Date/Time: Tue, 17 Nov 2026 18:09:17 +0000
Sierra Chart simultaneously on 2 PC's
View Count: 354
| [2026-03-16 10:16:11] |
| User187406 - Posts: 4 |
Hey, I thought about a two PC setup, I already read about that it's possible but that post was from 2023 so I'm not sure if this is still the case. I use Denali Data feed, I did read that you maybe need to pay for a second Data feed for the second PC if not you will have delayed data,is this true? Thank in advance. Date Time Of Last Edit: 2026-03-16 10:23:51
| [2026-03-16 15:40:34] |
| John - SC Support - Posts: 48555 |
It is still true that if you want to get the data from our Denali Exchange Data Feed to two different computers at the same time, then you need to pay a second set of exchange fees. Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously -- We want to point out that the account you have posted from is Expired. But you state that "I use Denali Data feed". If you have another account that you use for Sierra Chart, then be sure to post from that active account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
