelease of Sierra Chart and also: Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
