Date/Time: Thu, 26 Nov 2026 03:41:29 +0000
Chart Tabs not reporting correctly (Global issue?)
View Count: 349
[2026-03-21 14:15:45]
User186889 - Posts: 55
Hello Sierra
I have been finding for a few weeks now that the tabs withing a chart book do not report correctly. For example, using 4 charts (1H, 30m, 15m 1m) in one chartbook
Problem 1 - Sometimes, not all tabs show, I might get 2 or 3 out of the 4 charts
Problem 2 - Sometimes, not all charts show even though 4 tabs are shown (No - The Charts are not hidden)
Problem 3 - I click on one chart and it does not highlight the tab
Problem 4 - I click on a tab and it fails to highlight which chart it is linked to
Problem 5 - I select Toolbar > Window > Tile Vertically and not all charts sort correctly or sometimes do not show all charts
If I click to another chartbook, 'sometimes' it resolves.
If I close Sierra and reopen, it will sort itself out but only for a while.
Regards Mark SB
[2026-03-21 15:28:16]
Sierra_Chart Engineering - Posts: 25489
Maybe an exception is occurring causing a corruption, an incorrect state and instability in the program.
Run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
And make sure Sierra Chart is up-to-date:
Let us focus on just this one issue:
Do you see these charts listed on the CW menu of the main menu?
Date Time Of Last Edit: 2026-03-21 15:30:52
