Date/Time: Thu, 26 Nov 2026 03:41:30 +0000
[User Discussion] - How to display horizontal line value within price axis?
View Count: 472
[2026-03-19 02:30:32]
grayfrog - Posts: 70
Curious if there is a way to display a horizontal line value within the price axis instead of taking up space on the right hand field of the chart?
This seems simple and I've gone through everything I can think of so I'm here asking a very rudimentary question.....
Thank you
[2026-03-19 14:35:56]
There is not a way to do this with the Horizontal Line drawing tool.
The workaround would be to use the "Horizontal Lines" study and then use the "Value Label" option to put the label in the price ladder (or a separate Label column). Refer to the following:
Horizontal Lines
Chart Studies: Subgraphs Tab >> Name and Value Labels
