Date/Time: Thu, 26 Nov 2026 03:41:37 +0000
Seeking a way to hide HA Open and HA Low in Heikin Ashi Smoothed study
View Count: 339
[2026-03-19 08:42:31]
User140464 - Posts: 7
I am using the Heikin Ashi Smoothed study in the same chart region as my candlestick chart.
I want to hide the HA Open and HA Low (the wick components) of the Heikin Ashi study. Currently, I have set their colors to match the chart background. However, these lines become visible when they overlap with rectangle drawings because the rectangle's fill color differs from the background.
I tried changing the Draw Style for HA Open and HA Low to "Ignore" but as soon as I click the Apply button, the settings automatically revert to "Visible."
Is it simply impossible to change these settings for this study?
[2026-03-19 15:00:53]
You can not change the "Draw Style" for bar-based graphs.
But, if you are really wanting to get rid of the wicks, then on the Subgraphs tab of the Heikin-Ashi study, set the "Graph Draw Type" (at the top of that window) to "Candlestick Body Only". Refer to the following:
Chart Studies: Subgraphs Tab >> Graph Draw Type
If you are really wanting to not display the Open and Low, then there is not a solution to this.
