Date/Time: Thu, 26 Nov 2026 03:41:37 +0000
Chartbook
View Count: 317
| [2026-03-17 14:58:27] |
| eli733 - Posts: 13 |
Hallo Sierra Team, ich habe 12 Grafiken in einem Charbook gekauft . Ich will diesen Chartbook für NQ und ES parallel nutzen. Ich habe schon versucht den FIle in Trade Sierra Windows zu kopieren. So wollte ich zwei Chartbooks NQ und ES machen , praktisch ZWEi Chartbooks. Es geht aber nicht wenn ich bei einem Chartbook auf ES beispielweise ändere, ändert sich der zweite Chartbook auch automatisch auf Es und bleibt nicht als NQ . Bitte um Ihre Hilfe . Vielen Dank! |
| [2026-03-17 15:06:49] |
From Google Translate: I purchased a chartbook containing 12 charts. I would like to use this chartbook for both NQ and ES simultaneously. I have already attempted to copy the file within TradeStation.
My intention was to create two separate chartbooks—one for NQ and one for ES—effectively having two distinct sets of charts. However, this is not working as intended: if I switch one chartbook to display ES (for example), the second chartbook automatically switches to ES as well, rather than remaining on NQ. I would greatly appreciate your assistance. Thank you very much! What are you stating is not possible. If you actually have two separate chartbooks, then when you change the symbols in one of those chartbooks it can not change the symbols in the other chartbook. Make sure you have properly created two separate chartbooks. Refer to the following: Chartbooks (Workspaces): To Save a Chartbook And keep in mind that if you have the option for "Window >> Window Always Visible", then those windows will be visible regardless of what chartbook you are viewing. This is another possibility that you are actually viewing the charts from one of the chartbooks that was changed to ES. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
